Joined: Apr 03, 2004 Posts: 24676 Location: The Netherlands, Enschede
Posted: Fri Jun 24, 2011 5:14 pm Post subject:
Re: Push.Pull Spectrum Subject description: PLL Pedal |
| coloring pad wrote: | | ... hope you like it! |
Oh, I like how it looks! Will need to listen later though. _________________ Jan
tjookum
Joined: May 25, 2010 Posts: 360 Location: Netherlands
Audio files: 26
Posted: Sat Jun 25, 2011 3:21 am Post subject:
coloring pad, that thing looks just perfect. I really like how the sound fits the design and I know from experience that stripping a PCB and mounting it like that can be a lot of work.
The actual function of the machine isn't really clear to me though and I can't make it out in the video, do you have a schematic? _________________ There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die.
Hunter S. Thompson
movies
noise |
coloring pad
Joined: Nov 13, 2009 Posts: 17 Location: newer jersey
Posted: Sat Jun 25, 2011 6:31 am Post subject:
| tjookum wrote: | coloring pad, that thing looks just perfect. I really like how the sound fits the design and I know from experience that stripping a PCB and mounting it like that can be a lot of work.
The actual function of the machine isn't really clear to me though and I can't make it out in the video, do you have a schematic? |
Thank you!
I did this on perfboard. It barely fits, and there are about 60 wires coming out of it to the knobs & joysticks & such. No official schematic, but basically, the signal path goes:
Preamp>PLL (with six oscillators that intertwine in the circuitry)>Octave divider>Filter
Basically, it recognizes the audio and turns it into a telephone type synthesized signal, sputters and pulses because of the oscillators and various voltage starves/capacitor values, gets divided to a lower octave to add thickness, and then gets filtered through the photoresistors that are lined up with the three LEDs that are in the light.
I have no idea how to make a PCB (yet) and have little understanding of formal electronics. _________________ www.coloringpad.org |
Strazdas
Joined: Apr 21, 2010 Posts: 42 Location: Kaunas, Lithuania
Posted: Sun Jun 26, 2011 1:25 pm Post subject:
This is Polivoks VCF.
Schematic from http://m.bareille.free.fr/modular1/vcf_polivoks/vcf_polivoks.htm but with original russian op-amps (these are golden ones, really!!! and I'm still hold few of them, many went for gold recycling a time ago) and transistor which is not critical but they are very cheap nowadays (10 times as wester replacement) and I have bunch of them from old times. Green capacitors also russian 1uF and very large! It's very easy to build.
Added trimpot for "Frequency" adjust.
The filter sounds really good and dirty when Q knob turned half way and wild when turned on fully.
I didn't decide yet what knobs to use, so it stays as it is for now.
| Description: |
| Filesize: |
194.1 KB |
| Viewed: |
428 Time(s) |
| Description: |
| Filesize: |
169.43 KB |
| Viewed: |
420 Time(s) |
_________________ -none- |
bf
Posted: Mon Jun 27, 2011 8:49 pm Post subject:
First of a series of CGS panels of zthee's design.
Thank you again zthee for your inspiring designs, and you help along the way. |
diablojoy
Joined: Sep 07, 2008 Posts: 809 Location: melbourne australia
Posted: Tue Jun 28, 2011 2:52 pm Post subject:
very nice incredibly neat and compact build bf |
delayed
Posted: Tue Jun 28, 2011 7:01 pm Post subject:
A+ work on the keyboard!
And I second the fine wiring for the compact box.
Great jobs. |
ericcoleridge
Posted: Tue Jun 28, 2011 7:32 pm Post subject:
| bf wrote: | First of a series of CGS panels of zthee's design.
How do you go about making the "cradle"? Looks like a frame, made from L-brackets, yes? Where does one find this size L-bracket?
Beautiful job, very well don. |
Joined: Mar 28, 2006 Posts: 1472 Location: Kansas City, Mo USA
Posted: Wed Jun 29, 2011 1:33 pm Post subject:
| ericcoleridge wrote: | Looks like a frame, made from L-brackets, yes? Where does one find this size L-bracket?
Indeed, it is a wonderful job.
The aluminum L brackets are pretty standard -- I purchase them at Lowe's.
For the PCBs, he is using nylon spacers and attached them with wire ties. The panel is really neat and the whole project is very compact, indeed! _________________ -- Kevin
http://kevinkissinger.com |
The Peasant
Joined: Nov 13, 2009 Posts: 114 Location: Sunny Alberta
Posted: Wed Jun 29, 2011 1:40 pm Post subject:
Beautiful job!
