Professional manufactured PCB for JH Wasp clone - Interest?
Page 1 of 5 [103 Posts]
Goto page: 1, 2, 3, 4, 5 Next
PostPosted: Sun Dec 04, 2011 9:22 am    Post subject: Professional manufactured PCB for JH Wasp clone - Interest?
Subject description: a project to raise some relief for haibles family
As you all might already know, Jürgen has been taken from us. Among other relatives he leaves two children behind, who will miss their father.
Jürgen once made a hand drawn schematic of a Wasp VCF clone. I later made a singlesided layout for press'n'peel blue - being one of my earliest layouts, it is not a nice layout. but ut has been built quite often, i think.
JH's clone is quite unique, i believe. This is what Jürgen had to say about it:
Jürgen Haible wrote:
The whole combination of the separate parts has some unusual aspects that one might consider suboptimal design, but which I have chosen deliberately to have something different from my other modules:
No expo converter for the filter. Manual Cutoff is set by a logarithmic potentiometer, and the envelope is added to this exponential CV. This results in a certain interaction of Manual Cutoff and Envelope Depth settings.
The Distortion is located after the filter. Usually, you create rich harmonics with an overdrive, and then you filter these harmonics with a VCF, a phaser, or something similar. But it is also very interesting to have a VCF before a distortion unit, to pre-shape the waveform that feeds the distortion in a dynamic way. The avoid the very sharp sound of a pure distortion unit, a fixed filter ("speaker simulator") is hard-wired after the overdrive section.
The state variable filter normally doesn't self oscillate. However, if you plug in a long cable at it's output, it will. This is because the CMOS buffers have a rather large output impedance which will form an extra filter pole together with the cable's capacitance. This could easily be cured with an extra buffer stage, but I decided not to do it in my unit.
My idea was to do a limited run of professional manufactured PCB's for his circuit, using LM13700 OTA's. He never did. I would spend 5.-EUR/PCB to his family.
The price for this PCB would depend on the number of pre-orders we get. The expenses must be covered + 5.-/EUR relief donation.
What do you think?
(If anybody had objections about this project, speak out).
UPDATE (6 DEC 11): the layout is almost done, however, keep in mind that i still have to order and build a prototype. and then we will have to wait and see when and what the family decides to do.
inlifeindeath
PostPosted: Sun Dec 04, 2011 12:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
i'm in. i built his design with your layout and i love it! such an odd filter. depending on the price i'd probably get 2.
Level5
PostPosted: Sun Dec 04, 2011 12:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm in with 2 PCB's Razz
Mongo1
PostPosted: Sun Dec 04, 2011 1:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd be in for 1 or 2, depending on the cost. I don't have any wasp's in my nest yet.
Gary
diablojoy
PostPosted: Sun Dec 04, 2011 4:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think this is a very good thing you do mathias Smile
so count me in and i will take six.
ask where the hell am I
as good an answer as any
fluxmonkey
PostPosted: Sun Dec 04, 2011 5:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
a fitting tribute. 2 for me plz.
www.fluxmonkey.com
Danno Gee Ray
PostPosted: Sun Dec 04, 2011 6:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd be in for 1 or 2.
ach_gott
PostPosted: Sun Dec 04, 2011 10:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm in for 2!
glacial23
PostPosted: Sun Dec 04, 2011 11:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Two for me, please.
glacialcommunications.com
Boerge
PostPosted: Mon Dec 05, 2011 2:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Would take two also.
...ich will doch nur löten...
a.b.o.z.
G2 patch files: 4
PostPosted: Mon Dec 05, 2011 2:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm up for one board.
delta32
PostPosted: Mon Dec 05, 2011 3:36 am    Post subject: Reply with quote  Mark this post and the followings unread
I will also take two.
LFLab
PostPosted: Mon Dec 05, 2011 6:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I am up for a couple.
Edited:
Have read up on the in memoriam thread on this forum, we have been in contact with his family and they welcome the support. I will definitely be up for several boards.
PostPosted: Mon Dec 05, 2011 6:33 am    Post subject: Reply with quote  Mark this post and the followings unread
But have you/we been in contact with his family? Are they open to this sort of thing (since they were divorced or at least living separated)?
This is in the works, and it will take it's time.
I am asking for interest only, yet.
LFLab
PostPosted: Mon Dec 05, 2011 6:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Matthias, I have now read the replies in the other thread.
RF
Audio files: 28
PostPosted: Mon Dec 05, 2011 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
2 here!
www.sdiy.org/rfeng
keninverse
PostPosted: Mon Dec 05, 2011 7:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Count me as interested.
raoulblues
PostPosted: Mon Dec 05, 2011 10:48 am    Post subject: pcbs for JH Wasp clone Reply with quote  Mark this post and the followings unread
I am for two
a65 years I know the fragile life
marvkaye
PostPosted: Mon Dec 05, 2011 11:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Put me down for two as well. And count me in for some donation+ too. It's nice to know that this will benefit his family... he left us all way too soon.
<marv>
hv0190
PostPosted: Mon Dec 05, 2011 12:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm in for two pcbs ... I'd also be willing to donate a bit more ...
emdot_ambient
PostPosted: Mon Dec 05, 2011 12:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep, two for me, but only if you put the fish on the PCB...I'm not Christian, but in honor of the man it must be done thumb up
LFLab
PostPosted: Mon Dec 05, 2011 12:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
+1
xpmtl
PostPosted: Mon Dec 05, 2011 1:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Count me in for one.
Will you add the cmos distortion thinggie on your board?
http://sdiy.xpmtl.net
PostPosted: Mon Dec 05, 2011 3:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
sure i will, and i will add a perf-board area around a LM358 for your discretion (output buffer!?).
jumunius
PostPosted: Mon Dec 05, 2011 8:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great idea, 2 please!
-Jim
