today> Twyndyllyngs Chez Mosc
Simplest VC-LFO ever?
Page 1 of 1 [14 Posts]
macumbista
PostPosted: Sat Sep 26, 2009 5:28 am    Post subject: Simplest VC-LFO ever? Reply with quote  Mark this post and the followings unread
I was checking the thread on the Buchla 208 Random PCB, and thought it would be good to have a built-in VC-LFO in the same module. So I'm curious what people might recommend for the simplest LFO of all time.
Here's what it would need to have:
    Linear voltage control
    Pulse output (no need for ramp, sine, pwm, etc)
    Manual frequency adjustment
    Manual CV trim
    Lowest parts count/smallest space possible!
Maybe the voltage controlled 40106 that got posted recently?
macumbista.net
Dave Kendall
PostPosted: Sat Sep 26, 2009 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi.
Maybe something based around a CD4046? like in the CGS31. Look at the top section of the schemo.
http://www.cgs.synth.net/modules/cgs31_digital_noise.html
The output is a square wave. The 10n sets the freq range. I added a 3-way toggle to change the cap values as a range switch.
I also added a simple non-inverting summer made from 2 x opamps before the 10K resistor, to give manual control and 2 x CV inputs, and did not include the 1K to +15V at the front end, as it was now redundant.
This could possibly replace the voltage follower....?
just a thought...
de_engineered
PostPosted: Sat Sep 26, 2009 5:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
There was a Lunetta (or Lunetta-ish) 40106 VCO design somewhere on here - used a diode as current controlled resistor. Might fit your bill - uses the 40106, a 2N3906, the diode, and a cap... think that's about it. Add your necessarily pots and you're good to go.
de_sign : de_stroy : de_engineered
de_engineered
PostPosted: Sat Sep 26, 2009 6:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh royal brainfart, you already found it, doh!
Well, count this as my approval of the design then!
macumbista
PostPosted: Sat Sep 26, 2009 7:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very nice, and elegantly simple! I must admit, I've gone over the CGS site almost a hundred times and didn't look at that that particular schemo close enough yet.
I'll breadboard this one, and the Lunetta-ish 40106 one, and make some comparisons soon.
Thx!
macumbista.net
de_engineered
PostPosted: Sat Sep 26, 2009 8:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Another possible solution: I wouldn't be able to tell you the exact values for building one, but you could do a discrete Schmitt Trigger with two transistors, and treat that as a functional Schmitt block, and have a pot and cap in a feedback loop, and you'd have your pulses. Can't say how 'square' it would be, as within a 40106 itself, per channel it's actually three inverters and a Schmitt trigger in a row - really square!
http://en.wikipedia.org/wiki/Schmitt_trigger#Schmitt_trigger_with_two_transistors
This amounts to *more* parts but with *less* area. Again though, I can't vouch for how sharp the output would be.
Good luck!
bugbrand
PostPosted: Sun Sep 27, 2009 4:28 am    Post subject: Reply with quote  Mark this post and the followings unread
You can actually also get an almost ramp-wave off the 4046 -- if you buffer (non-inverting follower) straight off either side of the timing cap and then combine the signals.
'tis true!
http://www.bugbrand.co.uk
DGTom
PostPosted: Sun Sep 27, 2009 7:30 am    Post subject: Reply with quote  Mark this post and the followings unread
... & all of a sudden the only part of the Wogglebug #3 schem. that didn't make sense to me... does! Very Happy
Thanks Tom! You rule!
macumbista
PostPosted: Sun Sep 27, 2009 8:46 am    Post subject: Reply with quote  Mark this post and the followings unread
macumbista.net
bugbrand
PostPosted: Sun Sep 27, 2009 1:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh - I hadn't looked enough at the Woggle to see that either! I just started trying such things out quite by chance, but then afterwards realized that THenry has something going half-way there in his XR2206 part of the VCO chip cookbook to get a rampoid wave (ie he only taps from one side of the timing cap)
I think I did try it initially just with diodes, but thought it didn't work out quite right -- was better with a buffer on each side and then diode mix before a non inverting opamp (to give a little gain and offset the signal to standard +/-5v)
DGTom
PostPosted: Sun Sep 27, 2009 8:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
as soon as I read your post above I had a total 'head meet desk' moment! I should've realized alot sooner what was going on there as I'd tapped into a timing cap pin on another PLL type chip before to steal the internal oscillator signal.
Very cool tho, can't wait to try it out on a 4046 linear VCO type cct.
square & ramp waveforms off a 50c chip with half a dozen passives and an op-amp or 3 sounds like a good deal to me!!
Coriolis
PostPosted: Wed Sep 30, 2009 8:35 am    Post subject: Reply with quote  Mark this post and the followings unread
I believe Tim Servo posted a pretty simple vc-lfo here some time ago - also with some nice trapezoid waveshaping add-on-stuff...
C
Edit: Oh - and this one of course!
http://electro-music.com/forum/topic-34550.html&sid=3cb459053c73c11fe5d6dab7b4b33ce5
Tim Servo
PostPosted: Wed Sep 30, 2009 3:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Actually, I posted an LFO with a wide frequency range and a couple of add on waveshapers (including the trapezoid / TSQ waveshaper), but my LFO design was not voltage controlled. However, at the start of the same thread, the very prolific Nicolas3141 had posted a simple VCLFO. Nic's design runs off a single supply, but he said it should work with a dual supply. Looks like a cool design:
http://electro-music.com/forum/topic-32372.html
Tim (captain trapezoid) Servo
Coriolis
PostPosted: Thu Oct 01, 2009 12:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah..so that's how it was. Sorry about that!
C
