Broadwave
Joined: Feb 16, 2007 Posts: 347 Location: Manchester UK
Audio files: 6
Posted: Tue Jun 19, 2012 10:02 am Post subject:
Seriously simple mixer... But I need help! Subject description: 1 x 8 *or* 2 x 4 Mixer |
After all these years of sucessfully building various modules, I've come across something that is so mind bogglingly simple... but I just can't seem to think straight.
I have two very basic 4 input mixers with individual outs, but I need to switch them at some point to create a single 8 in mixer.
Is the rough drawing below ok? If not, then I need help (possibly a Lobotomy!)... any pointers?
Thanks.
EDIT: Or could I just put in a switch to join the 2 x 4 inputs together at the inverting op-amp inputs?
| Description: |
| Filesize: |
27.34 KB |
| Viewed: |
9653 Time(s) |
_________________ Kronos 2-88, Kronos 61, Studiologic Sledge V2/SL, Broadwave ARP 2600EX, Broadwave 18U ARP based Eurorack Modular, Broadwave Minimoog Clone, GEM S2 Turbo.
Synth DIY Projects
Musical Doodlings |
bubzy
Joined: Oct 27, 2010 Posts: 594 Location: United Kingdom
Audio files: 64
Posted: Tue Jun 19, 2012 10:42 am Post subject:
you seem to have two outputs there, it might be better to switch the signal AWAY from the lower opamp instead of adding it.
just my (mostly uneducated) opinion _________________ _Richard_  |
Broadwave
Audio files: 6
Posted: Tue Jun 19, 2012 11:50 am Post subject:
| bubzy wrote: | you seem to have two outputs there, it might be better to switch the signal AWAY from the lower opamp instead of adding it.
just my (mostly uneducated) opinion |
So, use a DP switch to also disconnect the inverting IP of the lower right op-amp?
Although it would be nice to have a duplicated output in order to send a bunch of VCO's to two separate VCF's. _________________ Kronos 2-88, Kronos 61, Studiologic Sledge V2/SL, Broadwave ARP 2600EX, Broadwave 18U ARP based Eurorack Modular, Broadwave Minimoog Clone, GEM S2 Turbo.
Synth DIY Projects
Musical Doodlings |
Sebo
Posted: Tue Jun 19, 2012 12:02 pm Post subject:
If you want duplicated output, I think the switch have to be before the resistors between the OpAmps. _________________ Sebo
My Music:
https://www.facebook.com/cosaquitos/ |
JingleJoe
Joined: Nov 10, 2011 Posts: 878 Location: Lancashire, England
Posted: Tue Jun 19, 2012 12:09 pm Post subject:
| AndyR1960 wrote: | | bubzy wrote: | you seem to have two outputs there, it might be better to switch the signal AWAY from the lower opamp instead of adding it.
Although it would be nice to have a duplicated output in order to send a bunch of VCO's to two separate VCF's. |
It would help if you noted which input of the op amps were which
I'd add a switch between the two groups of four resistors, if you want to use both op amp networks that is, if you want to keep two output but bypass one of the op amp parts, you could connect the input to, say, the bottom op amp from the group of four resistors, to a switch and another switch on the output to switch the lower output between being connected to the top op amp circuit or the bottom one, then have both these switches in a DPDT switch, activating them both, do you see what I mean? It's hard to explain. _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
Green Dungeon Alchemist Laboratories |
bubzy
Audio files: 64
Joined: Apr 03, 2004 Posts: 24555 Location: The Netherlands, Enschede
Audio files: 303
Posted: Tue Jun 19, 2012 1:03 pm Post subject:
I would rather not short the outputs of them two opamps, if you switch then you do it after the the resistors, but I think the original schematic will just work ... although I cant quite get ny brain around it either  _________________ Jan
bubzy
Audio files: 64
Posted: Tue Jun 19, 2012 1:06 pm Post subject:
yeah i guess that makes more sense. just move the switch to after the resistor, that way you eliminate one of the two outputs, you could, of course as joe said, put the switch before the input of the lower (or upper) op amp after the 4 resistors and switch between 4 and 8 inputs into one op amp _________________ _Richard_  |
Posted: Tue Jun 19, 2012 1:26 pm Post subject:
| Looks to me like the switch needs to be spdt though, not just simply shorting them together. Closed to second output amp, or closed to first output amp. |
diablojoy
Joined: Sep 07, 2008 Posts: 809 Location: melbourne australia
Posted: Tue Jun 19, 2012 2:55 pm Post subject:
you could of course drop the switching by adding 2 more inverting opamps
to sum both of the existing outputs and then add a third output jack which would be the sum of all 8 inputs
that way both configurations are available simultaneously.
