| Do we need a control signal monitor in the G2 editor |
| Yes, this is a must. |
90% |
[ 18 ] |
| Would be nice but I don't need it. |
10% |
[ 2 ] |
| Bad idea. Spend development time elsewhere. |
0% |
[ 0 ] |
| Total Votes : 20 |
statler
Joined: Feb 14, 2005 Posts: 6 Location: Brisbane, Australia
Posted: Tue Feb 15, 2005 8:28 pm Post subject:
Signal Monitor Module |
Like in Logic Audio, a simple window that displays the current signal value that can be stuck in the path at any point. I imagine there is a hidden module included for debugging that does something similar but it would be a very useful tool.
Similarly a graph module or application even so we can monitor signal over path and figure out what's going on with modulation on more complicated patches.
[editor's note: I added the poll queston -- mosc] _________________ www.statlerandwaldorf.com |
ik
Joined: Jan 30, 2005 Posts: 50 Location: North Carolina
G2 patch files: 25
Posted: Wed Feb 16, 2005 8:52 am Post subject:
| Quote: | | ... a simple window that displays the current signal value ... |
Yes, a must have ...
also, more involved ... but I'd love to see an 'oscilloscope' module for audio, ... not sure if it is possible since audio needs to be computed by the pc not by the G2 itself to have this ... Since the Demo does audio now, this, ... may be not too much to ask ...
ik. |
Joined: Jan 31, 2003 Posts: 18259 Location: Durham, NC
Audio files: 228
Posted: Wed Feb 16, 2005 10:10 am Post subject:
This has been discussed elsewhere. Seems like an essential tool to me. I could imagine a little volt meter or something. It would really make patching easier. _________________ --Howard
my music and other stuff |
Fozzie
Joined: Jun 04, 2004 Posts: 875 Location: Near Wageningen, the Netherlands
G2 patch files: 49
Posted: Wed Feb 16, 2005 2:25 pm Post subject:
| I agree too, but there are some issues here. Should the monitor device show peak values? Current values (these might change too quick to monitor / read)? Selectable? At intervals? |
Robby
G2 patch files: 6
Robby
G2 patch files: 6
Posted: Wed Feb 16, 2005 3:51 pm Post subject:
I agree that better visual monitoring would be nice ...
Something as simple (and presumably quick) to develop as a larger version of the level monitors they already have on some of the mixer modules would help a lot.
To make this work really well, it would be nice to display minimum & maximum signal levels hit within a certain amount of time. This would
let you determine if your audio has a DC offset or something.
There are ways to do this now, but they're a bit clunky. |
Audio files: 228
Posted: Wed Feb 16, 2005 4:31 pm Post subject:
The oscilloscope programs let you look at waveforms and do spectrum analysis, but this monitor module would be good for looking at control voltages when you are working out a patch. Sorta like a digital volt meter you can put in to see what's going on in the middle of a complex patch. _________________ --Howard
varice
Joined: Dec 29, 2004 Posts: 961 Location: Northeastern shore of Toledo Bend
Audio files: 29
G2 patch files: 54
Posted: Wed Feb 16, 2005 6:20 pm Post subject:
Yes - a control signal "voltmeter" module would be very handy. It should also display maybe three decimal points of precision (not just integer values -64 to +64 or 0 to 127). _________________ varice |
Posted: Wed Feb 16, 2005 6:41 pm Post subject:
If this is going to be there it´ll *need* a option to perform a rms operation on the signal with a intergral time and meter inertia based on standard v.u. meters. If at all possible I´d like it to be able to switch between three modes; "volt meter", "guitar tuner" (like the last one, except with a dynamic scale and output based on what the pitch would be if the signal in qeustion would be patched into a osc) and "rms". Clearly those modes would need to be able to output to the keyboard version´s lcd diplays too.
Perhas with another "meter"/"digits"
This is going to eat usb bandwith.
It might be worth it considdering that some set of utility patches might make a big difference for the social position a keyboard player would have within his band. Back in my band engineering days I would´ve loved to be able to read the tuning of two guitars and a bass from seperate lcd´s on the same machine....
Varice; It should display as many decimal points as the G2 uses itself if it displays any, I´m not obsessed with numbers but there is a huge difference between "1" and "rougly 1, could be a little more or less" _________________ Kassen |
varice
Audio files: 29
G2 patch files: 54
Posted: Thu Feb 17, 2005 8:34 pm Post subject:
Kassen,
Good point about the module's display precision. The G2 has 24 bit DSPs, so in theory there could be over 16 million different control levels between -64 to +64 units. That would make the minimum step value be about 0.00000757. In that case, the display would need to have at least 6 decimal places of resolution.
