TH Design Downloads
Page 1 of 2 [28 Posts]
fluxmonkey
PostPosted: Sat May 05, 2007 9:39 am    Post subject:  TH Design Downloads
Subject description: Thomas Henry Design and Publication Resource Links
as mentioned in other threads, Nuts & Volts Magazine apparently owns rights to TH articles published there... some of that stuff is available from them, here are some links:
arrow most links below are dead - you may have to search - but also read on in the posts below arrow
Rack Panels: http://www.nutsvolts.com/~downloads/December%201998%20Thomas%20Henry%20-%20Secrets%20of%20Making%20Attractive%20Rack%20Panels.pdf
MIDI-CV interface: http://www.nutsvolts.com/~downloads/December%201997%20Thomas%20Henry%20-%20Build%20Your%20Own%20MIDI-to-Synthesizer%20Interface.pdf
Tunable Noise Generator: http://www.nutsvolts.com/~downloads/November%201999%20Thomas%20Henry%20-%20Build%20a%20Tunable%20Noise%20Generator.pdf
Power Supply: http://www.nutsvolts.com/~downloads/January%201998%20Thomas%20Henry%20-%20Power%20Supplies%20for%20Electronic%20Music.pdf
Clangora PCB/Parts Placement: http://downloads.nutsvolts.com/Clangora.zip
Analog-related design spreadsheets: http://www.nutsvolts.com/%7Edownloads/Design%20Sheets.zip
=====More Thomas Henry Links=====
UD-1 Drum Voice Info: http://mypeoplepc.com/members/scottnoanh/birthofasynth/id23.html
sMs Electronics UD-1 PCB/Kit: No link yet.
XR VCO Info: http://mypeoplepc.com/members/scottnoanh/birthofasynth/id20.html
BugBrand XR VCO PCB Layout: http://bugbrand.co.uk/pages/electronics.htm
SN-Voice Info: http://mypeoplepc.com/members/scottnoanh/birthofasynth/id22.html
sMs Electronics SN-Voice PCB/Kit: No link yet.
Magic Smoke Electronics TH-201 Mankato Filter: http://www.magsmoke.com/synthmodules.asp
Magic Smoke Thomas Henry Books:
Electronic Drum Cookbook
Making Music With the 566
Coming soon - "An Analog Synthesizer for the 21st Century"
http://www.magsmoke.com/magsmoke.asp
Edit: This thread was originally started by Bbob to point people to some Thomas Henry designs posted by Nuts and Volts magazine. I've renamed the thread to make it more general. Thanks to Bbob for starting this thread, which I've turned into a permanent sticky. I'm going to post other links in addition to Bbob's original Nuts and Volts links, so that everything will be in one post at the top of the thread. As more links are added to this thread, I'll copy them here in the first post for easy access. - Scott Stites
arrow Edit by Blue Hell : most links are dead here, the domain ones may still work, the waybackmachine may have some info stored.
PostPosted: Sat May 05, 2007 9:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice one bbob!
Scott, Bill, do you want to make this one a sticky?
ACHTUNG!
Scott Stites
Audio files: 96
PostPosted: Sat May 05, 2007 11:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah - thanks for that Bbob!
I think it would make a nice sticky. How 'bout you, Bill?
Scott
PostPosted: Mon May 07, 2007 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, sure. Make it stick. Thanks bbob !!
Q: Can we add to the "sticky" (Leave it editable) so that if there are more important TH hardware links, members can just go to this one single sticky post??
We could add Scott's links also that has anything relating to Thomas henry projects. Question
Bill
Tronato
PostPosted: Fri Nov 09, 2007 10:32 am    Post subject:   Reply with quote  Mark this post and the followings unread
Hello!
Where's the power supply link? It is broken!
TRO
shawn
PostPosted: Sat Nov 10, 2007 11:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Use this url, all the stuff Thomas Henry related on nuts and volts are here:
http://www.nutsvolts.com/downloads.php
Tronato
PostPosted: Sun Nov 11, 2007 9:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello!
Shawn: Thank you very much! The article is the real deal! Just what I was looking for!
Thanks again!
TRO
slo
PostPosted: Wed Nov 21, 2007 8:46 am    Post subject:
Subject description: 21st Century ADSR
Here's the pcb for an early version of the Thomas Henry ADSR. With the addtion of 2 diodes in the trigger and gate sections you can bring it up to full 21st century spec. Thanks go to Thomas (of course) and to Tim Servo for permision to post and modifing the image slightly.
George
pcbadsr_115_update_139.pdf
PCB image for ADSR
 Filename:  pcbadsr_115_update_139.pdf
 Filesize:  51.24 KB
 Downloaded:  2142 Time(s)
Sound
PostPosted: Sun Sep 28, 2008 3:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Updated links from Nuts and Volts:
Build Your Own Midi to Synthesizer Interface
Secrets Making Attractive Rack Panels
Power Supplies For Electronic Music
Build a Tunable Noise Generator
The Forgotten Analog Design Tool
O
Sound
PostPosted: Sun Sep 28, 2008 3:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can found the Clangora here:
http://electro-music.com/forum/topic-19835.html
camelneck
PostPosted: Wed Dec 31, 2008 3:48 am    Post subject: Reply with quote  Mark this post and the followings unread
>>Here's the pcb for an early version of the Thomas Henry ADSR. With the addtion of 2 diodes in the trigger and gate sections you can bring it up to full 21st century spec.<<
slo,
Thanks for the pcb layout. Do you know where can one find a schematic and possibly more information on this ADSR?
Thanks.
slo
PostPosted: Thu Jan 01, 2009 6:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Schematic is only available in the book " An Analog Synth for the 21st Century" available @ Magic Smoke.
Great book of up to date schematics for a killer synth. Some boards available for it too.
George
Tim Servo
PostPosted: Fri Jan 02, 2009 5:22 pm    Post subject: TH Design Downloads Reply with quote  Mark this post and the followings unread
Hey Guys,
Thanks for the mention of AS21C. I've built most of the circuits in there, and I'm really happy with them. And yes, more AS21C PCBs are in the works. All of our Thomas Henry books can be found here:
http://stores.lulu.com/magic_smoke
Cheers and Happy 2009 to all!
Tim (still writing "Year of the Goat" on my checks) Servo
Dougster
PostPosted: Wed Sep 21, 2011 6:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was just trying to find the books on Lulu. Looks like this is the current link:
http://www.lulu.com/spotlight/magsmoke
EDIT: Updated link
Regards,
Doug
Once you start down the modular path, forever will it dominate your destiny!
Every DIY person should own a copy of Electronotes: http://electronotes.netfirms.com
Blue LEDs are evil.
inlifeindeath
PostPosted: Thu Sep 22, 2011 11:27 am    Post subject: Reply with quote  Mark this post and the followings unread
I just got two TH books from Lulu and they are great. There's a sale going on now too.
marvkaye
PostPosted: Thu Sep 22, 2011 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sale??? What sale??? Did I miss something somewhere? I just bought the AS21C downloadable book, didn't see any mention of a sale. Actually I think it's my computer... it filters stuff like that out just to spite me.
<marv>
inlifeindeath
PostPosted: Thu Sep 22, 2011 2:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
only on through tomorrow, promo code: OKTOBERFEST305
Max savings of $200.
Tim Servo
PostPosted: Fri Sep 23, 2011 9:52 am    Post subject: TH Design Downloads Reply with quote  Mark this post and the followings unread
Hey Guys and Gals,
Yes, Lulu just recently changed the "Storefront Page" addresses, but the old address should still work. The old address will just redirect you to the new one:
www.lulu.com/magsmoke
http://www.lulu.com/spotlight/Magic_Smoke
As far as the discounts, Lulu will have a site-wide discount at random times once or maybe twice a year. I announce these on the Magic Smoke Facebook page, and I don't always get around to posting them here, but I try. "Like" the FB page and you'll get those announcments sooner. I usually post 'freebie' schematics like the LFX there too, although I also try to post them here on E-M.
Tim (Like like or LIKE like?) Servo
Tim Servo
PostPosted: Fri Sep 23, 2011 2:28 pm    Post subject: TH Design Downloads Reply with quote  Mark this post and the followings unread
Hi All,
Just found out that Lulu has extended their site-wide sale (15% off) until midnight September 26th, so you've got a few more days to save a few bucks on Thomas Henry books. Also, Lulu.com has a lot of other interesting self-published books, so check it out while you're there. Smile
Use the code OKTOBERFEST305 at check-out to get your discount.
Tim (what a bargain) Servo
dark000arena
PostPosted: Fri Jan 20, 2012 1:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Bernie Hutchins has generously uploaded Thomas' Precision Controller Clock. Get it here:-
http://electronotes.netfirms.com/ENEHenry150.PDF
http://electronotes.netfirms.com/ENEHenry300.PDF
The 300 DPI version is correct for layout etching. The clock requires a CEM3340 but you can always raid your mates boring old polysynth for one ... or five. serves him right for not being exclusively modular afterall.
acidblue
PostPosted: Fri May 24, 2013 1:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
A lot of the above links are dead.
Could we get an update?
Tim Servo
PostPosted: Fri May 24, 2013 1:59 pm    Post subject: TH Design Downloads Reply with quote  Mark this post and the followings unread
If nothing else, here's an update for the the books published by Magic Smoke (available through our print to order service at Lulu.com)
The links to the Electronotes / Thomas Henry Super Controller seem to work okay for me. It is worth noting that the divide-down circuitry and start/stop controls will work with other oscillators and VCOs. You don't necessarily need to sacrifice an expensive CEM 3340 for the task.
Tim (Sir Linksalot) Servo
acidblue
PostPosted: Fri May 24, 2013 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
The ones linking to 'Nuts and Volts' mag are the ones in the very first post I was refering to.
Sorry I should of been a bit more clear.
Tim Servo
PostPosted: Fri May 24, 2013 3:14 pm    Post subject: TH Design Downloads Reply with quote  Mark this post and the followings unread
Ah, got it. Yes, the links at the top of the page don't work. However, the updated links a few posts further down all work except for the "Forgotten Analog Design Tool" link. That one is about using spreadsheets, in case you were wondering. I don't have that article, but I've seen that Thomas has mentioned it before.
Tim (The Missing Link) Servo
acidblue
PostPosted: Fri May 24, 2013 3:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
OIC, thanks.
It would've been nice to have the "Forgotten Analog Design Tool" .
