Backlog Free "Special Timbral Generator" DIY
Page 2 of 3 [69 Posts]
inform3r
PostPosted: Sun Feb 13, 2011 10:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey phd... Any idea on what the price will be? Also, will it accept 1.2v CV? What kind of power connector will it have? I noticed you mentioned card-edge connectors on your blog, but I can't tell for sure if they have anything to do with powering the circuit.
BTW, I have an original panel of the module that inspired you to build this circuit. Will it be possible to put your PCB behind my panel and wire up the corresponding knobs, switches, exactly like the original?
phdinfunk
PostPosted: Sun Feb 13, 2011 7:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm not 100% sure on the price yet. Allied is selling Vactrols for about 5 bucks a pop. You've got to pay for 8 of those, some cool transistors and tempcos and such, PCB manufacturing and assembly. I am working like hell to source things and find a PCB fab and assembly house to get all this done for as low a price for the end-user as possible. If I end up, for example, able to buy a bulk of vactrols from some warehouse through alibaba.com or something along those lines, then everything gets cheaper.
It's going to be 1v/Oct, not 1.2V/Oct, However, it could be modified for 1.2V if you are comfortable messing around with SMTs, or can find someone who is.
We're setting it up with a "blacet style" power input and everything is running off +15V/-15V/0V.
The pots, jacks, LEDs, etc will connect to edge connectors, and I'll probably set up a ribbon cable with the remote control inputs (basically an aux CV system and a system to control the switching).
The topology is precisely the same as the original, and we've kept the switchable computer control system as well. Though we are not the same manufacturer as the original, we're working to keep the soul of the system as true to the original as possible. Thus, you will be able to wire it up, switch for switch, pot for pot, jack for jack, LED for LED to an original panel if you so desire.
For people without original panels, we're looking into having panels made from Printed Circuit Board material that fit FracRac systems. The good news on this part is that it looks like it will be astonishingly cheap once we're having ten or more done at a time.
--JP
www.phdinfunk.com
cbm
PostPosted: Sun Feb 13, 2011 7:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
So the board(s) aren't set up to parallel to the panel like in the original?
Chris Muir
http://www.eardrill.com <– My jobby (more than a hobby, less than a job)
phdinfunk
PostPosted: Sun Feb 13, 2011 8:28 pm    Post subject: Yes Reply with quote  Mark this post and the followings unread
They ARE meant to be parallel to the front panel. However, the front panel design I'm setting up attaches them via standoffs.
The original also had a panel control board, which was wired to the mainboard. I'm bypassing all that and just making it one PCB with everything that you attach to whatever panel design you like via wires to the edge connectors.
Now, to answer more specifically informer's question: my panel dimensions are different from the original and it WON'T mount directly onto the panel via the pots the way the old one did.
Originally I'd planned to make everything panel mount. But I decided that I want to leave people more options.... like the fella who wants to mount to an original panel.
--JP
www.phdinfunk.com
TekniK
PostPosted: Mon Feb 14, 2011 12:56 am    Post subject: Reply with quote  Mark this post and the followings unread
you should provide also a single general connector for ribon cable for all pots,led etc.
So then it worth for someone to draw a pot-pcb for this project..
phdinfunk
PostPosted: Mon Feb 14, 2011 5:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Okay, that's a good idea. Anyone see a problem with using a ribbon connector for all pots, LEDs, etc? At this point, it's not a big deal to move things around on the PCB.
www.phdinfunk.com
inform3r
PostPosted: Mon Feb 14, 2011 1:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Speaking of sourcing... JP, you should PM me. I have sources for those pesky "unobtanium" parts, as well as a small stash for myself. I'd be willing to donate enough of these parts to you for the purpose of getting the prototype up and running. It's also my way of "giving back" to this great community. Let me know if this is of any interest to you.
Glad to hear it's possible to modify it for 1.2V. Will you provide instructions to those who wish to do so when the PCB is available?
That is amazing! The only challenge will be finding a way to mount your PCB to an original front panel. The original has 4 countersink screw holes for attaching the PCB(s). Will your PCB have the mounting holes in the same location as the original PCB? Laughing Or is that wishful thinking on my part? If it doesn't, I'll have to concoct some sort of Rube Goldberg device to make it work. Smile
-John
phdinfunk
PostPosted: Fri Feb 18, 2011 10:22 am    Post subject: short run Reply with quote  Mark this post and the followings unread
Well, it looks like two things are going to happen with this....
1) I am going to make a pretty short run of these. It's going to cost me quite a pile of cash to get, say 25-30 of them made. I want four for myself to make a four voice synth.... that's pretty much going to be it.
