The death of sofware modulars
Page 3 of 5 [119 Posts]
BobTheDog
Audio files: 32
PostPosted: Mon Oct 12, 2009 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Yep you are absolutely correct.
I have just re-read my posts and they are a bit arsey, sorry about that.
I know it is no excuse but I have been having a bad day/week/month.
Bloody computers!
Andy
purusha
PostPosted: Mon Oct 12, 2009 8:46 am    Post subject: Reply with quote  Mark this post and the followings unread
No worries.
No offence taken.
Smile
OVNI Soundcloud Purusha Soundcloud
Audio files: 299
PostPosted: Mon Oct 12, 2009 8:47 am    Post subject: Reply with quote  Mark this post and the followings unread
BobTheDog wrote:
Bloody computers!
Probably just red paint .. no ? Shocked
It has been said that for multicore DSP a good C compiler will outperform hand coded assembly ... but I'm a noob you can fool me with anything there Laughing
purusha
PostPosted: Mon Oct 12, 2009 8:51 am    Post subject: Reply with quote  Mark this post and the followings unread
In development time and portability terms - almost certainly: yes.
Laughing
Wink
DrJustice
PostPosted: Mon Oct 12, 2009 8:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Not trying to be contrary, but although compilers written specifically for DSPs may turn out good enough code in most instances, I have yet to see one that exploits multifunction instructions really well, combined with interleaving parts of an algorithm to avoid result delays and pipeline stalls and also using peculiar data orderings to avoid unnecessary address register manipulation. That's what makes DSP coding fun; when you look at your code and can see how it exploits every clock tick, every register and every datapath with not a gram of fat - but hey, I'm kinda old school... Very Happy
purusha wrote:
The FFT algorithms themselves are purely based on arithmetic, not addressing mechanisms.
Surely the bit reversed address generators in DSPs are all about addressing issues in FFTs.
Of course, as purusha mentions, when coding C for DSPs you'll for a large part call library routines that are hand optimized. I haven't checked out if the latest compilers support SIMD instructions through intrinsics, I assume they offer something in that area.
However, I do suspect that the audio algorithms in DSP based synths are hand coded assembly - they often do impressive amounts of work compared to the DSP power at hand (e.g. 32 voice Virus C on a single 56k), and there's a tradition to uphold Razz
DJ
purusha
PostPosted: Mon Oct 12, 2009 9:02 am    Post subject: Reply with quote  Mark this post and the followings unread
I guess it depends on the architecture and whether or not the compiler can pull tricks to generate the proper code. To be honest, I only know TMS320 in any depth and didn't have any issues like that IIRC.
I'd have thought that kind of thing could be modularised though? Wrapper functions for making sure things are in the right format - that kind of thing?
BobTheDog
Audio files: 32
PostPosted: Mon Oct 12, 2009 9:31 am    Post subject: Reply with quote  Mark this post and the followings unread
How does the compiler understand a high level algorithm though?
Years ago there was some compiler that recognised the Sieve of Eratosthenes algorithm code and output highly optimised code which they then used in their marketing blurb to show how good their optimiser was!
I think it may have been Borland.
purusha
PostPosted: Mon Oct 12, 2009 9:44 am    Post subject: Reply with quote  Mark this post and the followings unread
I guess to do it properly, standard algorithms would be optimised for a subset of platforms.
A nice solution would be to have a library which kept the same API, but used platform specific optimised code for the algorithm.
BTW - It's not unusual for VST plug-in manufacturers to take algorithms from hardware DSP based platforms and port to native. Often they don't sound identical because of the different methods used to make calculations, but it does appear to be possible.
An example off-the-top-of-my-head, Sonnox?
Edit: this just been mentioned elsewhere too:
http://www.youtube.com/watch?v=a9rJzngpjDY&feature%20=channel&fmt=18
BTW - the "old school" optimisation reference has me remembering the days when I was writing ZX81 games in 1K. That 1K was also used for video RAM, so the more code you wrote, the smaller the screen had to get! Certainly honed your Z80 skillz Laughing
DrJustice
PostPosted: Mon Oct 12, 2009 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, it's exactly data copying and/or reordering one wants to avoid. I just had a quick search for compiler intrinsics supporting address generators (bit reversal, modulo, circular) and such, and it seems there's a lot of that nowadays, which makes it more feasible to write e.g. an efficient FFT in C. BTW, my experiences are based on 56k and AD SHARCs and fixed point DSPs
DJ
purusha
PostPosted: Mon Oct 12, 2009 10:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Agreed, you don't want to have to re-order by buffer duplication and transformation etc. if you can help it. However, if there's a necessity due to architectural limitations and you can do it whilst staying within the performance requirements...
Wink
It sounds like we're talking about a necessity for re-ordering for an algorithm that's beyond my experience though. The DSP algorithms I used were pretty basic and off-the-shelf. I wasn't doing audio DSP work, it was motor monitoring and control. There wasn't much optimisation for us on that job, the DSP had enough grunt to do the job without getting our hands too dirty.
I'm more of a real-time OS guy than a FFT maths type.
Smile
BobTheDog
Audio files: 32
PostPosted: Mon Oct 12, 2009 12:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
BobTheDog wrote:
Bloody computers!