It appears that the G2 keyboard LCDs only display module parameter values with at most 1 decimal place of precision! Each display is currently split to display two different values. To implement a high resolution level module display on a G2 LCD, a special provision would need to be programmed to allow this one module to take the full 16 digit dot matrix display available.
An additional feature for this module - max and min value captures - with manual reset. _________________ varice |
Posted: Thu Feb 17, 2005 11:12 pm Post subject:
It seems like this has become two requests: 1 for an editor based monitor, a 2nd for a LCD (on the G2) based monitor (not good for you engine owners).
But, if there was a USB-editor based monitor, couldn't we just get a VST plug-in instead? There's lots of VU, oscope, bit-width, spectral display, and waterfall chart monitors/analyzers in VST form. Just chain whatever analysis engine you want, and you're golden. |
Posted: Sat Feb 19, 2005 4:05 pm Post subject:
| jksuperstar wrote: | | But, if there was a USB-editor based monitor, couldn't we just get a VST plug-in instead? There's lots of VU, oscope, bit-width, spectral display, and waterfall chart monitors/analyzers in VST form. Just chain whatever analysis engine you want, and you're golden. |
Well, no. analysis plugins are a great development and I actually hooked up a second monitor for my laptop especially for those but they won´t help here, at least not everywhere. The main request seems to be for a simple volt meter style thingy that will basically be measuring dc offset or lfo-range signals. Sadly those won´t get thorugh the dac´s because the dac´s duie to their internal workings try and remove dc offset. Also; one of the prime uses of this would be sorting out "1" (or unity gain) from "slightly more then 1" or "slightly less then 1" in which we simply can´t afford rounding errors or outside influences like soundcard gains.
The values we want to "see" only exist within the G2 and while their effect can get out the values themselves are stuck inside the box. I´m not sure how this works ont he demo version which does not have the hardware dac´s and who´s output could conceivably be read within the digital domain.
I would say that it´d be best to have both these sugestions and the analysis plugins we already have (often for free) in the vst format since they serve different purposes. _________________ Kassen |
Posted: Sat Feb 19, 2005 11:05 pm Post subject:
| Quote: | | The values we want to "see" only exist within the G2 and while their effect can get out the values themselves are stuck inside the box |
I mean for the G2 to have a VST instrument of itself, connected via USB. This would bring audio I/O, Busses, and/or FX signals into the PC via USB without any DACs or ADCs involved. Of course, I didn't mention the MIDI i/o yet either, or the MIDI between patches.... |
Posted: Sun Feb 20, 2005 1:45 am Post subject:
That´d be nice but that won´t fit, bandwith-wise. _________________ Kassen |
Audio files: 228
Posted: Sun Feb 20, 2005 1:04 pm Post subject:
It's a good idea, but not for the G2. It would take USB2 or Firewire which the G2 doens't have. _________________ --Howard
Posted: Sun Feb 20, 2005 11:42 pm Post subject:
| As I've said before, I would honestly settle for just MIDI over that USB interface. Then I could take the G2 & laptop out for jams, using something like Ableton Live along side the G2 (while using the G2 for sounds & as a controller), without any other gear. That'd be tight, and tight is nice. |
Rob
Joined: Mar 29, 2004 Posts: 580 Location: The Hague/Netherlands/EC
G2 patch files: 109
Posted: Sat Feb 26, 2005 1:25 pm Post subject:
| varice wrote: | | The G2 has 24 bit DSPs, so in theory there could be over 16 million different control levels between -64 to +64 units. That would make the minimum step value be about 0.00000757 |
Just a slight correction for the record: 16 million values between (almost)+256 and -256 units. Almost +256 as the actual +256 units folds back to -256 in two's complement arithmetic. |
rhombus
Posted: Thu Mar 17, 2005 5:29 am Post subject:
| Perhaps there could be an option to set the compiler to ignore the signal monitor module when storing to the G2. That way it could be used for debugging your patch during design time, it would only be active in the editor. Since the editor gets values from an attached G2, it could maybe hook into that data stream so you're using your CPU to do all the monitoring. |
Axiom
G2 patch files: 28
Posted: Sat Apr 09, 2005 12:17 pm Post subject:
well, as I've said in my previous thread, can be very handy an oscilloscope and an FFT analyzer.. I use them on SynthEdit for every patch I make and are a MUST if you are working on acoustic emulations.
Luca _________________
