chaosMK
Posted: Mon May 02, 2005 1:57 pm Post subject:
Drum Machines |
Hello,
I am new here and new to electronic music. I havent seen anything on drum machines in this forum so please let me know if I am completely in the wrong place. It seems like everyone uses software here to write.
I write a lot of odd-time/progressive music on bass and am looking for a drum machine/sequencer that has the capability to play in times like 7/8, 5/4, 13/8, but havent been able to find one that goes outside of 3/4 or 4/4. Any thoughts? |
seraph
Editor
Audio files: 33
Posted: Mon May 02, 2005 2:25 pm Post subject:
Hi chaosMK
you're not in the wrong place, actually you are
to write odd-time drum patterns a computer application would be the right tool  _________________ homepage - blog - forum - youtube
| Quote: | | Don't die with your music still in you - Wayne Dyer |
Posted: Mon May 02, 2005 4:12 pm Post subject:
chaosMK!
Seraph is right about that. A laptop with some suitable software is the best solution for that. You wouldn?t really need a new laptop either, if you want to send the midi output to an external sound module.
In fact, old Cubase 5.1 would do just fine.. and you could use an old mac or PC laptop for this. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Posted: Mon May 02, 2005 4:18 pm Post subject:
| I have an old Yamaha QY-70. I've never tried 13/8, but for the most part, you can set it to whatever you like (x/n style). It's very small & portable, though the sounds are Yamaha XG (eXtra Generic). But as a MIDI sequencer it works fantastic. |
chaosMK
Posted: Mon May 02, 2005 11:07 pm Post subject:
Thanks for the warm welcome and suggestions =)
OK, so what it sounds like is I should find a copy of Cubase and go from there. Do I need a device to get the sounds from (I took a MIDI class back in the day and this was how we did it-) like a keyboard? If that is the case, would a drum machine or groovebox be a substitute?
MKC |
Posted: Mon May 02, 2005 11:26 pm Post subject:
To get the sounds from... ? You are thinking about some input device that you can use to record events from?
One possible workflow is to program basic patterns using the mouse/a computer keyboard. You then use this as a click track and use something like a midi drumkit with pads.. like some Yamaha or Roland to input performances. You then edit the performances to your liking then construct the track using these new patterns. If you feel confident with rythms you can just as well use the mouse to write the patterns in the piano roll editor in cubase.
The reason why I suggested Cubase 5.1 is that this product is old, you can probably still get nonupgradeable versions for like 65 USD or something like that, and the interface is more intuitive than the new SX series. You?ve got everything you need in there and the software will also perform OK on older computers. If you get the 5.1 VST 32 you will also have notation, and a lot of plugins including some simple drum modules. These are OK for clicktracks. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
seraph
Editor
Audio files: 33
Posted: Tue May 03, 2005 12:29 am Post subject:
an old Atari computer with a compatible software sequencer would be up to the task too  _________________ homepage - blog - forum - youtube
Posted: Tue May 03, 2005 12:30 am Post subject:
True, that would do just fine too.  _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Posted: Mon May 09, 2005 1:25 pm Post subject:
I think any machine with a "last step" setting will do. Even the lowly tr-505 has one, I´ve done 7/8 and 5/8 on that one. _________________ Kassen |
Joined: Feb 04, 2005 Posts: 2872 Location: Nottingham, UK
Audio files: 279
Posted: Mon May 09, 2005 3:08 pm Post subject:
I used to have a HR-16, it could have any pattern length you wanted and songs could be made up of patterns of different lengths
If you want to get into serious polyrythmic territory, something like a Doepfer Regelwerk allows 8 tracks of differing lengths to run simultaneously
Or you could as stated previously use a software sequencer _________________ Jez
music | adventures in sound | gear for sale |
Joined: Jan 31, 2003 Posts: 18260 Location: Durham, NC
Audio files: 228
Posted: Mon May 09, 2005 8:04 pm Post subject:
I like patterns of different lengths, but also different tempos. I prefer music with abmiguous tempos. When drum machines were first invented, that was bad enough. Then people started making music that was as only one tempo, like 132 or 123 or something that was much worse. When I first heard this I was pretty disappointed. I've learned to accept and tolerate what has become called Dance music, and everyone once in a while I hear something I like. I prefer IDM. Like lawyers, 4000 drum machines at the bottom of the ocean is a good start.  _________________ --Howard
my music and other stuff |
Posted: Tue May 10, 2005 2:27 am Post subject:
| Quote: | | Like lawyers, 4000 drum machines at the bottom of the ocean is a good start |
I had Jury Duty last week, and everyone told me "Just say your an engineer, or that 10,000 Lawyers at the bottom of the ocena is a good start". As it turns out, all the cases that day were settle out of court moments before they were due in court, so I'll have to save my humorisms for next time  |
seraph
Editor
Audio files: 33
Posted: Tue May 10, 2005 2:47 am Post subject:
| modulator_esp wrote: | | I used to have a HR-16 |
I had that too, it was a great little drum machine. you could pitch up or down any single sample. very nice _________________ homepage - blog - forum - youtube
Roland Kuit
Joined: Sep 29, 2003 Posts: 1090 Location: The Netherlands/Sweden
G2 patch files: 127
Posted: Tue May 10, 2005 5:03 am Post subject:
Hahahah, Howard,
I like your sense of humor:), AND it will be a good idea because of the wave currencies, you will get some phase differences! |
Posted: Mon May 23, 2005 12:52 pm Post subject:
Dangerous Drums |
I must add my recommendation here.
