yusynth
Posted: Sun Dec 06, 2009 2:23 am Post subject:
Congratulations ! _________________ Yves |
Joined: Mar 28, 2006 Posts: 1471 Location: Kansas City, Mo USA
Posted: Wed Jul 28, 2010 9:52 am Post subject:
Decided to build a FFB Subject description: It is Howard's fault |
In Kansas City last weekend Howard said, "You REALLY need a Fixed Filter Bank." Well, I have wanted to add one for a long time... Howard finally kind of shamed me into it.
I just ordered more panel aluminum and included the panel for the FFB.
I've decided to build the YuSynth FFB and I think it will be a nice addition to Aries synth. _________________ -- Kevin
http://kevinkissinger.com |
Posted: Tue Sep 14, 2010 7:52 pm Post subject:
A new Yusynth Fixed Filter Bank |
I finished this just before I left for the electro-music festival and I'm just now posting the pics.
I've felt for years that the Aries needed a Fixed Filter Bank and finally it has one.
| View of the front panel. I layed out the knobs to occupy four columns to fit onto a double size (6"x9") panel. |
954.23 KB |
| Viewed: |
483 Time(s) |
664.96 KB |
| Viewed: |
478 Time(s) |
| View of the etched side of the board. |
671.99 KB |
| Viewed: |
489 Time(s) |
yusynth
Posted: Tue Sep 14, 2010 11:01 pm Post subject:
Well done Kev, I will add these in the FFb Gallery for sure ! _________________ Yves |
KnobHell
Posted: Tue Mar 06, 2012 7:22 pm Post subject:
Hi Yves,
On your FFB webpage is a photo of the filter module built by Julien where he brings the filter output individually. Is it safe to assume that each of the filter outputs need to be buffered in the same way the combined outputs are?
len |
yusynth
Posted: Wed Mar 07, 2012 1:31 am Post subject:
It should work without buffering but it is more reasonable to buffer them. _________________ Yves |
KnobHell
Posted: Wed Mar 07, 2012 6:55 am Post subject:
Noted.
Yves, thank you for the great resource!
len |
marvkaye
AlasdairMoons
Joined: Dec 03, 2011 Posts: 105 Location: East-Belgium
Don Erskine
Posted: Fri Aug 05, 2022 1:15 pm Post subject:
YuSynth Fixed Filter Bank - design anomaly |
I have found an anomaly in the YuSynth Fixed Filter Bank design.
Yves' design is inspired by the Moog 914 filter, which is a half-octave filter bank starting from 125Hz in half-octave steps. Thus one of the Moog bandpass filters is labelled 700Hz (should be 707.1 Hz to be more precise).
However, Yves designed a 750 Hz BP filter instead. A check of the component values confirms that this is the centre frequency of Yves' BP filter, it's not just a typo on the filter panel.
This probably explains the slight irregularities in the frequency plots around 700-750Hz in Yves' design document.
Yves' design has C21, C22, C23 and C24 as 24.2 nF, made from 22nF in parallel with 2n2.
Fc can be lowered to around 700Hz by making C21, C22, C23 and C24 = 25.5 nF. This can be simply achieved by changing C21b, C22b, C23b and C24b all from 2n2 to 3n3.
Then the filters will be a true half-octave filter bank. |
