4049 hex inverter
Page 1 of 1 [22 Posts]
lostinpurdy
PostPosted: Sun Oct 25, 2009 5:43 pm    Post subject:  4049 hex inverter
Subject description: vco/vca/vcf applications - looking for examples
Hello - it's been awhile since I posted anything and I was just beginning to understand the concept of (music) electronics but then things happened and I had to abandon it all and eventually lost interest.. until now. So after messing around with some beginner circuit I came across the 4049 which is basically 6 inverters in a chip. Now knowing that inverters are commonly used especially in vco and lfo circuits, I was wondering if this chip would be a good candidate for such applications or even vcf and vca applications? Are there any examples flying around out there? I'm kind of aiming to build a single chip based synth.
Greetings, Patrick
lostinpurdy
PostPosted: Sun Oct 25, 2009 6:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
just noticed I posted that into the wrong place..
Audio files: 297
PostPosted: Mon Oct 26, 2009 2:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok, moved it up a bit.
Dave Kendall
PostPosted: Tue Oct 27, 2009 4:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Patrick.
Maybe try the hex VCA schemo below - it's an old EFM design, and looks interesting.... Haven't tried it myself.
EDIT - I guess +V is on pin 16, and GND on pin 8 , but I'm not sure how pin 1 works, as it seems to be connected to GND as well as the input to the TL071.
Hmmmm.. Anyone seen anything like this before?
 Filesize:  172.84 KB
 Viewed:  2122 Time(s)
"Everything in moderation, including moderation"
DGTom
PostPosted: Tue Oct 27, 2009 5:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Grab the datasheet & take a look at the pin out of the 4049 to see how really wierd that cct. is,
4049 / 4050 don't follow standard CMOS VCC / VSS Wink
Dave Kendall
PostPosted: Tue Oct 27, 2009 7:25 am    Post subject: Reply with quote  Mark this post and the followings unread
WOAH!
pin 1 is VCC and pin 8 is GND?
Blimey - that is seriously weird......
lostinpurdy
PostPosted: Tue Oct 27, 2009 9:14 am    Post subject: Reply with quote  Mark this post and the followings unread
hm.. so judging from the schematic it'd give me about 6 vca's in one little circuit? would it be possible to substitute the opamp with one of the internal inverters as a buffer so that I (hopefully) get a single chip vca, vco/lfo/AR, vcf design out of it? I'm thinking of using two inverters to be switchable between astable and monostable mode so that either of them can be used as a vco, lfo or attack/release generator, one inverter for vca, one as a simple vcf, leaving the remaining two as buffers for vca/vcf. Just an idea for a one chip synth/module I'm hoping to put together.
JovianPyx
Audio files: 224
PostPosted: Tue Oct 27, 2009 10:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't forget to look at 4069UB and 4007. These ICs are interesting for synthesis as well.
The difference between 4069UB and 4049 is that the 4069UB has symmetrical output transistors and the 4049 does not.
The 4007 is almost a transistor array and often, individual transistors can be used. 4069UB and 4007 can be used to make VCF, VCA and VCO as well.
Time flies like a banana.
corruptio optimi pessima
DGTom
PostPosted: Tue Oct 27, 2009 3:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
:facepalm: should have mentioned the 4069, ScottG has some FANTASTIC ccts. using that little critter Very Happy It feels really wierd saying (typing) it but... its a great sounding CMOS chip Laughing
I think Mark Verbos even posted a message to the SDIY list awhile ago mentioning he subbed it into an old Buchla waveshaping cct. with good results! As well as a few VC Fuzz type things I've also built a fairly resonable low pass gate with it, still tinkering with the CV input of that however - responds great to big rail to rail pulses from other CMOS but not so well to envelopes or more usual CV sources.
Somehow I still havn't got around to trying Rene S. 4069 VCO Embarassed
jnuaury
Audio files: 9
PostPosted: Tue Oct 27, 2009 11:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow, that 4049 circuit is really intriguing, looks "passive" too
any info on what EFM this is from or any more information on the circuit?
stolenfat
PostPosted: Wed Oct 28, 2009 2:17 am    Post subject: Reply with quote  Mark this post and the followings unread
I found this one on the the squarewave parade site... i havent tested it... i probably should considering i have a huge load of 4049s sitting around.
MULTI-SHAPE LFO:
 Filesize:  31.51 KB
 Viewed:  44106 Time(s)
Dave Kendall
PostPosted: Wed Oct 28, 2009 4:41 am    Post subject: Reply with quote  Mark this post and the followings unread
: jnuaury :
EFM was a site started in the late 90s by Tom Gamble. Lots of circuits were published, and many of them made into circuit boards for sale.
