drumfish
Joined: Feb 01, 2010 Posts: 30 Location: savoie france
Posted: Thu Dec 01, 2011 2:42 pm Post subject:
Ah, right - now I do understand the question ... not enough tracks available ...
Hmm .. should not be too hard ... as there is a PC send and a CtrlSend you can chain these modules from the send output to the send input of the next one - this determines the order in which the messages will be sent - when the first one is done the second one in the chain will start.
When you want remote control for what PC and banks select they send you'll need morphs on the Value knob and the Program knob. Then assign a CC value to the morph knobs ...
To trigger when things get sent you probably want to use CtrlRcv module.
Does this help? _________________ Jan
drumfish
Posted: Thu Dec 01, 2011 4:56 pm Post subject:
| thanks a lot ... i've been trying these midi module for few days ... the problem is that i'm stuck every time i try to send midi datas from any slot to the global channel ... weird ... the global channel is active & i have no problem to send a data to any of the 4 slots ... i just have to find the good way to chain the midi modules now you pointed the midi modules as well ... i shure miss a way to connect them properly ... so i go back to the editor & i keep in touch as soon as i sort it out ... thanks to you & electromusic to share such a huge database. |
Posted: Thu Dec 01, 2011 5:56 pm Post subject:
| drumfish wrote: | | the problem is that i'm stuck every time i try to send midi datas from any slot to the global channel |
Right ... starting to understand the problem better now ... maybe
It is not possible I think to make a patch that changes itself for another one ... I've needed a 2nd G2 to do stuff like that.
Maybe performance mode is not a good idea then ... in patch mode I think you could send program changes and bank selects to the channel associated with the individual patch.
Is that a better idea? _________________ Jan
Posted: Thu Dec 01, 2011 6:01 pm Post subject:
Hmm .. or maybe it is .. with a MIDI merger and a G2 sending MIDI to itself via the hardware/external MIDI connectors .. never tried that  _________________ Jan
Roland Kuit
Joined: Sep 29, 2003 Posts: 1090 Location: The Netherlands/Sweden
G2 patch files: 127
Posted: Fri Dec 02, 2011 1:28 am Post subject:
Or maybe with a program like Midi-ox?
Still miss your Midi Mod Jan  |
drumfish
Posted: Fri Dec 02, 2011 7:40 am Post subject:
thanks guys for your help,
so ... everything works on all slots (in a midi module / scroll down menu / channel this & slots A to D works in perf mode) but apparently you can't send any data to a "numerous" midi channel without plugin a midi cable. The midi merger is quite a good idea as i'm kind of familiar with weird midi chaining. The prg change works in patch mode but the bank change doesn't / only in perf mode.
& if i stay in patch mode i'm stuck with only 128 patches when the perf mode loads any patches from any of the 32 banks that's why i'm trying to sort out this perf mode.
i'll try the midi merger or i'll drive a synth from the machinedrum ( no arpegiator ) thru the monomachine to get an extra midi track for the global channel.
@sono-logica A.K.A "the tutorial" midi ox seams to be a good little soft but i work hmmm i try to play my machines with no laptop ... only hardwares.
anyway, thanks for all guys & we all look forward the 2nd version of an already great tutorial ... don't we ? |
Roland Kuit
G2 patch files: 127
drumfish
Posted: Sat Dec 03, 2011 10:28 am Post subject:
thanks for midi patchbay
i don't know how i could use it with my stuff but i'll try
& that's all about getting the music out of my head  |
Roland Kuit
G2 patch files: 127
Posted: Sat Dec 03, 2011 12:06 pm Post subject:
| You can send pch data etc to your computer and you can figure out what data it is for program changes(I think). You can see all kinds of midi data. Jan is the expert here:) |
drumfish
Posted: Sat Dec 03, 2011 6:23 pm Post subject:
i bothered jan enough & thanks to you roland ... poped-in-time for help ... keep twiddling & sharing your knowledge ...
culture is free so why not sharing  |
drumfish
Posted: Sat Dec 03, 2011 6:48 pm Post subject:
| drumfish wrote: | | i bothered jan enough |
I started to like it
Just post, feel free, there are plenty of people here to respond, there are no silly questions, we were all born with empty memories. _________________ Jan
drumfish
Posted: Sun Dec 04, 2011 7:31 am Post subject:
| true |
dasz
Joined: Oct 16, 2004 Posts: 1644 Location: victoria, canada
Audio files: 29
G2 patch files: 56
Posted: Sun Dec 04, 2011 9:12 am Post subject:
| Blue Hell wrote: | Hmm .. or maybe it is .. with a MIDI merger and a G2 sending MIDI to itself via the hardware/external MIDI connectors .. never tried that  |
that is a very flexible solution, the (midi merger and splitter) patchbay approach makes anything control anything else ... for example you md could control the blofeld or novation, with it's cool MIDI machines) in addition the the monomachine or the G2. Make sure you only have one midi clock and nothing sends/echos midi clock but that one source.
I personally use a MIDI solutions Quarda Merge going into a Quad Thru from Midi solutions.. I leave MIDI local off in the G2. In my setup I have 2 G2's, Octatrack and iPad (MIdiTouch) merging and splitting to xoxbox, Blofeld, Dark energy, 2880 looper and the G2's OT and iPad. |
dasz
Audio files: 29
G2 patch files: 56
Posted: Sun Dec 04, 2011 9:21 am Post subject:
the thing I'm trying to set up at the moment is a G2 based MIDI filter and MIDI message augmenter/builder, which listens to Note and CC data coming from the OT and changing it before it gets to other gear ....
the only good way I can do it is to use a few spare MIDI channels,
1. have the OT send midi to multiple slots in the G2 (so this way I can recieve all notes on one channel, I always miss not having the Keyboardin module with selectable MIDI channel)
2. the G2 transforms the MIDI data (for example lengthens notes, transposes them, changes velocity, generates new notes) output to the midi channels for the other gear |
cappy2112
Joined: Dec 24, 2004 Posts: 2508 Location: San Jose, California
Posted: Sun Dec 04, 2011 9:26 am Post subject:
| drumfish wrote: | thanks for midi patchbay
Patch bays provide for all sorts of routing and msg filtering.
