ZeeByeZon
Posted: Tue Mar 13, 2012 2:20 pm Post subject:
Fixed!
I tried with libusb version 1.2.6.0 and now it works! |
brunov
ZeeByeZon
Posted: Wed Mar 14, 2012 1:36 am Post subject:
The version which did not work for me is the last from the 'snapshot' section: 1.2.4.9
The 1.2.6.0 ('release' section) has no installer, but the installation is quite simple : just unzip the downloaded file and launch install-filter-win.exe, located in the bin\x86 folder. |
drapdap
Posted: Tue Mar 20, 2012 1:30 pm Post subject:
Bruno!
allow me a question. do you think it would be possible to monitor the midi input of the G2 in the open editor? like in max/msp there's a small window that shows a list of the incoming messages in text?
lot of the times i have no midi/soundcard connected to the laptop, just use the engine, and it would be sooo handy to see it... |
brunov
drapdap
Posted: Wed Mar 21, 2012 1:10 am Post subject:
Thanks Bruno! that makes sense...
just thinking how useful it would be, for me.
but notes are also sent, as they show up in the sequencer?
that's probably not midi when they arrive in the screen... |
brunov
drapdap
Posted: Wed Mar 21, 2012 1:31 am Post subject:
| brunov wrote: | | My guess is that only the parameter changes of the sequencer module are send. But I haven't tested recording notes in a sequencer yet, so I'll try that tonight. |
thanks!  |
brunov
drapdap
Posted: Thu Mar 22, 2012 2:56 am Post subject:
| brunov wrote: | | Drapdap, I'm afraid there are also no midi note events when recording notes in a sequencer module, I only get the parameter change messages. |
but thanks for taking a look! somehow it's logical.
| brunov wrote: |
Don't know it it's any use to you, but maybe I'll add another midi port in the editor to be able to emulate the front panel of the g2 keys with another midi controller (for engine owners), of course there'll be some more midi possibilities then. |
a midi port thru the pc into the editor then midi down to the usb cable?
is that what your saying?
that would be most excellent if works safely!
my problem, (except i can't use linux, but you solved that!) with
the editor, is how to organise things if i want to play, the screen gets busy,
and hard to see at first, if i recall something.
the on screen keyboard can only hold one note, but why not hold a few more?  |
brunov
Posted: Thu Mar 22, 2012 11:51 am Post subject:
Actually, that wasn't exactly what I meant. I don't think I really understand you question.
I meant that I want to be able to fix a knob on my controller to a fixed knob on the parameter pages, just like on the front panel of a g2 keys (since I have a engine).
For example I want cc 53 of my controller to always be connected to knob 1 on the parameter pages, and cc 54 to knob 2 and so on.
So when I'm browsing through a lot of patches, I don't have to manually assign these cc's all the time to try out some of the modulation possibilities of a patch.
That's only to overcome some of the limitations of the engine...
One part of your question was about sending midi note events down the USB line. I've tried that, but there also the usb message implementation is very limited. It's only mono key and no velocity, basically it's
key number, on
key number, off
and you have to send a note off before you can send a next note, otherwise the former sticks  _________________ My old OS NMG2 editor: http://sourceforge.net/projects/nmg2editor/?source=directory
My new G2 editor FMX: http://www.bverhue.nl/g2dev/?page_id=17
Source code: https://github.com/BVerhue/nord_g2_editor |
sitarman
Joined: Jul 08, 2007 Posts: 20 Location: New Lenox Il.
Posted: Thu Mar 29, 2012 7:02 am Post subject:
On startup I get a windows socket error: cannot bind to more that one....
I am on windows XP and get the message for both version (.49 and .60) of lib-usb.
Any hints?> |
brunov
sitarman
Posted: Fri Mar 30, 2012 8:17 am Post subject:
| Yes it did , thanks |
brunov
Joined: Apr 03, 2004 Posts: 24539 Location: The Netherlands, Enschede
Audio files: 299
Posted: Mon Apr 09, 2012 4:55 pm Post subject:
| brunov wrote: | - you can adjust the color scheme for each G2 in the application settings dialog.
Good idea!
Didn't check in later versions, so this may have been fixed .. but in earlier versions I missed the "variation init" functionality as Clavia has it ... don't recall it exactly but think I could not copy to variation init ... work flow is supposed to be be like :
1) get variation 1 more or less like you want it to be
2) set variation init as a copy of variation 1
3) hit any other variation and hit Init button to set it like variation init
did not check on CTRL-E -- which is parameter paste, but that one and variation init are realy handy to set up and maintain variations in a patch.
Anyway, that just crossed my mind ;-)
keep up the good work, really nice to see where it is going! _________________ Jan
brunov
Audio files: 299
Posted: Tue Apr 10, 2012 5:04 am Post subject:
| brunov wrote: | | Do you know by any chance how I should calculate the filter resonance display value? Maybe the unit is in decibel? |
Sorry, I don't know - I had always assumed a lookup table there, but yeah maybe there is a formula. It may even be different for different filter types? _________________ Jan
Posted: Tue Apr 10, 2012 10:07 am Post subject:
| brunov wrote: | Do you know by any chance how I should calculate the filter resonance display value? Maybe the unit is in decibel?
paramvalue display value
0 0,5
64 1,67
110 10
127 50 |
It should be a ratio of bandwidth and the center frequency. Here is the wikipedia page on it, which is nicely done:
http://en.wikipedia.org/wiki/Q_factor
The Clavia filters are mostly constant-Q type, which means as you sweep the frequency, the Q stays the same. In essence the filter bandwidth changes as the frequency is moved around.
I wish I had some time right now to look at these for you. But I won't be able to for at least a week, probably two. I will take a look then if you still need a good answer!
Oh, but it is dimensionless...there is no decibels, time, or anything else, since it is a measure of frequency over frequency. |
Audio files: 299
Posted: Tue Apr 10, 2012 11:52 am Post subject:
| Blue Hell wrote: | | It may even be different for different filter types? |
Indeed, as I suspected, the Classic filter has a different curve. _________________ Jan
brunov
purusha
Posted: Sat Apr 28, 2012 2:32 pm Post subject:
Nice work!
When I've finished off the work I'm doing at the minute, I'll have to give this a go!
 _________________ OVNI Soundcloud Purusha Soundcloud |
Estarriol
Posted: Thu May 03, 2012 11:13 pm Post subject:
Dunno if it fits here: Nord Modular OS 1.40 & 1.60 binaries... Ripped em for reverse engineering.
[attachment removed by Blue Hell - see my post below] |
brunov
Audio files: 299
Posted: Fri May 04, 2012 7:24 am Post subject:
| Estarriol wrote: | | Dunno if it fits here: Nord Modular OS 1.40 & 1.60 binaries... Ripped em for reverse engineering. |
Hmm, no, it does not fit here.
It is copyrighted material and you are not allowed to post it here. I know this information is easily obtained from the resources in the updater program, but people interested in reverse engineering will have to do such themselves.
Also it would not be appropriate to discuss the reverse engineering results on this forum.
I'll remove the attachment, I'm really sorry about that as I'm truly interested in what is in them, but it is not appropriate here. _________________ Jan