I've owned quite a lot of drum machines over the last few years but the one that keeps bouncing back, one I never tire of, is built like a brick shithouse (and therefore works and works and works etc), is a complete digital 'analogue' drum synthesiser on every key (x2 as well- one for left and right outputs), Really GOOD resonating digital 12/24 db/oct high/low- pass filters, Microtuning, +/- 4 octaves tuning, envelopes on everything (well decay, but you similate attack using the backwards sounds), noise, sines tri's saw's, 808, 909, sample playback, writes in virtually any time signature you can throw at it;
Is my Yamaha RY30
You could read all the glowing reports on Harmony Central but what's the point? Go find one on ebay etc- you will not be dissapointed.
Tom :-)
PS, hello Roland (Kuit)! |
Roland Kuit
G2 patch files: 127
Posted: Mon May 23, 2005 1:39 pm Post subject:
Hi Tom,
do i know you from the London event:)?The Birmingham guy!
Didn't you gasp: "heee, without cubase?!!!" Last edited by Roland Kuit on Mon May 23, 2005 2:00 pm; edited 1 time in total |
Posted: Mon May 23, 2005 1:56 pm Post subject:
OT: My favorite drum machine is this guy:
This guy is great too: http://www.spoonrecords.com/jaki2.html
Flickr |
Posted: Tue May 24, 2005 4:01 am Post subject:
| roland kuit wrote: | Hi Tom,
Didn't you gasp: "heee, without cubase?!!!":) |
hmmm I have thought about this- I never went to the london event. I do however know another Tom in Brum (who's a synth nut too) who could be the Tom you met? I know you Roland from Justin Maxwell's now sadly defunked nordmodular list. Its been a year or so since I was last there- small children are hard work !
But 'live, without cubase' is definitely the way forward! |
Roland Kuit
G2 patch files: 127
Posted: Tue May 24, 2005 7:43 am Post subject:
Aha, you said Justin. Now i know. But not only small kids are hard work:(
Bigger ones are too!(1st small worries, later bigger worries, hope i don't dissapoint you:)))) |
Mohoyoho
paul
Posted: Thu May 26, 2005 5:00 am Post subject:
... what do you think about MachineDrum SPS-1 (Elektron)?
... maybe a little bit expensive but it's amazing! _________________ paolo ferrari |
Posted: Thu May 26, 2005 6:09 am Post subject:
| paul wrote: | ... what do you think about MachineDrum SPS-1 (Elektron)?
... maybe a little bit expensive but it's amazing! |
A friend here in Birmingham has got one- pure 'electro-pop'! Yes it is a lot of money. If you can afford one, get one but personally if I was going to spend that much money, I'd get a Clavia G2 :)) Waay more versatile! |
softroom
Posted: Tue Jun 07, 2005 2:03 am Post subject:
I'm a big fan of the Korg ESX-1, especially in combination with a P3 sequencer. It's very instant yet deep enough so you won't get bored. And, of course, you can do some bizarre things beyond the scope of any drum machine if you send some additional triggers from the P3.
Paul _________________ www.smokyfrog.com http://www.youtube.com/WilyEPeyote |
seraph
Editor
Audio files: 33
Posted: Tue Jun 07, 2005 3:10 am Post subject:
hi Paul
welcome to electro-music.com  _________________ homepage - blog - forum - youtube
