VCA (NLC) XMIX EFM PCB
Page 1 of 1 [19 Posts]
vladosh
Audio files: 51
PostPosted: Wed Mar 30, 2016 8:58 am    Post subject: VCA (NLC) XMIX EFM PCB Reply with quote  Mark this post and the followings unread
This is Xmix and VCA from CellF NLC schematic , prolly the same Sims VCA posted here , in aaddition to the vca i added the xmix 2 channel mixer from wildcat from EFM , pcb is tested and working , should work prolly better on 12V and the VCA performance is so-so ..comparing to other VCA's i've built , so i don't know why i share it when it's not the best vca , i built it so here it is
 Filesize:  413.44 KB
 Viewed:  849 Time(s)
printvcaxmix.pdf
 Filename:  printvcaxmix.pdf
 Filesize:  230.29 KB
 Downloaded:  877 Time(s)
Ayab
PostPosted: Thu May 24, 2018 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Can anyone help me identify the IC's on this layout? Itching to get etching!
I have looked at the schematics referred to but they are the basis from which Vladosh has tailored the circuit himself.
Are these LM13700 and TL074?
Thanks for your help Very Happy
vladosh
Audio files: 51
PostPosted: Thu May 24, 2018 12:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes the IC facing down is TL074 ,i've built this VCA but was not so happy with it ,there were some clicking ,maybe because it was designed for 12V and i used 15V ,it's working but i like MFOS vcas better
Ayab
PostPosted: Thu May 24, 2018 11:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello and thanks so much for getting back to me.
I have etched an MFOS dual VCA and will be populating it soon.
Do you have a simple way to make it into a Xfader?
Thank you also for your very interesting Synthhacks blog Very Happy
vladosh
Audio files: 51
PostPosted: Fri May 25, 2018 12:45 am    Post subject: Reply with quote  Mark this post and the followings unread
i don't know how to convert it into fader ,you can find a xfade pcb layout on my blog but i'm not sure if i can recommend you that one ,i built it and it was working but there was minor bleed trough that was annoying ,maybe cause i made the vactrols myself .good luck with building
Ayab
PostPosted: Fri May 25, 2018 7:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi - Thank you Smile
Will have a look for the Xfader on your blog. If I expect some bleed through it will be ok.
cslammy
PostPosted: Wed Jun 13, 2018 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
For adding crossfade, The EFM crossfader may work, out of the wildcat. I haven't tried to build this but the circuit looks simple enough.
http://www.modular.fonik.de/files/EFMforum/orgEFMfiles/wildcat_001.pdf
Scroll down to Cross mix-inverter.
Ayab
PostPosted: Thu Jun 14, 2018 9:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the tip having a look at Fonik link now. Looks good, nice and simple from the parts layout. But there is no schematic or foil layout. Do you know where I can find one pls?
cslammy
PostPosted: Fri Jun 15, 2018 8:48 am    Post subject: Reply with quote  Mark this post and the followings unread
CL: I'll create a board/schemo/gerber using eagle and post it soon, but I don't think I'll have time to test it any time soon since I am working on a bunch of other things right now.
If you want, take the gerber and send it off to easy EDA, it would cost maybe $30 for 10 boards. To me that's easier/cheaper than spending a day breadboarding or using perf.
Stay tuned....
cslammy
PostPosted: Fri Jun 15, 2018 9:57 am    Post subject: EFM xfader-gerber, eagle files, diagrams etc. NOT TESTED Reply with quote  Mark this post and the followings unread
Hi again, I whipped up an eagle design for this.
As I said, it's not tested, but this is one of those "I can't see why it won't work" situations.
The ZIP file contains eagle 9.x brd and schem and the gerbers.
If anyone actually prints up the gerbers let me know if it works and I can make adjustments. I may run this the next time I do an easyeda run (it'd be $5 for 10 boards...) and if I get it working I'll post.
About the quickee layout: The xfade pot is 50K linear and to make this faster to conjure up in eagle I used a trimmer package, but you won't want to use a trimmer in real life, instead please solder your 3 pot wires to there (or you could wire in a VCA that passes DC if you want to "automate" this).
