vladosh
Audio files: 51
Posted: Wed Mar 30, 2016 8:58 am Post subject:
VCA (NLC) XMIX EFM PCB |
This is Xmix and VCA from CellF NLC schematic , prolly the same Sims VCA posted here , in aaddition to the vca i added the xmix 2 channel mixer from wildcat from EFM , pcb is tested and working , should work prolly better on 12V and the VCA performance is so-so ..comparing to other VCA's i've built , so i don't know why i share it when it's not the best vca , i built it so here it is
413.44 KB |
| Viewed: |
848 Time(s) |
 Download (listen) |
| Filename: |
printvcaxmix.pdf |
230.29 KB |
| Downloaded: |
876 Time(s) |
_________________ http://synthacks.blogspot.com/ шематикс |
Ayab
Posted: Thu May 24, 2018 12:03 pm Post subject:
Can anyone help me identify the IC's on this layout? Itching to get etching!
I have looked at the schematics referred to but they are the basis from which Vladosh has tailored the circuit himself.
Are these LM13700 and TL074?
Thanks for your help  Last edited by Ayab on Thu May 24, 2018 11:54 pm; edited 1 time in total |
vladosh
Audio files: 51
Posted: Thu May 24, 2018 12:49 pm Post subject:
yes the IC facing down is TL074 ,i've built this VCA but was not so happy with it ,there were some clicking ,maybe because it was designed for 12V and i used 15V ,it's working but i like MFOS vcas better _________________ http://synthacks.blogspot.com/ шематикс |
Ayab
Posted: Thu May 24, 2018 11:56 pm Post subject:
Hello and thanks so much for getting back to me.
I have etched an MFOS dual VCA and will be populating it soon.
Do you have a simple way to make it into a Xfader?
Thank you also for your very interesting Synthhacks blog  |
vladosh
Audio files: 51
Posted: Fri May 25, 2018 12:45 am Post subject:
i don't know how to convert it into fader ,you can find a xfade pcb layout on my blog but i'm not sure if i can recommend you that one ,i built it and it was working but there was minor bleed trough that was annoying ,maybe cause i made the vactrols myself .good luck with building _________________ http://synthacks.blogspot.com/ шематикс |
Ayab
Posted: Fri May 25, 2018 7:00 am Post subject:
Hi - Thank you
Will have a look for the Xfader on your blog. If I expect some bleed through it will be ok. |
cslammy
Ayab
Posted: Thu Jun 14, 2018 9:40 am Post subject:
| Thanks for the tip having a look at Fonik link now. Looks good, nice and simple from the parts layout. But there is no schematic or foil layout. Do you know where I can find one pls? |
cslammy
Posted: Fri Jun 15, 2018 8:48 am Post subject:
| Ayab wrote: | | Thanks for the tip having a look at Fonik link now. Looks good, nice and simple from the parts layout. But there is no schematic or foil layout. Do you know where I can find one pls? |
CL: I'll create a board/schemo/gerber using eagle and post it soon, but I don't think I'll have time to test it any time soon since I am working on a bunch of other things right now.
If you want, take the gerber and send it off to easy EDA, it would cost maybe $30 for 10 boards. To me that's easier/cheaper than spending a day breadboarding or using perf.
Stay tuned.... _________________ Visit my AUDIODIWHY blog and website |
cslammy
Posted: Fri Jun 15, 2018 9:57 am Post subject:
EFM xfader-gerber, eagle files, diagrams etc. NOT TESTED |
Hi again, I whipped up an eagle design for this.
As I said, it's not tested, but this is one of those "I can't see why it won't work" situations.
The ZIP file contains eagle 9.x brd and schem and the gerbers.
If anyone actually prints up the gerbers let me know if it works and I can make adjustments. I may run this the next time I do an easyeda run (it'd be $5 for 10 boards...) and if I get it working I'll post.
About the quickee layout: The xfade pot is 50K linear and to make this faster to conjure up in eagle I used a trimmer package, but you won't want to use a trimmer in real life, instead please solder your 3 pot wires to there (or you could wire in a VCA that passes DC if you want to "automate" this).
I could also do an eagle variation that uses a PCB mounted pot (you can get these cheap from small bear but it assumes certain front panel space requirements that may not work for you) if there is interest.
I image all the 47K resistors and 50K can be any value but should all be matched to at least 2% or better except the pot. Just a guess.
36.32 KB |
| Viewed: |
653 Time(s) |
23.2 KB |
| Viewed: |
633 Time(s) |
25.15 KB |
| Viewed: |
578 Time(s) |
 Download (listen) |
| Filename: |
EFMxfader-6-15-18take2.zip |
186.75 KB |
| Downloaded: |
557 Time(s) |
Ayab
Posted: Sat Jun 16, 2018 1:25 am Post subject:
Wow that is great thank you
Will try a home double sided etch for first time! : ) |
cslammy
Posted: Sat Jun 16, 2018 4:57 am Post subject:
No need for two sided ayab, I redid for single side. (I never had much luck fabbing 2 sided by myself....)
I include eagle sch and brd files.
Let us know how it goes!
57.2 KB |
| Viewed: |
421 Time(s) |
26.6 KB |
| Viewed: |
453 Time(s) |
| brd and sch Eagle 9.x files for single sided xfade board. Based on EFM wildcat crossfader. Untested. |
 Download (listen) |
| Filename: |
EFMxfade-6-16-18 eagle single layer.zip |
53.58 KB |
| Downloaded: |
432 Time(s) |
Ayab
Posted: Thu Jun 28, 2018 1:08 pm Post subject:
Just seen this. You rock thank you  |
gabbagabi
gabbagabi
Ayab
Posted: Mon Jul 02, 2018 1:55 pm Post subject:
Yes I would like to try and make the g.gabbi crossfader, thank you g.gabbi!
I will be running the Xfader on +/-12V do you think those resistor values would be ok? |
gabbagabi
Posted: Tue Jul 03, 2018 8:50 am Post subject:
that means u try out my idea? and report back if it is working? and then i make a little pcb for it?
or u will try out the pcb of the efm xFader?
both will run smoothly on 12V. |
Ayab
Posted: Wed Jul 04, 2018 4:11 am Post subject:
I can try out both. I think crossfading is a useful functionality.
And yes I will let you know how it goes. Thank you. |
gabbagabi
Posted: Wed Jul 04, 2018 10:31 am Post subject:
so i send you this,
please make double shure that i have done the mirroring right.
otherwise u could face problems with soldering the tl072. which is the reason why i use normally tl074, there it does not matter
good luck,
would be a pleasure to have done something usefull
 Download (listen) |
| Filename: |
xfader pcb.pdf |
200.02 KB |
| Downloaded: |
403 Time(s) |
 Download (listen) |
| Filename: |
xfader_part place.pdf |
217.91 KB |
| Downloaded: |
339 Time(s) |