They were inexpensive, and a great way for someone *less* than very rich to get into building synths Smile
Tom no longer sells PCBs, but does have some VST plugins on his site. http://www.ele4music.com
CJ Miller kindly sent me that schemo from a collection he had made from early posted stuff while there was a forum on the EFM site. I doubt if there are any notes still existing about that particular schematic, as the EFM site and forum died and were born again a couple of times, and a lot of the early notes were lost.
The most complete collection of stuff I've seen on the web is hosted by Fonik here
http://www.modular.fonik.de/Page37.html
lostinpurdy
PostPosted: Fri Nov 06, 2009 9:37 pm    Post subject:   Reply with quote  Mark this post and the followings unread
thanks for all your input - the LFO looks promising and I'm pretty sure it could be turned into a VCO and EG kind of thing - as a matter of fact I might try to accomplish a multifunction modulation device out of that, which ideally would be swithable between VCO, LFO and EG modes. Now what would be the likelyhood of using the 4049 for VCF applications? I've seen simple lowpass and bandpass VCF circuits using an inverting op-amp topology and since inverters are basically inverting op-amps I should be able to make some decent VCF out of that, right?
PS: Why the 4049? Because that's what came with my Radioshack lab. And that's the only kind I have right now.. inverter wise that is. I ain't rich, ya know.. Wink
yusynth
PostPosted: Sat Nov 07, 2009 1:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Many years ago, Sam(Osamu) Hoshuyama did post on the SDY list a series of designs of his of a basic modular synth all based on CMOS circuits.
You can find it al here :
http://www5b.biglobe.ne.jp/~houshu/synth/index.html
Some of these brilliant designs:
Yves
The Real MC
PostPosted: Tue Dec 15, 2009 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've been looking into that EFM hex VCA circuit.
The 4049 is a hex inverter IC. Manufacturers build their inverter circuits differently and this schematic may very well be dependent on an inverter design from a certain manufacturer.
It may not even work with a 4069.
The problem is, the IC manufacturer is not specified in the schematic. Most tinkerers will be confused if they breadboard this circuit and it does not work.
Some of the clever circuit designers have been known to design a circuit around the substrate makeup of ICs. The old minimoog has one such circuit - the 741 - that will not work with modern opamps.
richardc64
Audio files: 26
PostPosted: Tue Dec 15, 2009 4:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't care who has had what success with the things: I will never ever trust digital CMOS used linearly, except in the simplest of applications, e.g. no-frills amplifiers, as used in the Osamu Envelope Follower and Noise Generator circuits. (Do you hear me, all youse over there in the Lunetta forum?)
Negative. Look at how the 4049 is wired. Vcc and Vss are connected together, creating an output "buss" of all the mosfets' drains and sources. Individual inverters are not available separately for any other use.
btw, I've looked at 4049 data sheets from National and Fairchild and the innards appear identical. The 4069 is slightly different, so, indeed, it may not work in the hex VCA circuit.
 Filesize:  8.67 KB
 Viewed:  43254 Time(s)
PostPosted: Wed Dec 16, 2009 12:19 am    Post subject: Reply with quote  Mark this post and the followings unread
great diagram, richard! thank you.
PostPosted: Sat Jan 26, 2019 12:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ten years after! Wow. Very Happy
Good things need time...
PRB617 wrote:
Thanks again. I did try the circuit again and it does work fine now. I'm not sure what I did wrong, I may have not had the VCC +5 to the best inverter connected the first time around and it might have back fed through, but it's good now.
Audio files: 297
PostPosted: Sat Jan 26, 2019 2:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Better to not reply to spam fonik ... edited some stuff out of here ...
PostPosted: Sun Jan 27, 2019 2:59 am    Post subject: Reply with quote  Mark this post and the followings unread
oopsie.
Embarassed
have not been aware of the situation.
amarello
PostPosted: Mon Mar 04, 2024 7:06 pm    Post subject: I found it Reply with quote  Mark this post and the followings unread
Dave Kendall wrote:
Hi Patrick.
https://www.paia.com/talk/topic-481.html
Hello!
crazy circuit, i´m gonna test it
someone has seen this working?
Ayab
PostPosted: Sat Apr 06, 2024 3:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Amarello
I have not tried the 4049 Hex VCA but it looks very interesting and with a pcb design on the Paia pdf - handy for etching. Maybe helpful to note that regarding the schematic posted by Dave Kendall most EFM designs were for 12V
Look forward to hearing how it turns out and if the low impedance of the inputs is good with the sources you use it with.
