PHOBoS' euro-rack modular
Page 1 of 3 [70 Posts]
Goto page: 1, 2, 3 Next
PostPosted: Sat Jan 16, 2016 9:06 am    Post subject: PHOBoS' euro-rack modular
Subject description: it's another synth! (in progress)
I couple years ago I bought two 19" rack cases. I modified one of them, turned it over with the front facing down
and used it as the case for my modular lunetta.
I had been thinking about using the other case for a synth with some chaos modules and maybe some (VC)LFO's.
I wasn't really planning on starting on it yet and first finish up some other stuff but for xmas I got a PCB set
from AlanP (thanks Alan! Very Happy) for a "Driven Double Well Chaos Module" (Ian Fritz design), to be used as a euro module.
I also designed a PCB set for the WaveWiper to be used as a euro module as well. And to test those
I need a case with a PSU.
So that's what I started with. I made a LM317/LM337 regulated -12V/+12V supply powered by a wall wart.
Reasons for using a wall wart are weight, size, safety and I didn't have a suitable transformer.
Here are some photos and the schematic.
Euro PSU -12V/+12V
 Filesize:  93.18 KB
 Viewed:  1069 Time(s)
DES
PostPosted: Sun Jan 17, 2016 12:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice clean build. 🙂. Looking forward to the rest.
www.davesneed.com
PostPosted: Sun Jan 31, 2016 4:07 pm    Post subject: Melt Yer Face
Subject description: Multi/Interface module
All my other synths use 1/4" jacks so I need something to convert those to 1/8". My initial idea was a panel
with both 1/4" and 1/8" sockets but you can't get a lot of 1/4" on a panel. So instead I made a panel
with 8x 1/8" sockets connected to a 9P sub-D connector. This will plug into a breakout box with 1/4" sockets
which, as an added bonus, I can put next to my synths. when nothing is plugged in on the other side it
also acts as a multiple. It can also be used as a multiple when something is plugged in but than I have to
leave a minimum of 2 sockets unused. Since there was some panel space left I also added 2 attenuators.
 Filesize:  96.06 KB
 Viewed:  827 Time(s)
 Filesize:  123.14 KB
 Viewed:  825 Time(s)
 Filesize:  127 KB
 Viewed:  820 Time(s)
 Filesize:  123.92 KB
 Viewed:  880 Time(s)
 Filesize:  59.71 KB
 Viewed:  868 Time(s)
PostPosted: Fri Feb 19, 2016 2:17 pm    Post subject: toner transfer front panels Reply with quote  Mark this post and the followings unread
I had seen some people having nice results with the toner transfer method to make front panels so I gave that a try myself.
I first tried it with some regular paper but that didn't work very well. So next I tried some pages from a couple of different
magazines. I got much better results but the toner didn't take 100% and I also got some of the print of the magazines itself
on it. But what was transferred looked good and was pretty scratch proof.
So I ordered some photopaper to see if that would work any better. What I only relalized after I got it was that it was
made for inktjet printers. It didn't say that it wasn't suitable for laserprinters though so gave it a try anyway.
Well,.. when it came out of my printer it sounded like unwrapping some candy Shocked The print had cracks in it and the
paper had become all bubbly. So that did NOT work. I looked for a bit more info and actually came across some warnings
against using glossy inktjet paper in a laser printer. Apparently the glossy coating can melt and stick to the fuser,
ruining the printer. Luckely that didn't seem to have happened. However there are people who are getting great results
with it even using the exact paper I tried. So you could try it but be warned!
I read up some more about toner transfer method and somewhere someone mentioned getting great results using cheap transfer
paper from china available on ebay. So I ordered some of that (pretty cheap indeed and no shipping costs!). That was all
about a month ago and I had almost given up on receiving the paper when it arrived yesterday Laughing
So I could get back to testing. It came out of my printer looking great, but while cutting it to size I did notice that the
toner didn't stick very well to it. Of course that's exactly what you need to make good transfers but you also have to be
very careful when handeling it. The first tranfer I made looked horrible and much worse than the ones I had made using the
magazine paper. Confused So I gave it another try. Sofar I had been emerging the (very HOT!) aluminium in water after the transfer
to rub of the paper. But the scrap piece I was testing on didn't really fit in my sink so only a small part got emerged this
time. Now, when I pulled of the paper (you don't have to rub this transfer paper of) the part that was emerged looked bad
again but the part that wasn't looked great Very Happy So on the next try I just let it cool of by itself and that seem to do the trick.