You a Noob!
I am not sure that the C compiler is doing the real work here though.
For instruction level parallelism compilers written by the chip manufacturer do an extremely good job, but for data parallelism it is pretty hard for a compiler to produce parallel code for anything non-trivial without hints from the programmer.
If I knock out a bit of complex serial C code it is hard for a compiler to work out data dependencies and to split the algorithm into the most efficient number of concurrent sub-tasks and to manage the critical path ordering of these sub-tasks based usually on a smaller number of concurrent processing units.
Also the compiler would need some understanding of shared memory cost between these units, for instance the cache between cores is going to be more efficient that shared memory between processors which is more efficient than between machines in a cluster.
Then it has to deal with synchronisation problems to certain resources, it is all starting to look pretty complicated to do a good job.
So you have to start looking at extension to C that allow the programmer to tell the compiler how to distribute processing, these allow you to declare blocks of processing and relationships between them, UPC is an example of this.
Audio files: 299
PostPosted: Mon Oct 12, 2009 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
BobTheDog wrote:
You a Noob!
Laughing I used to be good at compiler building when I was at uni, but I didn't pay attention really for the last 25 odd years ... all the multiple data / instruction issues were just remarks then ... DSP was barely touched ... but I guess the dragon book still has some useful tricks these days.
What is UPC ... ah ... http://en.wikipedia.org/wiki/Unified_Parallel_C ... reading up now.
cappy2112
PostPosted: Mon Oct 12, 2009 8:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have a great documentary about Atari- in the early days, on DVD.
There are interviews with the programmers who wrote the games for the 2600. They had to write the game logic, the graphics I/O (while maintaining refresh rates), the sound fx (while still maintaining video refresh rates).
Some of those programmers got several hundred thousand dollar bonuses, in the early 80's, for the top-selling games !!!!!!!!!!!!!!!!!
Chet
G2 patch files: 35
PostPosted: Tue Oct 13, 2009 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
buzzr wrote:
Right now I'm using the G2 with Reaktor and having some very good results.
Maybe Reaktor will be updated.......HA!
Heh, I agree that Reaktor's overdue for an update. But it still has some life in it. I'm building a collection of Reaktor macros right now in an attempt to mimic the style and operation of the G2 modules. I've got another dozen or so modules to finish, and then I'll submit it to the Reaktor user library.
I'd add a picture of it, but I got a message saying "Sorry, you have reached your maximum Upload Quota Limit of 20 MB".
Audio files: 299
PostPosted: Tue Oct 13, 2009 10:26 am    Post subject: Reply with quote  Mark this post and the followings unread
I raised your limit Chet and would love to see the picture Wink
Chet
G2 patch files: 35
PostPosted: Tue Oct 13, 2009 10:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Great! Here it is.
G2-style modules in Reaktor.
 Filesize:  262.5 KB
 Viewed:  251 Time(s)
dorremifasol
G2 patch files: 49
PostPosted: Tue Oct 13, 2009 10:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow, that looks pretty nice Very Happy
Albert
Audio files: 299
PostPosted: Tue Oct 13, 2009 10:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Chet wrote:
Here it is.
Thanks! looks good!
BobTheDog
Audio files: 32
PostPosted: Tue Oct 13, 2009 10:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Beatless Chords sounds interesting, what does that do then?
Chet
G2 patch files: 35
PostPosted: Tue Oct 13, 2009 11:18 am    Post subject: Reply with quote  Mark this post and the followings unread
It makes minor adjustments to pitches, converting equal temperament to just intonation. You choose a root key, and when you play chords some of them (I, IV, V, IIIm, VIm, etc.) do not beat. It’s an unusual sound for those of us accustomed to hearing equal temperament-based music. It’s especially useful for crunching guitars and overdriven organs, because major chords don't sound muddy.
BobTheDog
Audio files: 32
PostPosted: Tue Oct 13, 2009 11:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the info, it all looks fun.
I look forward to a play.
buzzr
PostPosted: Tue Oct 13, 2009 4:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks nice Chet! You're giving Bantri a run for his money Smile
In the meantime I'm investing in a doepfer...
Chet
G2 patch files: 35
PostPosted: Tue Oct 13, 2009 8:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, I'm not attempting anything as difficult as Bantri is. I'm making an imitation, not a copy. He's actually going to emulate 24-bit integer math in Reaktor (egads!), while I'm content to paste in stock oscillators and filters. Smile
Unfed
G2 patch files: 11
PostPosted: Tue Oct 13, 2009 9:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Chet wrote:
Great! Here it is.
Shocked absolutely fantastic, looking forward to it! i'm actually more interested in something like this than what Bantri is doing. we'll see how this works out as far as patching. not sure exactly what it entails, pretty exciting though!
Chet
G2 patch files: 35
PostPosted: Sat Oct 24, 2009 2:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's been uploaded to the Reaktor User Library now, and can be found at http://co.native-instruments.com/forums.html?id=userlibrary&type=0&ulbr=1&plview=detail&patchid=8957
It includes four sample instruments built with the modules: a waveguide guitar, bells made with modal synthesis, a Hammond organ, and a basic VA synth with 16 stereo sawtooth oscillators.
