today> Twyndyllyngs not postponed Chez Mosc
808 Mid Tom in one-sided Euro format
Page 1 of 1 [10 Posts]
jbeuckm
Audio files: 9
PostPosted: Thu Apr 21, 2016 9:34 pm    Post subject: 808 Mid Tom in one-sided Euro format Reply with quote  Mark this post and the followings unread
Verified working. Needs separate pink noise source. Should work for LowTom / HiTom values too. Designed for this chunky 4PDT toggle:
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?search_type=jamecoall&catalogId=10001&freeText=2181204&langId=-1&productId=2181204&storeId=10001&ddkey=http:StoreCatalogDrillDownView
Eagle files:
https://github.com/jbeuckm/808-MidTom-MidConga/releases/tag/v0.1
 Filesize:  169.68 KB
 Viewed:  662 Time(s)
LFLab
PostPosted: Fri Apr 22, 2016 1:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Chunky indeed, looks great, Joe!
vladosh
Audio files: 51
PostPosted: Thu May 31, 2018 11:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for sharing these layouts ,i got these pcb's made for me ,was wondering if anyone can share a parts view of the board , just reinstalled my computer and it wouldn't install eagle , i have some print screen images of the boards with the parts but it's not easy to read .
thanks
vladosh
jbeuckm
Audio files: 9
PostPosted: Thu May 31, 2018 11:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
I made the values more visible and added an image of the layout here: https://github.com/jbeuckm/808-MidTom-MidConga
vladosh
Audio files: 51
PostPosted: Thu May 31, 2018 11:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks a lot for that , can you do it for the noise source ,thanks Very Happy
vladosh
Audio files: 51
PostPosted: Thu May 31, 2018 11:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
was thinking to make two of these one - hi tom ,one mid ,made the craig anderton hip bass ,and one rimshot and that will be enough for this box Smile
jbeuckm
Audio files: 9
PostPosted: Fri Jun 01, 2018 2:07 am    Post subject: Reply with quote  Mark this post and the followings unread
https://github.com/jbeuckm/808_Noise
vladosh
Audio files: 51
PostPosted: Fri Jun 01, 2018 2:52 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks a lot ,cheers
Snaper
PostPosted: Wed Sep 19, 2018 2:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Just a quick question, arhm, three, actually.
How / where should you connect the noise source and what does the big switch?
Are all of your 808 boards verified? ... you know, winter comes, will have a lot of free time Very Happy
vladosh
Audio files: 51
PostPosted: Fri Sep 21, 2018 1:35 am    Post subject: Reply with quote  Mark this post and the followings unread
i built this one and as i recall of checking the capacitors it's hi-tom ,i think .. you may check that before building .the switch is for tom/conga ,and the noise source is to be connected in the pink noise input (you'll need to make noise separate) ,had to turn the trimmer all the way down so the noise would make sense