Take care,
Doug _________________ The Electronic Peasant
www.electronicpeasant.com |
bf
Posted: Wed Jun 29, 2011 7:21 pm Post subject:
| ericcoleridge wrote: | How do you go about making the "cradle"? Looks like a frame, made from L-brackets, yes? Where does one find this size L-bracket?
Thank you for all of the compliments. If anything this project has only motivated me to build more.
Yes, I just used two pieces of aluminum angle I picked up from Lowe's, drilled at the spacing of the PCB's holes and secured them with zip ties, save for the distro board which has tapped holes to allow me to adjust its height. Without the PCBs attached, the "cradle" rails are not mechanical attached to each other save through the standoffs screwed to the panel. I have seen frames or cradles where the two ends are attached via cross-members, but everything felt secure enough without being overly rigid done this way.
adambee7
Joined: Apr 04, 2009 Posts: 420 Location: united kingdom
Posted: Mon Jul 04, 2011 1:31 pm Post subject:
awesome BF  |
Dan Lavin
Audio files: 21
Posted: Wed Jul 06, 2011 6:16 pm Post subject:
Just finished my rack-mount version of the deMIDulator, 8 bit digital synth and lo-fi sampler. You can read about it here:
http://derekenos.com/dIndex.html
I hardwired the audio line in to a 1/4" mono jack on the front panel. Right now, I have a mellotron string sample in the sample waveform location. I probably won't change samples too often.
| Description: |
| Filesize: |
1.55 MB |
| Viewed: |
3113 Time(s) |
| Description: |
| Filesize: |
1.56 MB |
| Viewed: |
3155 Time(s) |
_________________ Synth DIY since 1977! |
coloring pad
Posted: Wed Jul 06, 2011 6:24 pm Post subject:
| Strazdas wrote: | This is Polivoks VCF.
I didn't decide yet what knobs to use, so it stays as it is for now. |
I believe I heard this filter before online and spent a lot of time looking for it... if i remember correctly it sounds amazing. I wanted to build a pedal with this filter but I am not well versed in schematics and obscure Soviet parts despite what my work looks or sound like: more of a breadboard person. How much do I have to bribe you to talk to me about this filter and how to make it with my limited knowledge, or talk you into producing a few of these? PM me or email me... sound samples soon? I think this is what I've been looking for. _________________ www.coloringpad.org |
ericcoleridge
Posted: Thu Jul 07, 2011 2:13 pm Post subject:
recent builds
| Description: |
| Filesize: |
1.38 MB |
| Viewed: |
3159 Time(s) |
| Description: |
| Filesize: |
1.15 MB |
| Viewed: |
3180 Time(s) |
inlifeindeath
Joined: Apr 02, 2010 Posts: 316 Location: Albuquerque, NM
AnalogCustom
Posted: Fri Jul 08, 2011 12:40 pm Post subject:
Simple Keyboard Controller and KB Controller panel.
Marco. |
ericcoleridge
Posted: Sat Jul 09, 2011 12:22 pm Post subject:
| AnalogCustom wrote: | Simple Keyboard Controller and KB Controller panel.
Marco, where did u get the keyboard itself? It looks great. |
AnalogCustom
Posted: Sat Jul 09, 2011 1:47 pm Post subject:
| ericcoleridge wrote: | | AnalogCustom wrote: | Simple Keyboard Controller and KB Controller panel.
Hello
I do not understand the question. The keyboard was of a Korg Polysix, did not work. That was your question?
Regards
Marco. |
LFLab
Joined: Dec 17, 2009 Posts: 497 Location: Rosmalen, Netherlands
Posted: Sun Jul 10, 2011 2:14 pm Post subject:
I think he was referring to the touch keyboard in the Buchla-esque case, interested in this myself too!
Nice work on your controller as well, Marco. |
Celtic Peasant
Posted: Sun Jul 10, 2011 10:46 pm Post subject:
| ericcoleridge wrote: | | recent builds |
Eric that is a thing of beauty!! Awesome job!
Take care,
Zoie _________________ www.celticpeasant.com |
Celtic Peasant
Posted: Sun Jul 10, 2011 10:48 pm Post subject:
| AnalogCustom wrote: | | Simple Keyboard Controller and KB Controller panel. Marco. |
What a beautiful keyboard Marco. Beautiful work.
Take care,
LFLab
Posted: Tue Jul 12, 2011 12:14 pm Post subject:
| Gruendlich und Klar, Matthias, not boring! They look great, I really should get my *ss in gear and finish stuff as well! |
shawn
Posted: Tue Jul 12, 2011 1:09 pm Post subject:
Your folding case looks great and I forgot to pm you my touch keyboard info! I'll do that tonight! |
