today> Twyndyllyngs - canceled because of back pain - sorry Chez Mosc
Single transistor VCA circuit
Page 4 of 4 [80 Posts]
gasboss775
PostPosted: Thu Jan 26, 2017 4:10 pm    Post subject: MOSFET VCA Reply with quote  Mark this post and the followings unread
It is possible to make a MOSFET based VCA too. Here is a possible circuit:
I haven't breadboarded this so it's possible that some of the component values might need tweaked. The opamps can be TL071/72/74 or TL081/82/84
 Filesize:  90.54 KB
 Viewed:  693 Time(s)
danja
PostPosted: Wed Nov 29, 2017 5:06 am    Post subject: Capacitor values Reply with quote  Mark this post and the followings unread
Thanks for the circuit. I'm going to play on the breadboard later, but my guess is that the input cap C1 should be at least 100nF, will depend a bit on the value of R1 so as not to block bass. C2, C3, I imagine should both be pretty small, maybe 1nF - 10nf, so as not to block the treble.
gasboss775
PostPosted: Sat Dec 02, 2017 8:12 am    Post subject: Reply with quote  Mark this post and the followings unread
richardc64 wrote:
Yes, but I've seen the same basic idea used with other op amps. The scrap below, using a TLO72, is from the TR909 clone rim shot. I've also seen an LM324 used.
I like this type of VCA for percussion circuits as the distortion and control signal breakthrough tends to accentuate the attack portion of the sound, which is generally desirable in a percussion sound.
 Filesize:  6.28 KB
 Viewed:  9960 Time(s)
blakeAlbion
PostPosted: Wed Jul 01, 2020 4:59 pm    Post subject: "Roland's DR-110 percussion unit"
Subject description: Simple VCA
I breadboarded the 1-transistor, 1-diode VCA shown above.
At first the sound quality was only suitable for white noise.
But I was able to improve the circuit. Sorry I don't have a diagramming tool.
By adding a feedback resistor of about 220K across the collector and emitter, and moving bias resistor R1 from +V to ground, I was able to keep the sound clean enough for a lot of cheesy drum sounds.
This with a "decay-only" envelope generator provided by another NPN transistor will meet my requirements. I think.
feedback resistor
 Filesize:  42.71 KB
 Viewed:  6834 Time(s)
Ricko
Audio files: 27
PostPosted: Mon Sep 07, 2020 7:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Since we are on the subject, here is an unusual kind of 2-transistor VCA I have been toying with, as a quasi 4Q multiplier. Expressly lo-fi: I wanted it for inside a waveshaper, so fiddling with the shape is a feature not a bug!
First up, the wide pic is a voltage controlled attenuverter, in the picture roughAttenuator.png.
In the trace: the audio signal is the blue; the control signal is the red: this is first fullwave rectified, to give the green: this green signal goes to base of the transistors, causing the output in yellow.
You can see that when the green is 0.25V, it makes the inputs to the op-amp cancel each other out, so you get 0V on the output. As the green goes above .25V you get the blue multiplied by the green, but as the green goes goes below .25V (to 0V) the output is inverted. (The asymmetry you can see is just the operation of the fullwave rectifier.) (You can perhaps see there are little horns at the polarity turn too.)
And there is a variant on this (in the picture roughAmplifier.png) which acts more like a VCA.
 Filesize:  16.7 KB
 Viewed:  410 Time(s)
 Filesize:  57.85 KB
 Viewed:  359 Time(s)
 Filesize:  11.37 KB
 Viewed:  416 Time(s)
