today> Twyndyllyngs Chez Mosc
Haible Vokoder?
Page 10 of 20 [481 Posts]
Goto page: Previous 1, 2, 3, ..., 8, 9, 10, 11, 12, ..., 18, 19, 20 Next
zthee
PostPosted: Sun May 30, 2010 3:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Jürgen, Great to read about the progress!
Mono-Poly, The 20x20 is €158 from Ghielmetti http://www.ghielmetti.ch/forums.html?nav=19,48,107&Kategorie=Kreuzschienen-50VAC/6A&prod_id=56
jhaible
PostPosted: Sun May 30, 2010 5:57 am    Post subject: Reply with quote  Mark this post and the followings unread
mono-poly wrote:
zthee wrote:
Yeah, I know, it takes some thinking and it's done! Wink
Though I'm sad to report I removed the cushion last night Embarassed In favour of making a rack mount panel, but you could always mount the panel in a box with a cushion Smile
I've done some more thinking, and is feature creeping this panel now.. How about hardwiring the FS-1A to the signal input, and a triple chorus to the carrier input?
http://www.thehumancomparator.net/tmp/haible-vocoder3.png
Only thing you should think about is the patch matrix.
A 36x36 is a comon one to get.
Other sizes are very very expensive.
Sad
The Ghielmetti from my link above is around 150 Euros, for 20x20.
Are there 36x36 cheaper than that?
I think for a vocoder the small size (3mm between rows and columns) should be enough. I don't expect wild on-the-fly crosspatching as with a VCS3. Also, shorting pins should be ok here - you want to interchange sources for destinations, not mix them. (Or do you? ... well, maybe ...)
Jh.
astroschnautzer
PostPosted: Sun May 30, 2010 11:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sad
Jh.
The nord modular vocoder can mix the signals , I think its a good feature.... real good for certain things..
zthee
PostPosted: Mon May 31, 2010 12:42 am    Post subject: Reply with quote  Mark this post and the followings unread
How does mixing work with a patch matrix? (Perhaps that's another thread, but anyway)..
If it's complicated I'd say skip it. If it's doable and doesn't require a lot of thinking and extra circuitry - I say put it in. But I'd prefer if we all avoid feature creeping this project and thus risking it not ever getting made...?
mono-poly
PostPosted: Mon May 31, 2010 12:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Ooow that 20x20 is pretty fair priced indeed.
Didn't see that one before.
Mixing is possible but you really need to buffer the matrix if you go that way.
astroschnautzer
PostPosted: Mon May 31, 2010 1:15 am    Post subject: Reply with quote  Mark this post and the followings unread
If you choose to make banaplugs instead of a patch matrix wouldnt it be just a matter of where you plug your plugs? Or is it possible with a patch matrix to make two junctions in one row?
jhaible
PostPosted: Mon May 31, 2010 2:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Basically, you just use resistor pins instead of shorting pins.
If you want real independent mixing without any crosstalk, you'd need a virtual GND summing node input for each channel. I will *not* include this (not even the VCS3 has it), but you can add it on a piece of veroboard. It's just 40 opamps (10 quads like TL074).
But if you're using resistors of about 4.7k, you should get decent results with just a little crosstalk, without these opamps.
BTW: Are there any interesting demos for cross-patched vocoder channels? I admit that I never saw such a big benefit in it. The formant shifting that is always quoted as a main application can also be done with a pitch shifter in the Analyzer channel, can't it?
Anyway: I'll provide the possibility of cross-patching, of course. On the PCB, it's just a row of connectors where you plug in the matrix, or jumpers instead.
JH.
zthee
PostPosted: Mon May 31, 2010 2:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds easy enough! Smile
jhaible
PostPosted: Mon May 31, 2010 2:21 am    Post subject: Reply with quote  Mark this post and the followings unread
It's tiny, though - 1/4 of the area I've used in the synthi clone.
Probably just right for a vocoder. It's been a while since I had the big Synton vocoder in my hands, but that might be about the matrix size.
JH.
jhaible
PostPosted: Mon May 31, 2010 2:24 am    Post subject: Reply with quote  Mark this post and the followings unread
You might also try to reduce the series resistors of the opamp outputs that feed the matrix, to improove crosstalk. I've been conservative with 470 Ohms, but the opamps might get away with a much lower value, without oscillating. It's all DIY, so everybody can customize it to his/her taste.
JH.
mono-poly
PostPosted: Mon May 31, 2010 2:25 am    Post subject: Reply with quote  Mark this post and the followings unread
JH.
The Synton vocoder uses a smaller matrix indeed if we compare it to the ems one.
jhaible
PostPosted: Mon May 31, 2010 2:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Layout for Silence Bridging / Filter Bank finished.
Current state of the layout:
http://www.jhaible.de/vocoder/working_on_vocoder.jpg
The Filterbank funktion will have 3 modes:
1) On
The Filterbank will always be mixed with the vocoded sound, acording to how you set the Filterbank sliders.
2) Off
Basic Vocoder function
3) The Filterbank function will fade in when there is no speech. So there is always a coloured Excitation signal. While you speak, the colour is set by the speech. When you don't speak, the colour is set by the 20 Filterbank sliders. This allows a seamless blend of ariticulated and non-articulated sound.
