<on air> Twyndyllyngs - not canceled Chez Mosc
2019/2020 BUILD PHOTOS
Page 5 of 6 [139 Posts]
PostPosted: Tue Mar 31, 2020 3:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice, and the housing ,seems totaly appropriate to me πŸ˜πŸ‘πŸ»
my synth
PostPosted: Tue Apr 07, 2020 10:51 am    Post subject: Reply with quote  Mark this post and the followings unread
The secundary board for the drum sequencer (isn't 3D printing great πŸ˜‡πŸ‘πŸ»)
Top input resets the sequencer to first step, second connector Is the output of the clock, one pulse for every step.
Then a button for tap-tempo and a trigget input.
Below that a midi output connector with activity Led.
Next.... Software πŸ™ˆ
 Filesize:  8.84 MB
 Viewed:  399 Time(s)
my synth
PostPosted: Mon Apr 20, 2020 12:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Nintendo Wii Nunchuck Module
https://youtu.be/s3ADI7035gY
 Filesize:  1.45 MB
 Viewed:  368 Time(s)
my synth
PostPosted: Mon Apr 20, 2020 12:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Reverb/Echo module inspired by the Favorite Reverb/Echo module as designed by Juanito Moore (on this forum known as Hashtag Octothorpe.
https://youtu.be/7xiZvJM4k3c
 Filesize:  405.17 KB
 Viewed:  401 Time(s)
my synth
PostPosted: Fri Apr 24, 2020 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
This one's been on the backburner for awhile. VCF from the MS-10, using the Korg35 circuit. The input has far too much gain on it at the moment -- it's very easy to swamp the filter entirely, so nothing gets filtered at all. But it does work nicely once the input level is set correctly!
808 Snare circuit. Again, backburner... this one had a really embarassing mistake that caused it to be benched for a few years (a few, he says.) But now it works nicely.
Audio files: 160
PostPosted: Fri Apr 24, 2020 2:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice builds Smile
PostPosted: Fri Apr 24, 2020 7:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi-hat module, both open and closed hat. The sound... is not amazing, but it is vaguely hi-hat-like.
Audio files: 160
PostPosted: Tue Apr 28, 2020 3:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Great you caught that tricky resistor Alan , glad it works fine now , nice build Smile
PostPosted: Tue Apr 28, 2020 5:28 am    Post subject: Reply with quote  Mark this post and the followings unread
nice builds grumble and alan.
MapacheRaper
PostPosted: Mon May 04, 2020 5:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fantastic builds, guys!
Grumble, how itΒ΄s going the sequencer? Do you have a thread for it anywhere?
PostPosted: Tue May 05, 2020 4:36 am    Post subject: Reply with quote  Mark this post and the followings unread
No, not yet
my synth
PostPosted: Fri May 08, 2020 2:16 am    Post subject: Reply with quote  Mark this post and the followings unread
6 channel mono in/stereo out eurorack audio mixer with individual volume and pan control and mixed volume control.
 Filesize:  1.1 MB
 Viewed:  236 Time(s)
my synth
PostPosted: Fri May 15, 2020 3:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Today I finished my drumkit. The sequencer needs some more programming.
http://youtu.be/hKxWkB8Dxms
 Filesize:  1.32 MB
 Viewed:  237 Time(s)
my synth
PostPosted: Wed May 27, 2020 11:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Eeprom programmer for 28c512 eeprom (64k x 8bit)
my synth
kaputtpanzer
Audio files: 15
PostPosted: Tue Jun 23, 2020 5:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is a little drone synth I made. It is just a prototype now, but works quite well (but there are one or two little issues). There is a VCF included which is inspired by the Oberheim SEM VCF and it sounds pretty good. I added a little demo clip (sorry for the poor quality)...