I made 4 panels sofar. the 'Melt Yer face', EZChaos for which I got the PCBs from AlanP and two WaveWipers. I had some trouble
getting the large black area of the WaveWiper panels to tranfer 100% but after a couple of tries it worked. Here are some photos.
Melt Yer Face module
 Filesize:  118.8 KB
 Viewed:  865 Time(s)
EZ Chaos / Driven Double-Well Chaos
 Filesize:  105.16 KB
 Viewed:  831 Time(s)
 Filesize:  117.98 KB
 Viewed:  891 Time(s)
WaveWiper
 Filesize:  143.86 KB
 Viewed:  840 Time(s)
WaveWiper
 Filesize:  125.64 KB
 Viewed:  824 Time(s)
L´Andratté
PostPosted: Fri Feb 19, 2016 4:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked compress transformer
cyclic
PostPosted: Mon Feb 22, 2016 10:52 pm    Post subject: Re: toner transfer front panels Reply with quote  Mark this post and the followings unread
hey,
you've reminded me that I keep meaning to post this somewhere:
I have excellent toner transfers using the backing paper from sticker sheets. We use these at work for patient labels and when I'm done I just pull off all the unused stickers and use the shiny backing paper.
It seems kind of wasteful to chuck out the actual product, but this is healthcare, and often they print out a whole sheet, use one sticker and then shred the rest anyway...
I can't understand why no-one else has mentioned this anywhere before!
(and sorry that my mention here means its likely to get lost in an obscure corner...)
Anyway, It takes the image from the laserjet perfectly, then it transfers very nicely with half a dozen runs through the laminator and then the sheet JUST FALLS OFF. I actually think that if the sheet were taped onto the PCB it would actually just fall off after 2 or three passes of the laminator.
There is NO 'rubbing under water'
There is NO 'transfer of the original image.
For me personally, the failures have been from the density of the ink itself and the slowness of etching I've done with muriatic acid + peroxide. So I've just ordered some pulsar foils to remedy the first problem and am going ot heat up the etchant next time for the second.
Also, since I'm using work printers too, I have no control over 'get a new cartridge,' but I do know that the printer at my old site was better than the identical one at my new site. Go figure.... Sometimes if the artwork doesn't have any tiny traces I do two overlays to double up the ink, but hopefully the pulsar foils will mean I don;t have to do that anymore.
So, I'm not saying I have excellent home made PCBs, but I think that I DO have excellent success on the ACTUAL TONER TRANSFER steps of the process.
I just went out and checked the brand of our sticker sheets, and it looks like they are more or less no-name brand (after all, this is public health care here!) so I assume that any brand should give similar results.
Just for completeness, curerntly I am using sheets with about 10 small stickers all in one big block, and then a whole bunch of smaller ones up above it, but we have previously had sheets which have probably 14 stickers in two columns instead.
I'm planning on doing some in the next week or so, so if anyone cares, pipe up and I'll take some photos along the way...
cheers
Lance
PostPosted: Tue Feb 23, 2016 3:27 am    Post subject: Re: toner transfer front panels Reply with quote  Mark this post and the followings unread
I am not surprised since that is exacly what the transfer paper looks/feels like Laughing One of the videos I came across
while looking for more info on it actually mentioned using the backing paper of self-adhesive labels. So yeah if you have
easy access to it, it is perfect.
Oh and I thought about using a laminator but it would have to be able to take 2mm panels, and it would also need
a lot more heat than a PCB which only has a very thin layer of copper. If I would stumble upon a cheap one at
a thriftstore I might give it a try, but I have no way of knowing beforehand if one would be suitable and it might even
break in he process. So for now I just use an iron.
solaneu
PostPosted: Wed Mar 09, 2016 3:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi PHOBoS, I have a question. Looking at your MeltYerFace module, I see you mounted jacks with solder lugs on a perfboard. They seem intact so how did you manage to squeeze them through those holes?
PostPosted: Wed Mar 09, 2016 4:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
I drill 2.5mm holes for 3 of the pins, the 4th one can just be pushed through.
You can probably use a smaller drill but that's what I have and works.