You can set the threshold - how many dBs down the speech signal is, before the filterbank is engaged -, and the attack and release time of the filterbank fade in/out, with 3 potentiometers.
I'm pretty excited to hear this working when the prototype is finished - so far I only know it from a Sennheiser Vocoder demo.
JH.
TekniK
PostPosted: Mon May 31, 2010 7:05 am    Post subject: Reply with quote  Mark this post and the followings unread
am realy curious
zthee
PostPosted: Tue Jun 01, 2010 1:56 am    Post subject: Reply with quote  Mark this post and the followings unread
I just realized how big that board is! Shocked
jhaible
PostPosted: Tue Jun 01, 2010 2:42 am    Post subject: Reply with quote  Mark this post and the followings unread
It will fit into the bottom of a 19" rackmount enclosure.
Height will mainly be determined by the front panel elements you choose.
That is, if you don't want any channel pots, matrix, or filterbank functions, you can probably put it into a 2U enclosure.
For my own prototype, I've bought a 3U enclosure, and will probably use tiny potentiometers. For sliders, and/or a matrix, just use more height, or go for a tabletop enclosure.
Also, I do *not* expect the PSU to fit on that board, so you will probably have to use a separate +/-12V supply. (Yes, *not* +/-15V this time. But if you want to integrate it in a modular system, a separate PSU is recommended anyway. Don't know yet what the power consumption will be, but the EMS5000 has a 1.5A @ +/-12V rating.
But wait before you go shopping for a PSU - maybe there is room left for regulators on the board. The power transistors must go to an external (off-board) heatsink anyway. We'll see.
Today I start implementing the Slew/Freeze function. It will be a mix of EMS2000 and 5000 method (no PWM stull like the ETI), with some extras from myself. What I plan is to have a Slew/Freeze/Accumulate function. "Accumulate" works a bit like these "Infinite Reverb" programs: Everything sing into the microphone will "add" to the previously frozen spektrum. The normal Freeze function is available, too, of course. Again, well see how useful this is, or not. I'll implement it and try it.
JH.
Luka
PostPosted: Tue Jun 01, 2010 7:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
now that i have finished my mb808 this looks like it will take it's spot on my desk. probably about the exact same size pcb. we use a tilted desktop hammond case for the mb808, perhaps it will also suit the vocoder
problemchild
melbourne australia
frenchyinmunich
PostPosted: Wed Jun 02, 2010 4:22 am    Post subject: Panel Reply with quote  Mark this post and the followings unread
Hi Zthee,
I sent you a message in PM but it seems there is a problem for you to read it.
It was about the TZ VCO front panel you show us and asked for our point of view.
Apparently you are not in a hurry to produce it.
And it seems I am more interested. Could you please tell me what tool do you use to design your panels?
could it be possible to get the file I find that panel so nice for my buchla oriented clone that I want to start with that panel ASAP.
Thanks for the nice work,
Francois
TekniK
PostPosted: Wed Jun 02, 2010 4:56 am    Post subject: Re: Panel Reply with quote  Mark this post and the followings unread
frenchyinmunich wrote:
Hi Zthee,
Francois
You have to bomb his PM box with 3 PM's each day Wink
He use illustrator Francois
zthee
PostPosted: Thu Jun 03, 2010 4:12 am    Post subject: Re: Panel Reply with quote  Mark this post and the followings unread
TekniK wrote:
You have to bomb his PM box with 3 PM's each day...
That's funny because it's true.
Well, enough about me! Let's get back on topic!
frenchyinmunich
PostPosted: Thu Jun 03, 2010 4:16 am    Post subject: Voko Reply with quote  Mark this post and the followings unread
Hello,
I recently spoke with Juergen about different things and about the Voko.
I wanted to know if the EMS were built around OTA?
Nice to see you back Zthee. Smile
f
TekniK
PostPosted: Thu Jun 03, 2010 5:54 am    Post subject: Re: Voko Reply with quote  Mark this post and the followings unread
Hello,
f
i think Juergen wrote somewhere in the topic it uses LM13700
jhaible
PostPosted: Thu Jun 03, 2010 6:04 am    Post subject: Re: Voko Reply with quote  Mark this post and the followings unread
Hello,
f
EMS used CA3080, for the channel VCAs and for the Slew control.
I'm using LM13600 or LM13700. (Buffers are unused, so you can choose either chip.)
JH.
frenchyinmunich
PostPosted: Thu Jun 03, 2010 6:10 am    Post subject: OTA Reply with quote  Mark this post and the followings unread
Hi Juergen,
And EMS sounds quite ok... Wink
Go back solder the rest of the board if it is not yet finish.
I am hurry to hear demos. And hurry to get the next secret weapon. Wink
F
jhaible
PostPosted: Thu Jun 03, 2010 6:31 am    Post subject: Re: OTA Reply with quote  Mark this post and the followings unread
Hi Juergen,
F
No Vocoder design work today. My wife has taken the day off, so I'm full-time father for baby-girl Anais today. Bible-study group tonight. Back to Vocoder layout work tomorrow. Smile
JH.
frenchyinmunich
PostPosted: Thu Jun 03, 2010 6:45 am    Post subject: Moto Reply with quote  Mark this post and the followings unread
You moto sounds like some Samuel Jackson one in Pulp Fiction.
