today> Twyndyllyngs Chez Mosc
Oberheim DX Drum machine
Page 1 of 1 [9 Posts]
G2 patch files: 626
PostPosted: Wed Feb 12, 2014 12:41 am    Post subject: Oberheim DX Drum machine
Subject description: Some lo-fi 80's drum samples
Here is another premature output from the web based tool I'm working on.
As a side track to the midi-pch2 converter, I thought I would dredge up an old idea. The unpublished app allows you to load ROM images from old drum machines like the DX and DMX, resample by 1:2 or 1:4 and save them in a patch file.
The Oberheim used a companded 8 bit data format (a-law) which was supposed to give a 12 bit dynamic range.
Rather than converting to linear 8 bit, I kept the same format and replicated the companding DAC in the patch.
There aren't that many of these type of drum rom images out there so now i'm working on a wav > pch2 (using the same companding).
The patch has 8 samples, 1 per variation.
OBDX.pch2
80's drum roms
 Filename:  OBDX.pch2
 Filesize:  12.53 KB
 Downloaded:  4913 Time(s)
Electromagnetic Wave
G2 patch files: 38
PostPosted: Wed Feb 12, 2014 11:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Your projects are very interesting. Very helpful. I'm keeping an eye on it!
It's fun to change the tones manually with a patch like this! Again the "patch mutator" work well on this type of patch!
G2 patch files: 626
PostPosted: Fri Feb 14, 2014 5:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks
I have updated the patch attached in the op. I was thinking of getting better timing resolution by running 2 parallel chains and multiplexing the outputs. While experimenting I discovered that the sequencers could run at 12,000Hz if they are fed a signal from the clock divider in square mode.
The new version has the same samples but now they can go twice as high and you can play them from the keys.
Hope to get the wav file utility on line before the end of the weekend.
My plans were to chain the sequencers into the FX area, giving 1024 samples per variation but it seems Clavia has limited the number of consecutive seq modules to 36 :¬0
With a bit of automated variation changing it still could be quite useful.
Tim Kleinert
G2 patch files: 236
PostPosted: Sat Feb 15, 2014 4:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Sequencers as sample ROM -lovely idea! Smile
Instead of doing the sample pitching via changing the clock rate (which is jittered by the system frequency and thus creates artifacts), one could play back the sample at a fixed base rate into a delay line used as a keyboard-tracking resampler, which gives the benefit of sample interpolation, unlimited keyboard range and optional anti-aliasing.
I've just moved yesterday, and my whole life is packed up into 30 cardboard boxes and various hardcases Laughing, but I might try this out once.
EDIT: Addendum:
Yes, but the G2 numerical resolution is 24 bit, so actually you could cram three 8 bit samples into one sequencer stage. Of course, the encoding app as well as the playback circuit would be more complicated, but it's not impossible and would triple the sample time. 3*16*36=1728 samples.
G2 patch files: 626
PostPosted: Sat Feb 15, 2014 12:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Tim, I was hoping you would see this. There is plenty of room for improvement in the playback patch and I am sure you can come up with something amazing.
I have started a thread on the conversion processor here.
Tim Kleinert
G2 patch files: 236
PostPosted: Sun Feb 16, 2014 3:19 am    Post subject: Reply with quote  Mark this post and the followings unread
The 'sample playback via delay line re-sampler'-shtick is straightforward, I've used this technique many times for many purposes. It also has the benefit that the huge bulk of sequencers can move into the FX area, where 'stuff' is piped back to the voice area which only does the resampling -making polyphonic application a lot more feasible.
As mentioned, I've just moved and right now I don't even know where my G2Xs are Laughing, but I'll try to eventually get to it.
The other issue is causing more trouble: I've been trying to encode three bytes (8 bit) into a 24 bit word as used by the G2, in order to triple the available sample memory -and it doesn't want to work right now. Well, the encoding does work, but the decoding -getting the three bytes back 'out of there'- doen't work as intended, as I probably have false assumptions about the 24 bit fixed point numerical system of the G2 Sad We'll see...
G2 patch files: 626
PostPosted: Mon Feb 17, 2014 11:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is a simple de-multiplexer patch that clocks two rows of sequencers at Max frequency to effectively double the sample resolution.
You can see how much smoother the de-multiplexed output is in the screen shot.
And good news everyone, my original idea of having two banks, one each in the voice and fx area is still a go. More careful testing revealed that despite the LED's not woking, the extra sequencers continue to function so the limitation must simply be the editor LED protocol or something. AT audio rates, the LED is useless anyway.
Will hopefully get some more time to work on this soon.
multiplexsine.pch2
test patch for high(er) resolution rom playback project.
 Filename:  multiplexsine.pch2
 Filesize:  3.93 KB
 Downloaded:  4721 Time(s)
G2 patch files: 38
PostPosted: Tue Feb 18, 2014 3:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes ! I was going to tell you about this. I had this problem in the past and it is documented on the forum.
http://electro-music.com/forum/topic-39858.html
Very Happy Wow!!!
dorremifasol
G2 patch files: 49
PostPosted: Wed Mar 05, 2014 7:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Ian, this is amaaaaaaaazing!!
Albert
