Morph groups Wheel and Vel: they not assigned to anything
Page 1 of 1 [19 Posts]
G2Psy
PostPosted: Wed Oct 21, 2009 5:45 pm    Post subject: Morph groups Wheel and Vel: they not assigned to anything Reply with quote  Mark this post and the followings unread
Running a G2 engine, so I'm relying on a midi controller to drive the engine. I can set up morph groups which are controlled by CC messages. So far so good. But I don't understand the Wheel and Vel morph groups which are there by default. Neither respond to wheel or velocity and F8 shows that no external midi is assigned to them.
Can they be used for wheel and velocity, how can I set this up?
B
Audio files: 329
PostPosted: Wed Oct 21, 2009 6:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Click on the knob below until it is in "knob" mode, you'll be able to use 'm then eithr from the editor or by assigning a CC to them.
G2Psy
PostPosted: Wed Oct 21, 2009 7:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I can do that. But can I assign the mod wheel CC01 or note on velocity to them? Mod wheel doesn't move the morph group labelled as Wheel and CC01 is not listed as an assignment. Similarly, note on velocity doesn't control the morph group labelled Vel. Are you supposed to be able to control morph groups with mod wheel and note on velocity?
B
G2Psy
PostPosted: Wed Oct 21, 2009 9:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
No wait, I understand now. If you change the setting underneath to 'Knob' then you can get any midi controller to control a morph group. If you click them to say 'Wheel' or 'Vel' then the controls don't move in real time but they are in fact controlled by Wheel or Velocity (or whatever is hard wired for each morph group).
Why is the obvious so hard to understand with a G2 Embarassed
B
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Oct 21, 2009 11:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
G2Psy wrote:
... Why is the obvious so hard to understand with a G2 Embarassed
Just take your time...
Once a synth-tech of the group Duran Duran phoned in because of a NM Classic Patch, which won't run they way it was supposed to.
It was just a small button and a blind spot...
Eventually you'll find your way Smile
Wout
Audio files: 329
PostPosted: Thu Oct 22, 2009 7:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Its not too obvious I think ... actually its a design error Shocked Laughing (for the engine that is, on the keyboard version it seems like a good idea).
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Oct 22, 2009 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
The thing is racks can do less than keyboard versions. Clavia makes keyboard instruments, no racks, well, they do, but a Midi keyboard doesn't have the same control as the 'internal' keyboard. And Clavia means keyboard key, a strange name for a compagny which started to make drums Very Happy
Wout
Audio files: 329
PostPosted: Thu Oct 22, 2009 9:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Twisted Evil Come to think of it .. a keyboard is a design error as well although it's nice for tapping a few test notes ... but it should have analog inputs for controllers and gates and triggers & OSC over ethernet too .. and all connectors on the front ... anyway ... something for a future product [that I'd have to design myself] I guess Laughing
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Oct 22, 2009 11:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Of course is the keyboard a total disaster, because it's only designed as a technical solution to the problem controlling strings, so ergonomic... ouch!
Nevertheless Clavia produces keyboard instruments as main product...
Wout
Audio files: 329
PostPosted: Thu Oct 22, 2009 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Organs ... yeah ... I won't argue that.
G2Psy
PostPosted: Thu Oct 22, 2009 2:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wout
My G2 Engine does not physically fit into my lowest-possible-price kit rack, so I can totally agree that their rack products are inferior to their keyboards Smile Also, if you get a Nord rack 2x to actually put it in a rack, you waste a few spaces above because the plugs are all up the top. Obviously designed by people who think that things without keys aren't worth their attention!
B
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Oct 22, 2009 2:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nah...
That's design philosophy!
To Midi through the red box has to be at the end of the line, but using it in a 19" rack only on top Very Happy
What I meant was doing some serious controlling the music. On a rack one cannot use (what I call) Slot Hold: let the Arpeggiator run while holding the keys; de-activate the Slot and the sound will go on; play another Slot and the first Slot isn't changing: it's in Hold...
A rack is controlled by Midi, an outside controlling force.
Wout
G2Psy
PostPosted: Thu Oct 22, 2009 2:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow yes, good point Wout about arp holding. The whole idea does make more sense with the keyboard and controllers built in. If you tried to save money and already had controllers (like me) then the manual is a bit depressing when you first read it. They seem to gloat about all the things you don't have in the rack engine version.
The engine is probably best used as a multi-timbral sound module for something else. All those arp, sequencing and external control features are great but maybe not that much for the rack.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Oct 22, 2009 3:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Clavia makes synthesizers for the performing musician and hardly for the studio.
Wout
3phase
G2 patch files: 141
PostPosted: Wed Oct 28, 2009 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
?? where the difference? except real modulars, that are to big for stage use, any synth is for the performing artist..in or out of the studio..or have i missed something?
G2Psy
PostPosted: Wed Oct 28, 2009 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
When Roland describe something as a performance synth, they mean it lacks features like multi-timbral, patch storage for multi-part setups and an actually useful effect architecture. Plus don't try to put in any creative new synth ideas because the performer doesn't want cutting edge sounds and new ways of err performing.
Is it some kind of badge of honour to not want to do something new with a synth?
Anyways, wout's point about performance synths most likely means: yes, it doesn't do some of the things you think are important Smile
B
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Wed Oct 28, 2009 6:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wout
Well, the G2 keyboard, is quite a performance instrument, for me. Pretty insane really. I have put my whole live pa (sequencing) set heart/brain into it, and it can keep my show going.
Having premade self sequenced patches inside a performance means having a backing on your live set, while using the panel to surf and tweak the variations means the kind of control that I need.
Ok, with the Engine, I am sure it is another story. But I think it depends on the controller you use with it.
As I recall, the Nord G2 keyboard preceeded the Engine, which can explain why the editor tends more towards the keyboard side.
Now, whether this, or any other issue could be put into for a future OS or editor, well ,that question has already been answered by Clavia. Perhaps our friend doing the NOMAD might do a G2 version?
Love the red beast, can't get enough ...
/Dasz
synthlab
PostPosted: Mon Nov 23, 2009 6:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
I use a Peavey PC1600x with my G2 Engine. That helps. I can change presets. Turn on arpeg and make adjustments. I miss having a display and I forget where things are.
I would rather not be tied to a computer when I play out. I would rather have something dedicated and labeled as apposed to using a Novation Remote Zero, which at least has displays.
What I keep coming back to is to use an Arduino to build a section of the G2 keyboard front panel that sends MIDI to the Engine. Has anyone built hardware like that? I need to push that further up my to do list. I am open to ideas, feedback or collaboration, if anyone is interested.
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Mon Nov 23, 2009 7:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
That would be a nice thing even for g2 panel users. I remember years ago recommending a feature for Clavia to support mutli g2 panel communication via MIDI. Didn't get developed though.
I reckon you'd have to do some USB code hacking (not MIDI) since in patch edit mode, the G2 panel get's the selected module in the editor (and can select modules with the navigation keys).
/Dasz