 Filesize:  1.61 MB
 Viewed:  205 Time(s)
 Filesize:  1.46 MB
 Viewed:  188 Time(s)
dronea.mp4
 Filename:  dronea.mp4
 Filesize:  40.64 MB
 Downloaded:  256 Time(s)
raccooneatingcacti
PostPosted: Fri Sep 04, 2020 7:31 pm    Post subject: My terrible DIY modules so far
Subject description: Please send perfboard design help
I have lots to learn... Elders of perfboard circuit design, bless me with your knowledge!(or a link to it)
I know these images will disturb most if not all of you... but sadly, this is my current definition of "success."
two thomas henry 555 attack decay envelope generators, with a modification that allows the envelope to retrigger. then I got Ray Wilson's MAKE: synth diy book and it had a much more elegant solution.
 Filesize:  589.39 KB
 Viewed:  163 Time(s)
 Filesize:  727.47 KB
 Viewed:  202 Time(s)
Drum voices using the T network design. between the noise circuit for the hihat and the cd40106 cymbal circuit, the output is very noisy.
 Filesize:  745.04 KB
 Viewed:  201 Time(s)
4 channel 16 step trigger sequencer, made to trigger drums. Arduino, wrote the code myself, so I'm sure it's not very optimal. The potentiometer feeds an analog input on the arduino, which determines the step position. step position is displayed in binary
 Filesize:  703.33 KB
 Viewed:  180 Time(s)
First successful attempt at a CV step sequencer. two CD4051s with a binary counter, basically. the two knobs on the right scale the CV and apply an offset, respectively.
 Filesize:  811.16 KB
 Viewed:  181 Time(s)
raccooneatingcacti
PostPosted: Fri Sep 04, 2020 7:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Everyone's projects are looking great! So many ideas here, it really makes me want to step it up!
PostPosted: Mon Sep 07, 2020 6:30 am    Post subject: Re: My terrible DIY modules so far
not disturbing at all and like the way you use those PCBs as frontpanel Very Happy
The wiring could use bit of tidying up but for the rest it's not bad at all.
Can't see the underside of the PCBs though.
PostPosted: Mon Sep 07, 2020 6:35 am    Post subject: Reply with quote  Mark this post and the followings unread
I had/have some time of from work so did some soldering and build 5 new modules.
1x 4x4 Matrix mixer, my first SMD PCB design (can be expanded)
2x ICL8038 Dual function generator using a design by Thomas Henry
2x Bucket Rogers Delay with an MN3007 BBD chip (thanks for those Cfish!!)
Played around with them yesterday which turned out quite different than I was expecting.
You can find the video on twitch (for the next 14 days): https://www.twitch.tv/videos/733559035
and I will probably post the audio (starting from around 1:40:00) here on EM later.
 Filesize:  321.91 KB
 Viewed:  168 Time(s)
 Filesize:  243.29 KB
 Viewed:  186 Time(s)
 Filesize:  306.83 KB
 Viewed:  188 Time(s)
 Filesize:  220.13 KB
 Viewed:  172 Time(s)
 Filesize:  278.96 KB
 Viewed:  179 Time(s)
PostPosted: Mon Sep 07, 2020 6:38 am    Post subject: BBDBBDBBDBBDBBDBBDBBDBBD Reply with quote  Mark this post and the followings unread
And the Bucket Roger Delay.
I didn't notice the opamps being upside down in the schematic, so I had to fix that afterwards by soldering directly to the opamp pins. Rolling Eyes .
 Filesize:  154.64 KB
 Viewed:  176 Time(s)
 Filesize:  185.56 KB
 Viewed:  183 Time(s)
 Filesize:  210.15 KB
 Viewed:  155 Time(s)
raccooneatingcacti
PostPosted: Mon Sep 07, 2020 6:45 am    Post subject: Re: My terrible DIY modules so far
Thanks, Phobos! I used an old printer PCB for the sequencer panel. I hadn't settled on using the Eurorack 3U standard at that point. I don't really recommend it, There was some pretty nasty dust in the cutting process.