The holes might be a bit hard to see because of the solder so here is a close
up of another board I am working on. Because the holes remove all the
copper I use some small pieces of wire to secure the pins.
 Filesize:  288 KB
 Viewed:  651 Time(s)
PostPosted: Fri Apr 08, 2016 4:29 pm    Post subject: Melt Yer Face breakout box Reply with quote  Mark this post and the followings unread
I finally got some sockets to built the Melt Yer Face breakout box Very Happy
 Filesize:  213.63 KB
 Viewed:  617 Time(s)
 Filesize:  223.45 KB
 Viewed:  613 Time(s)
PostPosted: Sun Apr 10, 2016 1:29 pm    Post subject: Moth Mixer module Reply with quote  Mark this post and the followings unread
I also got some pots so I can finish some modules. Here is the first one, the Moth Mixer. (yes those are butterflies on the panel)
I wanted a simple mixer but I added some extra features. With the resistors wired to the switch contacts of the input sockets an offset
voltage can be added when nothing is plugged in, +10V with the pots connected to A1/B1 and -10V with the pots connected to A2/B2.
Besides using it as an offset control it could also be used to create a DC voltage. Both mixers have an inverted output and there is a
switch to link one of the outputs of mixer A to mixer B creating a 4 input mixer. I also added some indicators that light up if the output
voltage is lower than -5V (red) or higher than +5V (green).
I made one mistake. When I drew the PCB layout I somehow labeled the 130K resistors as 360K Confused so that's also what I
soldered on the PCB. They are located in a spot where I couldn't replace them but I managed to solder some resistors in
parallel to bring them down to the correct value.
 Filesize:  35.4 KB
 Viewed:  690 Time(s)
 Filesize:  200.23 KB
 Viewed:  628 Time(s)
 Filesize:  227.75 KB
 Viewed:  583 Time(s)
 Filesize:  159.57 KB
 Viewed:  596 Time(s)
PostPosted: Sun Apr 10, 2016 4:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
And another one finished: the Yusynth Quadrature VC-LFO.
It didn't go a slow as I wanted it to be so I replaced the 10nF caps with 100nF ones.
After I had done that I wondered what the trimpot was for. doh So now it can go
very slooooooooooooooooooooooooooooow.
I should get some new sharp drillbits so holes will actually be where I want them.
 Filesize:  181.48 KB
 Viewed:  619 Time(s)
 Filesize:  218.72 KB
 Viewed:  612 Time(s)
PostPosted: Wed Apr 13, 2016 11:27 am    Post subject: Reply with quote  Mark this post and the followings unread
And the last one for now: The Wavolver II (with an extra Pulse 2 output).
 Filesize:  248 KB
 Viewed:  573 Time(s)
 Filesize:  245.09 KB
 Viewed:  618 Time(s)
DES
PostPosted: Sun Apr 17, 2016 2:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice work -as usual! Smile. Your graphics are coming out really well...I've had no success so far. Pretty much decided to pursue engraving.
www.davesneed.com
PostPosted: Sun Apr 17, 2016 10:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
put it on the spot where you want a hole and hit it with a hammer, it will give you a dent where you place your bit and start to drill.
your drillbit will never move again. (you could also use a sharpend nail for it...)
PostPosted: Mon Apr 18, 2016 5:04 am    Post subject: Reply with quote  Mark this post and the followings unread
@DES: Thanks Very Happy yeah I am surprised myself how well it works, especially for small lines and text.
@Grumble: I always use a center punch but dull drillbits just prefer to move horizontally instead of cutting through the panel.
It does make a bit of a difference if I use a drillpress or do it by hand and adding some oil also helps. But the best method
is just to use sharp bits which cut through a panel in mere seconds.
Cfish
PostPosted: Sun Apr 24, 2016 6:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
You build some very neat looking modules PHoBoS. You have inspired me to take some time doing some wire clean up in my modules.
PostPosted: Sun Nov 20, 2016 6:55 am    Post subject: Roland 100m ADSR with cycle mode Reply with quote  Mark this post and the followings unread
I finished 2 Roland 100m ADSR modules with PCBs from LFLab who added an End of Cycle output to the design. I was immediately curious if it
would be possible to use this output to turn the ADSR into an LFO by connecting this output to the GATE input. I tested it but it didn't work.