2) They will overshoot initial estimates in cost because these are quite a bit more difficult to put together than you might guess. I thought at one point I'd be able to substitute 5c1 vactrols, but it really needs to use 5c3s, and of course there's nothing equivalent to the 5c3/2s either... also, we basically need to use some pretty specific transistors in this circuit to get close to the original design. . . . also, the parts count is just... well, if you have any idea what circuit we're cloning, just look at the number of ICs. Hell, look at the number of frigging resistors(!!). Plus we're fabbing 7.5"x4.25" PCBs to assemble all this on. Basically, there seems to be no way to keep this cost as low as I'd hoped.
So, this is essentially going to be a one-shot short run clone for the DIYers who absolutely want something special. I'm going to be very interested to see what people do with them, since they're absolutely made to not sit around in a toolbox somewhere, but to get up and running and rocking and rolling.
--Jonathan Pratt
www.phdinfunk.com
sduck
PostPosted: Fri Feb 18, 2011 10:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I still want one!
cbm
PostPosted: Fri Feb 18, 2011 12:11 pm    Post subject: Re: short run Reply with quote  Mark this post and the followings unread
If you could get that down to 6.5" x 4.25" it could fit behind one panel of a popular synth format.
Chris Muir
notimeforlove
PostPosted: Fri Feb 18, 2011 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm probably in for 1 or 2 depending on price, especially if you do just the PCB and we source parts and assemble.
toppobrillo
PostPosted: Fri Feb 18, 2011 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
hm.. i guess it fits the other way if you use a 2W panel?
why not just sell PCBs as well and let the builder source parts? I would get a couple boards.
the vactrols are def the $. it may be possible to organize a decent group buy from the factory to get better pricing. most all the other parts that come to mind [including assumed substitutions] atm are not a big deal. most smd resistors and smaller caps are less than a cent in bulk.
so, is your board layout finished? tested? if u made a bom, those interested in this could collaborate a bit on sourcing things.
inform3r
PostPosted: Fri Feb 18, 2011 2:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Jonathan, did you PM me? My PM isn't working right now for whatever reason. I got a notification saying I have a message but nothing shows up in my inbox. If you need to contact me use my email address listed on my profile. Sorry everybody for having to post this out here.
synthi
PostPosted: Fri Feb 18, 2011 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Still interested in one or two. Either PCB only or assembled!
Rolling Eyes
TekniK
PostPosted: Fri Feb 18, 2011 3:15 pm    Post subject: Re: short run Reply with quote  Mark this post and the followings unread
--Jonathan Pratt
www.phdinfunk.com
Drop future anouncements,made one working prototype ,when ready post extensive audio and video files,inform for yourself and announce price vs quantity,organise and collect pre-payment orders,let manufacture,sell
Moogah
PostPosted: Tue Feb 22, 2011 9:05 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm in for a pair of these, and I'm also with the group who would be just as happy to see PCB's instead of "finished" modules Smile
adambee7
PostPosted: Wed Feb 23, 2011 4:28 am    Post subject: Reply with quote  Mark this post and the followings unread
i'd like just the pcbs aswell. i dont mind soldering smd. done years of it at work. Very Happy Very Happy
djs
PostPosted: Wed Feb 23, 2011 7:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd be interested in a pcb.. not so much the fully built board...
RSFC
PostPosted: Wed Feb 23, 2011 9:49 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm interest too, dependent on the finalization of everything. It would be a shame to limit the project if you could just sell PCBs as well. You might consider something like PCBs with the SMT already done, the rest to be completed by the the DIYers...
toppobrillo
PostPosted: Wed Feb 23, 2011 8:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah really, PCB and all smd parts purchased in bulk and baked on at the factory would probably still come out to less than $40 ea in asia.
ericcoleridge
PostPosted: Wed Feb 23, 2011 8:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
From what I've been told, it seems that it would be difficult to have this manufactured in surface mount, considering all the special selection, calibrating,and trimming that must be done in order for it to work at all. I think that's what keeps it from being a practical DIY project, and why it's so difficult and expensive to produce at all.
If someone can figure it out, I'd definitely want one.
diablojoy
PostPosted: Wed Feb 23, 2011 10:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would also be interested in PCB only run 4 or maybe 6 voices
dont mind SMD at all
jonkull
PostPosted: Thu Feb 24, 2011 7:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would love one of these as well.
http://recoilsun.bandcamp.com/
mono-poly
PostPosted: Thu Feb 24, 2011 7:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm interested in some pcb's
amnesia
PostPosted: Thu Feb 24, 2011 7:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am interested in PCBs, parts and or faceplate completed or not if it looks and fits into Buchla boats Smile This has been a dream for me to play on a 259 Smile