The underside of the boards? but that's where all the shame hides! I can get some pictures later today, haha. And yes the wiring is very bad at this point... I always intend on shortening the wires after getting confirmation that the modules work, but I haven't gotten around to that yet. I think using some standoff posts would be a huge improvement too.
I just finished a Thomas Henry VCF-1 perfboard yesterday. The first board I did all the components were crammed in super tight and every resistor was standing straight up. impossible to troubleshoot. Tried to save space and ruined a whole board! I've decided to lay things out and go really slow from this point on.
raccooneatingcacti
PostPosted: Mon Sep 07, 2020 6:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow, Phobos. Nice boards and panels! Is the solder mask opacity an aesthetic choice or does it serve a purpose? I've been wanting to get into PCB design but that seems like a whole new layer of troubleshooting. I've only done some very small boards by cutting traces out on a copper clad board with an exacto blade.
are there pictures of your complete system somewhere? I get the impression that it's massive.
PostPosted: Mon Sep 07, 2020 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Not sure if you are referring to the effect the copper pour between the traces has which will make it a bit harder to see the traces on the photos,
or the actual solder mask. Solder mask is standard when ordering PCBs (I think it's more expensive without) it's useful when soldering especially
with SMD since it reduces the change of shorts between pads. If you look at the top right of the Matix Mixer PCB there's an opamp which has 2 pins
bridged with some solder. For some reason the 2 opamps on the right side both didn't work so I had to replace them. In doing so I lost some of the
soldermask between those pins, and since they are connected with a trace the solder happily stuck to it. I could have tried to remove it a bit but that
would have probably done more harm than good.
The color choice on the other hand is for aesthetic reasons:
The Matrix Mixer had to be green of course.
I choose blue for the function generator because of all the blue components, especially all the blue pots.
For the Bucket Rogers Delay I looked up some images of Buck Rogers and his ship and saw a lot of white/grey so I went with that.
Usually I don't use the white solder mask as the black silkscreen always seems of lesser quality, it also obscures the traces a lot
(maybe that's what you were referring too) and it looks a bit messy with the solder flux. But for this one I made an exception.
I still like using perfboard but that doesn't really work well with SMD and if you need a couple of boards (I have 4 BBD chips and
10 function generator chips) it's not only less tedious than using perf but actually cheaper.
I've always been designing PCBs. initially I used to etch them myself but later switched to perf but for those I make a design too using an old free
version of SprintLayout. For these PCB designs I use the free version of Eagle and after watching 1 or 2 videos it wasn't too difficult to do but if you
start out I would recommend KiCAD or something else. The limitations of the free eagle version can be annoying and it now comes bundled with fusion
360 for which you need a subscription. A nice thing with eagle and I am pretty sure most PCB software, is that you can link the schematic and the PCB
so it will show you what to connect to another. You could even use an auto router but I've never made use of that myself, I enjoy the puzzle.
not a very recent one although it hasn't changed much but there is a nice one here.
A lot of things end up in boxes because I just don't have the space for it. But once in a while I pick something out to play with.
You could also check my youtube and twitch channels for some recent videos but they aren't very clear.
raccooneatingcacti
PostPosted: Mon Sep 07, 2020 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
if you start out I would recommend KiCAD or something else.
Thanks for the tip, I'm going to give that a try. Any suggestions on where to have boards made?
here
Looks awesome, looks like you could get lost for weeks in there. I'm hoping to fill two rows of 60 hp 3U tall, for starters.
I added pictures of the front and back of the Thomas Henry VCF that I finished the other day. I really took the extra time to lay the components and jumper wires out as clearly as I could. The wires going to the panel are still a little messy but it works.
 Filesize:  697.93 KB
 Viewed:  162 Time(s)
 Filesize:  900.05 KB
 Viewed:  193 Time(s)
PostPosted: Mon Sep 07, 2020 5:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've been using AllPCB, a lot of folks I know recommend JLC PCB, there's a site called "pcbshopper.com" that lets you compare the commonly used fabs with the details you want for your designs.