A fourth inverted output jack could also be added tapped off the output of the first extra opamp, if you want to send to 2 destinations for say 8 VCO's to 2 VCF's which might be interesting _________________ In an infinite universe one might very well
ask where the hell am I
as good an answer as any |
richardc64
Audio files: 26
andrewF
Broadwave
Audio files: 6
Posted: Wed Jun 20, 2012 12:44 am Post subject:
Thanks for the ideas guys.
Who knew that such a simple problem would elicit so many responses : )
@AndrewF - So simple, and such an obvious way to go about it!
Cheers. _________________ Kronos 2-88, Kronos 61, Studiologic Sledge V2/SL, Broadwave ARP 2600EX, Broadwave 18U ARP based Eurorack Modular, Broadwave Minimoog Clone, GEM S2 Turbo.
Synth DIY Projects
Musical Doodlings |
Posted: Wed Jun 20, 2012 12:46 am Post subject:
Would it add too much stuff to make all 8 inputs panable to either of the two outputs?
Then you'd get the best of all 8 inputs. Send this one here, that one there, etc. _________________ What makes a space ours, is what we put there, and what we do there. |
Broadwave
Audio files: 6
Posted: Wed Jun 20, 2012 1:48 am Post subject:
| Uncle Krunkus wrote: | Would it add too much stuff to make all 8 inputs panable to either of the two outputs?
Then you'd get the best of all 8 inputs. Send this one here, that one there, etc. |
I did think about doing something like this, but I have to squeeze it all onto a 3 U 12HP Panel... In fact I've had to compromise on the input level pots - I'm using 4 x dual pots so that IP's 1 & 5, 2 & 6 etc. are linked.
This is the last module to go in my synth... I'm trying desperately not to add another 3U rack, as I *think* I have enough modules in there now (but we all say that, right?).
Synth DIY Projects
Musical Doodlings |
Posted: Wed Jun 20, 2012 1:56 am Post subject:
| andrewF wrote: | switches are expensive
whynot add a 5th input to one on the mixers, no need for an attenuator pot, just the socket.
when you need 8>1, just patch the output of the 4 input mixer into the 5th input of the other.
it also means you now have a 5 input mixer.
If you are using minijacks, this could be hard-wired to the switches on the sockets so no need for a patchcord. |
this is exaclty what i did with a dual DC mixer for my first cabinet. i learned to like this setup very much!most of the time i need two mixers with less inputs, however, if i run into a situation where i needed 8>1 i have it.
BTW i wired the output of the 1st mixer to a socket and this sockets switching contact to the 2nd mixers 5th input. this way bt mixers are connected as long as i don't plug something into the 1st mixers output... _________________
Tech Buddy at Random*Source |
vladosh
Audio files: 51
Posted: Wed Jun 20, 2012 4:19 am Post subject:
| I see you replaced the switch with a waveform ..smart O_o |
JingleJoe
Posted: Wed Jun 20, 2012 10:39 am Post subject:
| vladosh wrote: | | I see you replaced the switch with a waveform ..smart O_o |
I think you have become too accustomed to seeing waveforms In Andrew's diagram that's just crossing out, no switch required! A very simple and elegant solution  _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
vladosh
Audio files: 51
Posted: Wed Jun 20, 2012 11:53 am Post subject:
| No Joe .. it's waveform ..i'm sure! )) |
vladosh
Audio files: 51
Posted: Wed Jun 20, 2012 1:06 pm Post subject:
| ..if you turn the switch a bit and make one more connection you can get sanmple and hold too )) |
richardc64
Audio files: 26
Posted: Wed Jun 20, 2012 1:27 pm Post subject:
 _________________ Revenge is a dish best served with a fork... to the eye |
JingleJoe
Posted: Thu Jun 21, 2012 7:27 am Post subject:
