Thunder
Page 1 of 1 [9 Posts]
Inventor
Audio files: 267
PostPosted: Thu Apr 22, 2010 10:11 pm    Post subject: Thunder
Subject description: Advice on how to make thunder in ChucK?
Hi, I've been challenged by a colleague to make some really good thunder using ChucK. I have kijjaz's thunder models but they are not overly realistic. So I'm asking what approach would you take to making thunder? I need gentle rolling thunder, violent claps of thunder, spatialization with traveling, etc. So how would you do this?
Les
PostPosted: Fri Apr 23, 2010 8:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds like a really tricky thing.
Maybe download a few samples of real thunder and analyse what's going on in those?
kijjaz
PostPosted: Fri Apr 23, 2010 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah, how can we model a thunder sound? ..
I'm thinking..
(1) Sparking Mechanism --> I'm thinking about a line of low-frequency / DC burst.
(2) a set of delays that line of energy burst to simulate sounds reflecting between clouds .. so maybe we should have some cloud models etc...
(3) the filtering effects of the atmosphere / clouds.
seems chaotic to me wahahahha..
Inventor
Audio files: 267
PostPosted: Fri Apr 23, 2010 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Kij, nice modeling ideas. I have a great thing for a cloud model. It would be a Karplus Strong circuit. I have code for this to save you trouble if you decide to code up something. KS is a little resonant thingie that can be tailored to a loop frequency that is in the range of clouds.
Then delay lines between the clouds.
And what would the source be, a burst of noise?
Spatialization with Pan2 UGen on each cloud according to it's position (delay) etc.
Les
Inventor
Audio files: 267
PostPosted: Fri Apr 23, 2010 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is the Karplus Strong model:
Code:
class KarplusStrong {
    // the patch
    Gain input => LPF nlpf => Gain sum => LPF lpf => Gain output;
    lpf => Gain feedback => Dyno limiter => DelayA delay => sum;
    160 => nlpf.freq;
    limiter.limit();
    second => delay.max;
    fun void set(dur dly, float freq, float fb) {
        dly => delay.delay;
        freq => lpf.freq;
        fb => feedback.gain;
KarplusStrong KS;
Les
Inventor
Audio files: 267
PostPosted: Fri Apr 23, 2010 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
each cloud has an x,y,z position in the sky. Delays between clouds are proportional to the distance between them. Panning position is a function of x. Clouds move their positions slowly during the storm...
Les
Inventor
Audio files: 267
PostPosted: Sun Apr 25, 2010 4:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Guys I took a quick shot at it and didn't get far. Decided to employ a charging mechanism like neurons - you know, clouds charge up then they release into other clouds, who then charge up... causing chain reactions. Too early to tell though...
Les
Inventor
Audio files: 267
PostPosted: Sun Apr 25, 2010 11:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is some thunder. It has a charging mechanism and a charge transfer (lightning) mechanism between clouds. sound is panned according to x position. clouds self-lighten if a threshold is reached. clouds are connected together with nearest neighbor connections.
It sounds ok.
Les
Thunder2.ck
Some Thunder
 Filename:  Thunder2.ck
 Filesize:  3.65 KB
 Downloaded:  341 Time(s)
Inventor
Audio files: 267
PostPosted: Tue Apr 27, 2010 11:59 am    Post subject: Reply with quote  Mark this post and the followings unread
OK i have the thunder more realistic now but it starts up with a resounding storm which eventually fades into nothingness. I need something more storm-like. Any suggestions?
Les
Thunder4.ck
Some more Thunder (with issues)
 Filename:  Thunder4.ck
 Filesize:  3.51 KB
 Downloaded:  371 Time(s)