I used to have a very old one, that worked quite nicely for my needs.
I'm sure the modern versions are more powerful.
I'll second the vote for MidiOx. You'll need a PC to run it, but it can do
sophisticated routing, filtering and mapping too. It's also free, but you will need a midi port
on the PC that is running it. MidiOx can be scripted too, if necessary. _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
drumfish
Posted: Sun Dec 04, 2011 7:08 pm Post subject:
| dasz wrote: | 1. have the OT send midi to multiple slots in the G2 (so this way I can recieve all notes on one channel, I always miss not having the Keyboardin module with selectable MIDI channel)
you must tell me more now
you send the settings in the hardwares ? you need your laptop running or you send the midi datas like a sysex file ? i don't understand how this patchbay works ... i spent days with the blofeld filling it up of samples so i had no much time to try midi patchbay but it sounds interesting ...
i need more something like this http://www.midisolutions.com/prodrte.htm as i just need to rechannelize a single midi out with 2 different channel & then drive 7 synths from 6 outs ... |
egw
Joined: Feb 01, 2003 Posts: 1571 Location: Asheville NC
G2 patch files: 8
Posted: Mon Dec 05, 2011 7:11 am Post subject:
You should be able to use the G2 for most of what the router does. But you'll need something like a midi thru box to control 7 synths from it. _________________ www.gregwaltzer.com |
drumfish
Posted: Mon Dec 05, 2011 8:07 am Post subject:
| egw wrote: | | You should be able to use the G2 for most of what the router does. But you'll need something like a midi thru box to control 7 synths from it. |
good you came to share your knowledge one more ... i keep the dsp power to create patches in the g2 & i control my synths from the monomachine ... the sequencer is killer ... i think i'll get a midi router from midi solutions & i'll rechannelize the router to control 2 synth from 1 midi out with the same midi track on different midi channels ... |
dasz
Audio files: 29
G2 patch files: 56
Posted: Mon Dec 05, 2011 9:12 am Post subject:
| drumfish wrote: | you must tell me more now
No laptop (except for editing patches and dumping some samples into the OT. my key midi generating synths/machines can talk to all other gear including each other. The blofeld dektop dark entrgy and xoxbox can only listen and are not connected to the midi merger)
In terms of control, it depends who is on what midi channel, that is how i route midi in this. The Nord g2 can filter messages and transpose them with a midi thru module, however doing other types of filtering like changing note lengths, velocities and adding or duplicating notes has to be done using one g2 slot per midi channel (for keyboard module). This is done in a g2 patch which listens to keyboard module and then the signal is routed to a midi note message with logic and user interface in-between... The OT sends midi sequence on channels which the blofeld , dark energy, and xoxbox are NOT listening to (ch 14,15,16). Dark energy listens to 8, xox is on 9, and blofeld is on 10. The g2 listens to 14,15,16, in 3 slots. Each of these slots then responds and alters the midi data on these channels and generates the appropriate midi note for the destination synth (on midi channels 8,9, or 10).
the midi router module sounds interesting if you want to do some simpler filtering to various outputs..
With the amount of gear capable of sending cool midi messages you have (machine drum, mono machine and g2), I highly recommend buying the quad midi merger as well ... |
drumfish
Posted: Mon Dec 05, 2011 12:03 pm Post subject:
| dasz wrote: | | I highly recommend buying the quad midi merger as well ... |
i'll check the configurations of this quadra merge then ... thanks for the advice
| dasz wrote: | | This is done in a g2 patch which listens to keyboard module and then the signal is routed to a midi note message with logic and user interface in-between... The OT sends midi sequence on channels which the blofeld , dark energy, and xoxbox are NOT listening to (ch 14,15,16). Dark energy listens to 8, xox is on 9, and blofeld is on 10. The g2 listens to 14,15,16, in 3 slots. Each of these slots then responds and alters the midi data on these channels and generates the appropriate midi note for the destination synth (on midi channels 8,9, or 10). |
exactly what i'm looking for in term of midi chaining ... |
dasz
Audio files: 29
G2 patch files: 56
Posted: Mon Dec 05, 2011 4:56 pm Post subject:
| The only thing about sending patch changes to a g2 which is doing filtering is the interruption of service when a new patch loads up (as par of a performance or a slot ... So if your performance includes all the patches you will use for a show so you are not sending patch changes within the g2, only outside, then you're good ... |
dasz
Audio files: 29
G2 patch files: 56
Posted: Mon Dec 05, 2011 4:58 pm Post subject:
| drumfish wrote: | | dasz wrote: | | I highly recommend buying the quad midi merger as well ... |
i'll check the configurations of this quadra merge then ... thanks for the advice |
You're welcome ... The merger made a big difference and made the entire rig easy to use in different ways without any rewiring ... |
drumfish
Posted: Tue Dec 06, 2011 6:43 am Post subject:
| dasz wrote: | | without any rewiring ... | exactly what i look for ... kind of fed-up to set the all midi protocol again & again ... i see on your profile picture that you have an octatrack ... how's the audio quality ? i sold my mpc ... not a very intuitive machine even the sequencer is killer ... octatrack's on my wish list & then i won't miss midi channels
i just clicked on your profile & oh surprise http://www.clavia.se/misc/users/daszgarncarz.htm we're in good hands on electro-music roland, jan, you & more  |