I could also do an eagle variation that uses a PCB mounted pot (you can get these cheap from small bear but it assumes certain front panel space requirements that may not work for you) if there is interest.
I image all the 47K resistors and 50K can be any value but should all be matched to at least 2% or better except the pot. Just a guess.
 Filesize:  36.32 KB
 Viewed:  655 Time(s)
 Filesize:  23.2 KB
 Viewed:  634 Time(s)
 Filesize:  25.15 KB
 Viewed:  579 Time(s)
EFMxfader-6-15-18take2.zip
 Filename:  EFMxfader-6-15-18take2.zip
 Filesize:  186.75 KB
 Downloaded:  559 Time(s)
Ayab
PostPosted: Sat Jun 16, 2018 1:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow that is great thank you Very Happy
Will try a home double sided etch for first time! : )
cslammy
PostPosted: Sat Jun 16, 2018 4:57 am    Post subject: Reply with quote  Mark this post and the followings unread
No need for two sided ayab, I redid for single side. (I never had much luck fabbing 2 sided by myself....)
I include eagle sch and brd files.
Let us know how it goes! Very Happy
 Filesize:  57.2 KB
 Viewed:  423 Time(s)
 Filesize:  26.6 KB
 Viewed:  455 Time(s)
EFMxfade-6-16-18 eagle single layer.zip
brd and sch Eagle 9.x files for single sided xfade board. Based on EFM wildcat crossfader. Untested.
 Filename:  EFMxfade-6-16-18 eagle single layer.zip
 Filesize:  53.58 KB
 Downloaded:  433 Time(s)
Ayab
PostPosted: Thu Jun 28, 2018 1:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just seen this. You rock thank you Very Happy
gabbagabi
PostPosted: Sat Jun 30, 2018 4:46 am    Post subject: Reply with quote  Mark this post and the followings unread
if anyone is interested-
and noone find an error-
ill pdf-it
regarding your schematic R2 must be higher in my opinion,
if u feed in two 10Vpp signals, u will get only 5Vpp signal out
after simulation i would suggest to try a value of 120k to 135K (two 270k parallel) then u get out a signal that is slightly under 10Vpp when the fader is full on one side, and slightly over 10Vpp in the middle
if u use all 100k, what i would do, this value is then of course 240k to 270k
 Filesize:  81.9 KB
 Viewed:  374 Time(s)
gabbagabi
PostPosted: Sat Jun 30, 2018 5:41 am    Post subject: Reply with quote  Mark this post and the followings unread
and with this u should not have to worry about over/under shooting signals
beside the lower partcount
 Filesize:  27.92 KB
 Viewed:  378 Time(s)
Ayab
PostPosted: Mon Jul 02, 2018 1:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes I would like to try and make the g.gabbi crossfader, thank you g.gabbi!
I will be running the Xfader on +/-12V do you think those resistor values would be ok?
gabbagabi
PostPosted: Tue Jul 03, 2018 8:50 am    Post subject: Reply with quote  Mark this post and the followings unread
that means u try out my idea? and report back if it is working? and then i make a little pcb for it?
or u will try out the pcb of the efm xFader?
both will run smoothly on 12V.
Ayab
PostPosted: Wed Jul 04, 2018 4:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I can try out both. I think crossfading is a useful functionality.
And yes I will let you know how it goes. Thank you.
gabbagabi
PostPosted: Wed Jul 04, 2018 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
so i send you this,
please make double shure that i have done the mirroring right.
otherwise u could face problems with soldering the tl072. which is the reason why i use normally tl074, there it does not matter Smile
good luck,
would be a pleasure to have done something usefull
xfader pcb.pdf
 Filename:  xfader pcb.pdf
 Filesize:  200.02 KB
 Downloaded:  404 Time(s)
xfader_part place.pdf
 Filename:  xfader_part place.pdf
 Filesize:  217.91 KB
 Downloaded:  340 Time(s)
