Joined: Oct 27, 2010 Posts: 594 Location: United Kingdom
Audio files: 64
Posted: Sun Nov 18, 2012 12:50 am Post subject:
Perfboard / Stripboard challenge
yesterday, while waiting for my iron to heat up, I noticed an offcut of perfboard that had chipped off an edge when i was cutting it, while I was absent-mindedly staring at it, I wondered what i could build on that small piece, then I wondered what any of you guys could make too.
therefore, I challenge everyone to make a circuit that:
1) makes noise!!!
2) takes up NO MORE than 30 holes on perf/stripboard
there are no prizes for this challenge (because im broke )
look forward to seeing your builds. _________________ _Richard_
But if you didn't need a hole/s could you drill it out and drop the hole count!? _________________ What makes a space ours, is what we put there, and what we do there.
I think no piggy-backing components should be a rule... and no off the board component wiring... no sculptural open space wiring, point to point or whatever it is called. That would be defeating the purpose. Not much room on that size board. Hopefully this will get beyond a load of two transistor multivibrators.
Posted: Sun Nov 18, 2012 6:41 am Post subject:
I agree
Posted: Sun Nov 18, 2012 8:01 pm Post subject:
Perfertorator Subject description: Bubzy's perferted challenge
played a bit more with a 2 transistor AMV,
replaced resistors with LDR's, changed the circuit a bit and to my surprise I got it oscillating with 1 capacitor.
didn't realize how small 30 holes actually was untill I cut the perf
the design was a bit trickier then I expected too,
but I managed to get it on there.
the 4 pins it stands on do have a function, 2 are for power, the other 2 are connected together and can be used
as a line out.
nice perferted challenge bubzy!
Filesize:
63.3 KB
Viewed:
462 Time(s)
Filesize:
60.65 KB
Viewed:
404 Time(s)
Filesize:
52.09 KB
Viewed:
413 Time(s)
Filesize:
64.18 KB
Viewed:
465 Time(s)
Filesize:
33.19 KB
Viewed:
427 Time(s)
Well done! Looks good... like a little bunch of electronic mushrooms. Some sound recording would be nice .
It does pretty much come down to transistors. There isn't room for an IC... unless you want to go opening the cases. Of course there is the option of making your own custom components if that is not cheating.
EDIT: also, there is a distinct advantage with perf. You don't need to sacrifice holes to make a break in the track.
Posted: Sun Nov 18, 2012 9:20 pm Post subject:
how about a video:
I might record some sounds too,. (I wanna hear it with delay )
Posted: Mon Nov 19, 2012 11:56 am Post subject:
You could stand an opamp or other 8 pin DIP on its side making it only 2 holes wide on perf or 3 on vero. You could get it 2 on vero if you made trace cuts between holes rather than through them, or would that be cheating?
The same trickery would just about allow a 14 pin DIP for some CMOS fun.
Audio files: 64
Posted: Mon Nov 19, 2012 1:26 pm Post subject:
Edit:
after rereading slackers post......
i cant see why we cannot "creatively" mount components, so long as we dont reduce the number of holes they use. i think reducing the number of holes they "waste" is PERFectly acceptable. _________________ _Richard_ Last edited by bubzy on Tue Nov 20, 2012 12:03 am; edited 1 time in total
Joined: Feb 09, 2012 Posts: 17 Location: 3rd from the sun
Posted: Sat Nov 24, 2012 8:12 am Post subject:
Possibly the ILC (International Lunettic Committee) will reject my entry because
- in two places a hole is used twice (the wires on AA and FB)
- one component (C2) is half-offboard
- the circuit is not my design, it is a Sudo-Mini by John Richards (http://www.dirtyelectronics.org/docs/sudomini.zip)
- I have not built and veryfied it yet.
But as it is about taking part, not about to win, here it is (24 holes):
Stripboard Mini-Sudo (unverified)
Filesize:
36.31 KB
Viewed:
415 Time(s)
No seriously, F*** the ILC! They are all Flat Earthers.
At 24 holes if you went down the perf route you could add another 4 and fit that cap on could you not? Although part of its charm is the cap hanging over the side.
