Seriously simple mixer... But I need help!
Page 1 of 1 [22 Posts]
Broadwave
Audio files: 6
PostPosted: Tue Jun 19, 2012 10:02 am    Post subject: Seriously simple mixer... But I need help!
Subject description: 1 x 8 *or* 2 x 4 Mixer
After all these years of sucessfully building various modules, I've come across something that is so mind bogglingly simple... but I just can't seem to think straight.
I have two very basic 4 input mixers with individual outs, but I need to switch them at some point to create a single 8 in mixer.
Is the rough drawing below ok? If not, then I need help (possibly a Lobotomy!)... any pointers?
Thanks.
EDIT: Or could I just put in a switch to join the 2 x 4 inputs together at the inverting op-amp inputs?
 Filesize:  27.34 KB
 Viewed:  9672 Time(s)
Synth DIY Projects
Musical Doodlings
bubzy
Audio files: 64
PostPosted: Tue Jun 19, 2012 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
you seem to have two outputs there, it might be better to switch the signal AWAY from the lower opamp instead of adding it.
just my (mostly uneducated) opinion
_Richard_ Smile
Broadwave
Audio files: 6
PostPosted: Tue Jun 19, 2012 11:50 am    Post subject: Reply with quote  Mark this post and the followings unread
So, use a DP switch to also disconnect the inverting IP of the lower right op-amp?
Although it would be nice to have a duplicated output in order to send a bunch of VCO's to two separate VCF's.
Synth DIY Projects
Musical Doodlings
Sebo
PostPosted: Tue Jun 19, 2012 12:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you want duplicated output, I think the switch have to be before the resistors between the OpAmps.
Sebo
My Music:
JingleJoe
PostPosted: Tue Jun 19, 2012 12:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
It would help if you noted which input of the op amps were which Laughing
I'd add a switch between the two groups of four resistors, if you want to use both op amp networks that is, if you want to keep two output but bypass one of the op amp parts, you could connect the input to, say, the bottom op amp from the group of four resistors, to a switch and another switch on the output to switch the lower output between being connected to the top op amp circuit or the bottom one, then have both these switches in a DPDT switch, activating them both, do you see what I mean? It's hard to explain.
bubzy
Audio files: 64
PostPosted: Tue Jun 19, 2012 12:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
like this i meant. Very Happy
please excuse the awful drawing
on reflection, the switch is SPST.....brain not work good today
 Filesize:  463.57 KB
 Viewed:  157 Time(s)
_Richard_ Smile
Audio files: 303
PostPosted: Tue Jun 19, 2012 1:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would rather not short the outputs of them two opamps, if you switch then you do it after the the resistors, but I think the original schematic will just work ... although I cant quite get ny brain around it either Laughing
bubzy
Audio files: 64
PostPosted: Tue Jun 19, 2012 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah i guess that makes more sense. just move the switch to after the resistor, that way you eliminate one of the two outputs, you could, of course as joe said, put the switch before the input of the lower (or upper) op amp after the 4 resistors and switch between 4 and 8 inputs into one op amp
_Richard_ Smile
PostPosted: Tue Jun 19, 2012 1:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks to me like the switch needs to be spdt though, not just simply shorting them together. Closed to second output amp, or closed to first output amp.
diablojoy
PostPosted: Tue Jun 19, 2012 2:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
you could of course drop the switching by adding 2 more inverting opamps
to sum both of the existing outputs and then add a third output jack which would be the sum of all 8 inputs
that way both configurations are available simultaneously.
A fourth inverted output jack could also be added tapped off the output of the first extra opamp, if you want to send to 2 destinations for say 8 VCO's to 2 VCF's which might be interesting
ask where the hell am I
as good an answer as any
richardc64
Audio files: 26
PostPosted: Tue Jun 19, 2012 8:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Add another input R to the top output amp and wire the switch to connect it to the output of the bottom input amp. The top mixer is switchable 4 or all 8 inputs and the bottom mixer is always 4 inputs.
Or add Rs to both output amps' inputs and use a dp switch to select 2 separate 4-inputs or one 8 with two outputs.
I like the first way for versatility.
 Filesize:  14.95 KB
 Viewed:  9462 Time(s)
andrewF
PostPosted: Tue Jun 19, 2012 9:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
switches are expensive Smile
whynot add a 5th input to one on the mixers, no need for an attenuator pot, just the socket.
when you need 8>1, just patch the output of the 4 input mixer into the 5th input of the other.
it also means you now have a 5 input mixer.
If you are using minijacks, this could be hard-wired to the switches on the sockets so no need for a patchcord.
 Filesize:  30.96 KB
 Viewed:  9450 Time(s)
Broadwave
Audio files: 6
PostPosted: Wed Jun 20, 2012 12:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the ideas guys.
Who knew that such a simple problem would elicit so many responses : )
@AndrewF - So simple, and such an obvious way to go about it!
Cheers.
Synth DIY Projects
Musical Doodlings
PostPosted: Wed Jun 20, 2012 12:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Would it add too much stuff to make all 8 inputs panable to either of the two outputs?
Then you'd get the best of all 8 inputs. Send this one here, that one there, etc.
Broadwave
Audio files: 6
PostPosted: Wed Jun 20, 2012 1:48 am    Post subject: Reply with quote  Mark this post and the followings unread
I did think about doing something like this, but I have to squeeze it all onto a 3 U 12HP Panel... In fact I've had to compromise on the input level pots - I'm using 4 x dual pots so that IP's 1 & 5, 2 & 6 etc. are linked.
This is the last module to go in my synth... I'm trying desperately not to add another 3U rack, as I *think* I have enough modules in there now (but we all say that, right?).
Synth DIY Projects
Musical Doodlings
PostPosted: Wed Jun 20, 2012 1:56 am    Post subject: Reply with quote  Mark this post and the followings unread
this is exaclty what i did with a dual DC mixer for my first cabinet. i learned to like this setup very much!most of the time i need two mixers with less inputs, however, if i run into a situation where i needed 8>1 i have it.
BTW i wired the output of the 1st mixer to a socket and this sockets switching contact to the 2nd mixers 5th input. this way bt mixers are connected as long as i don't plug something into the 1st mixers output...
vladosh
Audio files: 51
PostPosted: Wed Jun 20, 2012 4:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I see you replaced the switch with a waveform ..smart O_o
JingleJoe
PostPosted: Wed Jun 20, 2012 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
I think you have become too accustomed to seeing waveforms Wink In Andrew's diagram that's just crossing out, no switch required! A very simple and elegant solution Smile
vladosh
Audio files: 51
PostPosted: Wed Jun 20, 2012 11:53 am    Post subject: Reply with quote  Mark this post and the followings unread
No Joe .. it's waveform ..i'm sure! ))
vladosh
Audio files: 51
PostPosted: Wed Jun 20, 2012 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
..if you turn the switch a bit and make one more connection you can get sanmple and hold too ))
richardc64
Audio files: 26
PostPosted: Wed Jun 20, 2012 1:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
JingleJoe
PostPosted: Thu Jun 21, 2012 7:27 am    Post subject: Reply with quote  Mark this post and the followings unread
