 Forum index » Instruments and Equipment » DSI Synths
White Noise through Amp Env
Page 1 of 1 [2 Posts]
Markel
PostPosted: Wed Sep 14, 2011 6:04 am    Post subject: White Noise through Amp Env Reply with quote  Mark this post and the followings unread
Dear all
I d like use my Mono Evoler to process extrenall sound. I want to add the white noise of the evolver to the external sound. So if I play a note from an external synth going into evolver, I d like to add a bit of white noise from the evolver. The AMP of the white noise of the Evolver must be controlled from the VCA ADSR Env, but the VCA Envolpe must shape only the white noise of the evolver and not the external source. So VCA level (baseline) of the Evolver must be set to zero.
Does anyone have an idea how to achieve this?
Thanks and regards
stiiiiiiive
G2 patch files: 4
PostPosted: Wed Oct 12, 2011 3:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't have any Evolver at hand but here are my thoughs.
I guess you have to use another envelope and ensure MIDI is connected so that that envelope is triggered only on notes. This way, your VCA can be open without throwing the noise all the time.
Or… you may use the envelope follower to drive the noise level. No need for MIDI this way.
Folie à 6
Lawx and Mowk
