yusynth Fixed Filter Bank
Page 2 of 2 [35 Posts]
Goto page: Previous 1, 2
yusynth
PostPosted: Sun Dec 06, 2009 2:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Congratulations !
Yves
PostPosted: Wed Jul 28, 2010 9:52 am    Post subject: Decided to build a FFB
Subject description: It is Howard's fault
In Kansas City last weekend Howard said, "You REALLY need a Fixed Filter Bank." Well, I have wanted to add one for a long time... Howard finally kind of shamed me into it. Smile
I just ordered more panel aluminum and included the panel for the FFB.
I've decided to build the YuSynth FFB and I think it will be a nice addition to Aries synth.
PostPosted: Tue Sep 14, 2010 7:52 pm    Post subject: A new Yusynth Fixed Filter Bank Reply with quote  Mark this post and the followings unread
I finished this just before I left for the electro-music festival and I'm just now posting the pics.
I've felt for years that the Aries needed a Fixed Filter Bank and finally it has one.
View of the front panel. I layed out the knobs to occupy four columns to fit onto a double size (6"x9") panel.
 Filesize:  954.23 KB
 Viewed:  480 Time(s)
Love those capacitors!
 Filesize:  664.96 KB
 Viewed:  476 Time(s)
View of the etched side of the board.
 Filesize:  671.99 KB
 Viewed:  487 Time(s)
yusynth
PostPosted: Tue Sep 14, 2010 11:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well done Kev, I will add these in the FFb Gallery for sure !
Yves
KnobHell
PostPosted: Tue Mar 06, 2012 7:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Yves,
On your FFB webpage is a photo of the filter module built by Julien where he brings the filter output individually. Is it safe to assume that each of the filter outputs need to be buffered in the same way the combined outputs are?
len
yusynth
PostPosted: Wed Mar 07, 2012 1:31 am    Post subject: Reply with quote  Mark this post and the followings unread
It should work without buffering but it is more reasonable to buffer them.
Yves
KnobHell
PostPosted: Wed Mar 07, 2012 6:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Noted.
Yves, thank you for the great resource!
len
marvkaye
PostPosted: Fri Mar 09, 2012 8:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
I finished populating my FFB board earlier this week and have been working on the panel design for the last couple of days. I decided to implement some of the Dragonfly Alley mods but wanted to do something a bit different than the panel offered by Scott @ Bridechamber. The attached PDF is a plot from my CAD program that I'll use to program the CNC router to do all the drilling and engraving. I started my foray into modulars with a dotcom entry system and so am trying to stick to that format for my DIY modules as well. I thought I'd share the plot here and take this opportunity to thank Yves for a great project... so far I've enjoyed it thoroughly. Thanks for making it possible, Yves... you get my vote! Wink
<marv>
Yusynth_FFB_Panel.pdf
The little box around the Yusynth logo will be eliminated before engraving... can't make it go away in the CAD program, but it had to be placed to make the panel official.
 Filename:  Yusynth_FFB_Panel.pdf
 Filesize:  85.29 KB
 Downloaded:  469 Time(s)
AlasdairMoons
PostPosted: Tue Mar 20, 2012 4:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Mine is finished and it works perfect.
All frequencies are filtered like they should.
Thanks for this nice project
my Music-Channel:
my Facebook:
Don Erskine
PostPosted: Fri Aug 05, 2022 1:15 pm    Post subject: YuSynth Fixed Filter Bank - design anomaly Reply with quote  Mark this post and the followings unread
I have found an anomaly in the YuSynth Fixed Filter Bank design.
Yves' design is inspired by the Moog 914 filter, which is a half-octave filter bank starting from 125Hz in half-octave steps. Thus one of the Moog bandpass filters is labelled 700Hz (should be 707.1 Hz to be more precise).
However, Yves designed a 750 Hz BP filter instead. A check of the component values confirms that this is the centre frequency of Yves' BP filter, it's not just a typo on the filter panel.
This probably explains the slight irregularities in the frequency plots around 700-750Hz in Yves' design document.
Yves' design has C21, C22, C23 and C24 as 24.2 nF, made from 22nF in parallel with 2n2.
Fc can be lowered to around 700Hz by making C21, C22, C23 and C24 = 25.5 nF. This can be simply achieved by changing C21b, C22b, C23b and C24b all from 2n2 to 3n3.
Then the filters will be a true half-octave filter bank.