So I took a closer look at it and noticed 2 problems. First of all the E.o.C. output is a pulse output and as a result it is usually low. So if you would
connect it to the GATE input it would never trigger the ADSR unless you jumpstart it. Using the output of comparator IC2a instead solves this
problem but there is a second problem. As soon as the ADSR starts its cycle and the output voltages rises the output from this comparator
becomes low and as a result the ADSR immediately goes into Release. So even if it cycles it would be at a fairly high frequency and the output
amplitude would be very low.
To solve this I added a Flip-Flop made with NAND gates. So when the ouput of Comparator IC2a goes low the ouput of the Flip-Flop stays
high preventing the ADSR from going into Release. Of course without resetting the Flip-Flop it would get stuck at Sustain because the GATE
input is still high. Luckely the ADSR already has another comparator that changes state at the end of Attack and I used this to reset the Flip-Flop.
So now it cycles between Attack and Release (it skips Decay and Sustain)
Initially I was only using NAND gates IC3c and IC3d as inverters because the Flip-Flop triggers on a high to low transition. But NAND gates have
2 inputs and because the GATE input isn't connected to the ADSR in cycle mode I can use it to enable/disable the Flip-Flop turning it into a gated
LFO. By adding a resistor btween V+ and the switch connection on the GATE input it will still cycle when nothing is connected. This does have
another effect though which I guess is a bonus feature. In normal ADSR mode when nothing is connected to the GATE input it will get stuck in
Sustain, which means you can set a DC output voltage with the Sustain control. I also added another input between the output of the IC2a
comparator and the input of the Flip-Flop that functions as a trigger input.
This all worked fine but there was one minor issue. The NAND gates need a fairly high voltage to trigger, so using +5V which is pretty standard
for gate outputs wouldn't work. To solve this I added 2 more comparators to the inputs of NAND gate IC3c.
 Filesize:  195.62 KB
 Viewed:  669 Time(s)
 Filesize:  224.39 KB
 Viewed:  645 Time(s)
 Filesize:  88.78 KB
 Viewed:  744 Time(s)
Audio files: 160
PostPosted: Sun Nov 20, 2016 11:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks great , love the logo Wink
alanwilder81
PostPosted: Mon Nov 21, 2016 4:55 am    Post subject: Reply with quote  Mark this post and the followings unread
phobos,
i truly like that ADSR module ! Roland FTW ! Smile
i've been a Roland sound fan forever, in particular of the Jupiter 4 and Promars raw filter.
Do you have any Roland filter schematics,be it clone or modification of the original? i've been on the hunt for long, but internet offers 70's schematics which are confusing at best and use obsolete components Confused Confused
I'd be happy with modern schematics of some sort ! Smile
cheers
LFLab
PostPosted: Mon Nov 21, 2016 7:50 am    Post subject: Reply with quote  Mark this post and the followings unread
VCF's are not ADSR's Very Happy
But AMsynths has a range of Roland filters, and Frequencycentral has the 100m VCF (system100 vcf), I think most of these have (redrawn) schematics available.
alanwilder81
PostPosted: Mon Nov 21, 2016 8:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Flab
LOL Very Happy
i know filters do behave slighty differently from envelope generators Laughing Laughing Laughing . I just took advantage of Phobos coming up with this baby to have some infos. And there we go, you mentioned that company.
Is there any way to get the schemos without having to buy the modules?
I've known about them for long, they are tempting, but they come at a steep price at least for my pocket Crying or Very sad
thanks anyway
L´Andratté
PostPosted: Mon Nov 21, 2016 9:58 am    Post subject: Reply with quote  Mark this post and the followings unread
http://fa.utfs.org/diy/roland_filters/
Do you mean those? Wink
alanwilder81
PostPosted: Mon Nov 21, 2016 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
yes ,those very ones Smile Amazing filters collection !!
i found them long ago,however i think they arent very clear. Or those ancient filters employ hard to find components.
I really wish i could get any of the to work,becasue that's the sound im definitely after Very Happy
L´Andratté
PostPosted: Mon Nov 21, 2016 10:34 am    Post subject: Reply with quote  Mark this post and the followings unread
iirc Oliver Gillet has recreated the 4-pole roland style vcf with 13700s on his site mutable instruments, look at the shruti filter boards or ripples, he provides all the schematics...
Edit:http://mutable-instruments.net/shruthi1/build/smr4mkII
