wackelpeter
Audio files: 10
Posted: Wed Sep 27, 2017 8:12 am Post subject:
Circuits and ideas for clocking/trigger/timing applications |
As big as my DIY home brew'n stripboard systems grows i think it's time to add some further logic and Timing functions to the whole.
Already havev a lot of dividers some logic and also some random modules
(3xYusynth divider, 1XCGS Master divider,2xCGS Pulse divider, 2xCGS Gate Sequencer,2xCGS Burst Generator, CGS Gated Comparator, CGS VC-Divider, Fonik VC Clock, some NAND, XOR, XNOR OR and AND plus a few simple binary counters i made from CD4060 and CD4024?? (can't remember right now)
...but i want to add some more dividers and possibilities of rhythm, clock and trigger Generation.
As sure as there are some more counters and simple logic modules included i also think about such stuff as Shift Registers, multiplexers, flip-flops and latches...
Currently have a CD4015 shift Register on breadboard which seems useful as a comeplex rhythm/Timing Generator when fed with different divisions of a clock signal at it's data and clock Inputs, generating interesting repetitive patterns.
Have had a look at the most suspect sub-Forum (The Lunetta-Forum) to hopefully find some ideas but there are so many circuits that could be of interested so i gave up for the first time. Unfortunately not many of them had Sound examples to catch my interest immediately or that i can get an idea of how it would sound/work.
Anybody here with some cool hints and advices for some circuits i should give a try on breadboard and of course schematics? _________________ https://soundcloud.com/bastian-j |
wackelpeter
Audio files: 10
Posted: Wed Sep 27, 2017 9:29 am Post subject:
Thanks Phobos, there seem to be some cool suggestions there.
The euclidian rhythm Generator already caught my interest but i wasn't sure, if i will ever try to breadboard this as there are more than 2 Chips involved.... mostly i simply heat the soldering iron and begin to solder when something catches my interest no matter how big the circuit is... Breadbording is a totally different thing to me, which i mostly tried to avoid...
But as said i have so many logic IC's in my bin, i must get rid of them and build something with them... and as Christmas is very near, i need some blinky lights too... so there's no excuse to not try any of those suggested modules
Guess i should start the PSU for this small case today as i today got hold of a 16V AC wall wart with 500mA current Rating which seems to be enough for those things i have in mind... _________________ https://soundcloud.com/bastian-j |
piedwagtail
Posted: Wed Sep 27, 2017 12:24 pm Post subject:
For me, PHOBoS's circuit of choice is the NANDulator with large capacitors; 10uf and above.
R |
Posted: Thu Sep 28, 2017 12:24 pm Post subject:
I honestly haven't even tried it at very low speeds,. but the output is a 1-bit digital signal so yes it could be used here.
Also don't underestimate the patterns you can get with a Linear Feedback Shift Register which you already have the parts for. (nice for christmas too)
| wackelpeter wrote: | | Guess i should start the PSU for this small case today as i today got hold of a 16V AC wall wart with 500mA current Rating which seems to be enough for those things i have in mind... |
keep in mind that this is about 21V DC so if you would bring this down with a linear voltage regulator it could get pretty hot.
also, is this a measured voltage ? as it can vary quite a bit depending on the load. _________________ "My perf, it's full of holes!"
wmonk
Joined: Sep 15, 2008 Posts: 529 Location: Enschede, the Netherlands
Audio files: 15
Posted: Thu Sep 28, 2017 6:49 pm Post subject:
I would recommend adding some gate delays, very useful for triggering those semi-synchronized envelopes, amongs a range of posibilities.
The one I use are from Ian Fritz AD/AR (hey I notice his website is down... )
And if you like to generate gates and triggers from CV signals, Ians TGTSH is a very nice tool.
Now where are those schematics? It seems both his website and the Bridechamber are down.
Sorry, this really seems to be as we say in Dutch: "iemand blijmaken met een dooie mus"
- Woody _________________ Weblog! |
gabbagabi
Posted: Fri Sep 29, 2017 1:22 am Post subject:
cool phobos stuff!
dont know witch catches me more,
since today i almost ignored the digital stuff, but as i saw the Sierpinski triangle,
i love those moments when u see an open door where the moment before was only a wall
so for the spiritual morning
cu,cheers,bb |
wackelpeter
Audio files: 10
Posted: Fri Sep 29, 2017 8:18 am Post subject:
| PHOBoS wrote: |
also, is this a measured voltage ? as it can vary quite a bit depending on the load. |
Thanks again for this nice suggestion, will have a look what this LFSR is doing and if it fits within my thoughts.
The 16VAC are measured and normally a bit too low regulate it down to 15V, maybe i forgot to tell that i want to adapt most circuits to my 15V rails. There are plans for 2-3 15V modules already, sequential switch, the serge programmer perhaps... But i can also regulate those 15V down to 12,9 or 5 if needed in some Special cases... The current consumption i would estimate within the range of 200-300mA, so that should work and i have as i had no others used very big heatsinks, each the volume of a cigarette package...
Only have to have a look at the Input signals and condition them for 15V use...
To all the others contributing ideas, great thanks for those too... now that the gate delay is mentioned i should maybe add some of them too... already have one of those Ian Fritz delayed AD/AR but some more or just some delays could not harm...
As the TGTSH is mentioned, there are not many circuits in this Forum i haven't build yet, apart form the Lunetta sub-Forum. So it happens that i have 2 of these.  _________________ https://soundcloud.com/bastian-j |
wackelpeter
Audio files: 10
Posted: Mon Oct 02, 2017 9:46 am Post subject:
Nearly finished the first circuit for my small clocking, sequencing and logic box...
Unfortunately i ran out of pots, LED holders and sockets (just got 100 of them 3 weeks ago)
But it's working so far... It's a 8 step sequencer with CV out and individual gates for each step and also via switch pulses and a gate out for the selected steps and as i had no on(off/on Switches at hand the inverted Version of those... generated from a NOR with one Input to gnd and the other gate to clk and the other both Inputs fed via the Switches through the Signal from the individual gate out... This creatures components or subcircuitry are "stolen" from the MFOS 10 Step seqencer, Yusynth clock divíder and the CGS gate sequencer...
So far i've measured 35-38mA on the positive rail, on that Panel i've plan to build two simple versions of a 4017 Counter 10 steps each (bottom rows) and some logic...
Then i have a second Panel of the same size which will hopefully Feature some of the above suggested circuits...
I estimate that i will be okay with the small PSU i've build, especially regarding the CV Output of the sequencer... I left some space for some additional electrolytes and furthermore could switch to a stronger wall wart.
554.32 KB |
| Viewed: |
283 Time(s) |
1.11 MB |
| Viewed: |
278 Time(s) |
