2011 Build Pictures
Page 11 of 19 [453 Posts]
Goto page: Previous 1, 2, 3, ..., 9, 10, 11, 12, 13, ..., 17, 18, 19 Next
Audio files: 308
PostPosted: Fri Jun 24, 2011 5:14 pm    Post subject: Re: Push.Pull Spectrum
Subject description: PLL Pedal
coloring pad wrote:
... hope you like it!
Oh, I like how it looks! Will need to listen later though.
tjookum
Audio files: 26
PostPosted: Sat Jun 25, 2011 3:21 am    Post subject: Reply with quote  Mark this post and the followings unread
coloring pad, that thing looks just perfect. I really like how the sound fits the design and I know from experience that stripping a PCB and mounting it like that can be a lot of work.
The actual function of the machine isn't really clear to me though and I can't make it out in the video, do you have a schematic?
Hunter S. Thompson
movies
noise
coloring pad
PostPosted: Sat Jun 25, 2011 6:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you!
I did this on perfboard. It barely fits, and there are about 60 wires coming out of it to the knobs & joysticks & such. No official schematic, but basically, the signal path goes:
Preamp>PLL (with six oscillators that intertwine in the circuitry)>Octave divider>Filter
Basically, it recognizes the audio and turns it into a telephone type synthesized signal, sputters and pulses because of the oscillators and various voltage starves/capacitor values, gets divided to a lower octave to add thickness, and then gets filtered through the photoresistors that are lined up with the three LEDs that are in the light.
I have no idea how to make a PCB (yet) and have little understanding of formal electronics.
www.coloringpad.org
Strazdas
PostPosted: Sun Jun 26, 2011 1:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is Polivoks VCF.
Schematic from http://m.bareille.free.fr/modular1/vcf_polivoks/vcf_polivoks.htm but with original russian op-amps (these are golden ones, really!!! and I'm still hold few of them, many went for gold recycling a time ago) and transistor which is not critical but they are very cheap nowadays (10 times as wester replacement) and I have bunch of them from old times. Green capacitors also russian 1uF and very large! Smile It's very easy to build.
Added trimpot for "Frequency" adjust.
The filter sounds really good and dirty when Q knob turned half way and wild when turned on fully.
I didn't decide yet what knobs to use, so it stays as it is for now.
Polivoks VCF pcb.
 Filesize:  194.1 KB
 Viewed:  409 Time(s)
Polivoks VCF
 Filesize:  169.43 KB
 Viewed:  393 Time(s)
-none-
bf
PostPosted: Mon Jun 27, 2011 8:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
First of a series of CGS panels of zthee's design.
Thank you again zthee for your inspiring designs, and you help along the way.
diablojoy
PostPosted: Tue Jun 28, 2011 2:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
very nice Cool incredibly neat and compact build bf
delayed
PostPosted: Tue Jun 28, 2011 7:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
A+ work on the keyboard!
And I second the fine wiring for the compact box.
Great jobs.
ericcoleridge
PostPosted: Tue Jun 28, 2011 7:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
How do you go about making the "cradle"? Looks like a frame, made from L-brackets, yes? Where does one find this size L-bracket?
Beautiful job, very well don.
PostPosted: Wed Jun 29, 2011 1:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Indeed, it is a wonderful job.
The aluminum L brackets are pretty standard -- I purchase them at Lowe's.
For the PCBs, he is using nylon spacers and attached them with wire ties. The panel is really neat and the whole project is very compact, indeed!
The Peasant
PostPosted: Wed Jun 29, 2011 1:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Beautiful job!
Take care,
Doug
The Electronic Peasant
www.electronicpeasant.com
bf
PostPosted: Wed Jun 29, 2011 7:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for all of the compliments. If anything this project has only motivated me to build more.
Yes, I just used two pieces of aluminum angle I picked up from Lowe's, drilled at the spacing of the PCB's holes and secured them with zip ties, save for the distro board which has tapped holes to allow me to adjust its height. Without the PCBs attached, the "cradle" rails are not mechanical attached to each other save through the standoffs screwed to the panel. I have seen frames or cradles where the two ends are attached via cross-members, but everything felt secure enough without being overly rigid done this way.
adambee7
PostPosted: Mon Jul 04, 2011 1:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
awesome BF Very Happy Very Happy
Dan Lavin
Audio files: 21
PostPosted: Wed Jul 06, 2011 6:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just finished my rack-mount version of the deMIDulator, 8 bit digital synth and lo-fi sampler. You can read about it here:
http://derekenos.com/dIndex.html
I hardwired the audio line in to a 1/4" mono jack on the front panel. Right now, I have a mellotron string sample in the sample waveform location. I probably won't change samples too often.
 Filesize:  1.55 MB
 Viewed:  3089 Time(s)
 Filesize:  1.56 MB
 Viewed:  3136 Time(s)
Synth DIY since 1977!
coloring pad
PostPosted: Wed Jul 06, 2011 6:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
I believe I heard this filter before online and spent a lot of time looking for it... if i remember correctly it sounds amazing. I wanted to build a pedal with this filter but I am not well versed in schematics and obscure Soviet parts despite what my work looks or sound like: more of a breadboard person. How much do I have to bribe you to talk to me about this filter and how to make it with my limited knowledge, or talk you into producing a few of these? PM me or email me... sound samples soon? I think this is what I've been looking for.
www.coloringpad.org
ericcoleridge
PostPosted: Thu Jul 07, 2011 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
recent builds
 Filesize:  1.38 MB
 Viewed:  3134 Time(s)
 Filesize:  1.15 MB
 Viewed:  3151 Time(s)
inlifeindeath
PostPosted: Thu Jul 07, 2011 3:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
beautiful eric! i take it you had success cloning the keyboard then? care to share?
AnalogCustom
PostPosted: Fri Jul 08, 2011 12:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Simple Keyboard Controller and KB Controller panel.
Marco.
ericcoleridge
PostPosted: Sat Jul 09, 2011 12:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Marco, where did u get the keyboard itself? It looks great.
AnalogCustom
New postPosted: Sat Jul 09, 2011 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello
I do not understand the question. The keyboard was of a Korg Polysix, did not work. That was your question?
Regards
Marco.
LFLab
New postPosted: Sun Jul 10, 2011 2:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think he was referring to the touch keyboard in the Buchla-esque case, interested in this myself too!
Nice work on your controller as well, Marco.
Celtic Peasant
New postPosted: Sun Jul 10, 2011 10:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
recent builds
Eric that is a thing of beauty!! Awesome job! thumright
Take care,
Zoie
www.celticpeasant.com
Celtic Peasant
New postPosted: Sun Jul 10, 2011 10:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
AnalogCustom wrote:
Simple Keyboard Controller and KB Controller panel. Marco.
What a beautiful keyboard Marco. Beautiful work.
Take care,
Zoie
New postPosted: Mon Jul 11, 2011 2:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
your buchla and serge style synths are awesome! i am jeleaous!
here are the two modules i finished tonight (boring german style):
Comparator
and Dual WoggleBug
LFLab
New postPosted: Tue Jul 12, 2011 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Gruendlich und Klar, Matthias, not boring! They look great, I really should get my *ss in gear and finish stuff as well!
shawn
New postPosted: Tue Jul 12, 2011 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Your folding case looks great and I forgot to pm you my touch keyboard info! I'll do that tonight!
