Windows 11 x64 ?
Page 1 of 1 [22 Posts]
boaone
PostPosted: Thu Jul 03, 2025 3:17 pm    Post subject: Windows 11 x64 ?
Subject description: Someone uses WREN on Windows 11 x64 sucessfully ?
Im trying time to time install with new relases but modules not generating on first run.
Audio files: 297
PostPosted: Thu Jul 03, 2025 3:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Do you get a log file?
It would probably be called wren.log and would be situated in the folder where wren.exe is. I would like to see that file.
In case the log file does not exist - in what folder did you put Wren?
Are there any messages when you try to start wren?
boaone
PostPosted: Thu Jul 03, 2025 4:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
At first run i have error: A device ID has been used that is out of range for your system.
 Filesize:  751.4 KB
 Viewed:  14 Time(s)
 Filesize:  197.61 KB
 Viewed:  8 Time(s)
wren.log
 Filename:  wren.log
 Filesize:  11.82 KB
 Downloaded:  16 Time(s)
Audio files: 297
PostPosted: Thu Jul 03, 2025 4:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Could there be an issue with a selected audio device?
It is not really clear to me from the log file.
The screens you posted suggest that an error is generated when an audio device is being opened.
And that you then click away tat message, on which wren produces a boring look without a patch and without modules.
Am I interpreting this corrctly?
boaone
PostPosted: Thu Jul 03, 2025 5:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
This error pop up on start but when i click ok wren starting.
I can set audio settings to asio and general settings without problem.
I can run audio engine but there arent any modules. Palette of modules is empty.
Audio files: 297
PostPosted: Fri Jul 04, 2025 5:46 am    Post subject: Reply with quote  Mark this post and the followings unread
The log says nothing about populating the module selector - and it should say that. This I do not quite understand .. but apparently the error generated causes the modules not being created / populated.
The log also at first says that there is no ini file; then a little later it says that there is a new ini file being made and then saved as : 'C:\bin\wren.ini'
Is that file actually present after you ran wren once?
And if it is present - what happens when you start wren again after you had selected audio devices? [so for the 2nd time .. or later]
Audio files: 297
PostPosted: Fri Jul 04, 2025 5:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm .. it could also be MIDI i think
Audio files: 297
PostPosted: Fri Jul 04, 2025 6:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok ..this can be tested .. two things to try ..
1) if you start wren, and then change the window size, quit wrenand start it again - did it remember the window size?
2) if you start wren, then change the folder setup [from the menu setup/folder setup] - and then stop wren and restart it - did it remember the folder setup?
boaone
PostPosted: Fri Jul 04, 2025 8:28 am    Post subject: Reply with quote  Mark this post and the followings unread
wren.ini is present after first start. I can set audio devices and channels.
When i start wren once again i must change settings again. Configuration is not memorized.
boaone
PostPosted: Fri Jul 04, 2025 8:33 am    Post subject: Reply with quote  Mark this post and the followings unread
No windows size and folders after change are not memorized. They resetting to initial settings.
Audio files: 297
PostPosted: Fri Jul 04, 2025 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks like setting midi crashes then ... that is one of the first things tried on setting up [and does not generate proper error messages].
As your wren.ini is being saved .. you can try to set up midi from the menu, settings ..
then exit wren and restart it ..
if that does not work .. i'd like to see your wren.ini file ..
and maybe you could have a look at the section [FormMidiSelect] to see what the MidiInDeviceName and the MidiOutDeviceName are ... and if your sustemhas those devices.
boaone
PostPosted: Fri Jul 04, 2025 11:59 am    Post subject:   Reply with quote  Mark this post and the followings unread
Thanks a lot for help. Now its working.
Yes...that was some problem with midi like you point out. I didnt have any midi devices or midi ports on laptop.
so i installed loopMIDI virtual midi port and everything working again modules are present and config settings saved properly. Cool Smile
So for future if anybody had same situation on windows 11 X64 laptop
without proper audio interface:
I used free KoordASIO for ASIO
and loopMidi virtual midi port for midi.
Audio files: 297
PostPosted: Fri Jul 04, 2025 12:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool
glad you got it working - and thanks for being patient and helpful in finding the issue [instead of .. well .. let's say .. the nastiness at oher places] Exclamation
Now i'll try and fix that issue Laughing
It should be possible to not have midi.
boaone
PostPosted: Sat Jul 05, 2025 8:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Sometimes i want just plug in headphones somwhere to laptop and do some noodling without midi.
But i have next problem.
Now when i select and running audio engine Wren shutting down.
And wren didnt see any inputs or outputs with WASAPI. MME. DIRECT SOUND.
Only when ASIO selected wren detecting outputs and inputs.
wren.log
 Filename:  wren.log
 Filesize:  12.88 KB
 Downloaded:  14 Time(s)
boaone
PostPosted: Sat Jul 05, 2025 8:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Sometimes it work but i dont know why.
wren.log
 Filename:  wren.log
 Filesize:  29.24 KB
 Downloaded:  9 Time(s)
Audio files: 297
PostPosted: Sat Jul 05, 2025 3:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm .. what i have experienced in the past was that trying to use audio quickly after a reboot could fail ...
I'll try to again make sense of the logs later on, but it is not immediately clear to me right now.
I think I may have the MIDI issue fixed btw .. but then my computer crashed (not caused by wren, but by delphi .. i think :-) )
Audio files: 297
PostPosted: Sat Jul 05, 2025 3:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
at https://forum.audacityteam.org/t/wasapi-not-working-solved/64365/5 the problem seems to be that the sound system is set to 5.1 ... blaming hdmi drivers ...
you seem to have a display device connected too?
Audacity works with portaudio too i think ... it used to anyway :)
Audio files: 297
PostPosted: Sat Jul 05, 2025 3:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
I mean :
AddPAOutputDevice( 009, 'SHARP LCD (NVIDIA High Definition Audio)', 0 ins, 2 outs)
boaone
PostPosted: Mon Jul 07, 2025 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes i have display connected with hdmi cable and onboard connexant laptop card.
But its 2 audio channel device.
When i install wren from scratch and using asio its working.
But when i change some settings from windows when wren is closed and launch wren again its crashing when i click run audio engine.
Im trying to record stereo input when noodling. Its sometimes work i dont now why. What setting crash wren.
boaone
PostPosted: Mon Jul 07, 2025 9:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I was wrong because there are 2 onboard audio cards. Connexant and Nvidia.
But sometimes everything works without any problem
Audio files: 297
PostPosted: Mon Jul 07, 2025 7:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm .. recording of what is being played [if that is how i understand it correctly?] sucks on windows .. sorry .. it always used to suck .. maybe it is better nowadays.
[ On the mac there was soundflower :) ]
Some memories ... n ... stuff
Anyway .. on windows I do it trough my audio interface software which supports it - RME totalmix - RME is brilliant but erm .. not cheap .. bloody expensive even [but the babyface probably is enough to get totalmix to be useful]
There is software offering loopback .. but it is not standard and not free .. virtual audio cable (VAC) is one - I have never used it myself.
Some audio cards have drivers with "record what you hear" drivers; I've had that on a previous computer and it worked then .. it may be hidden a bit in the seetings too - it is not standard.
I think that .. vaguely recall that .. reaper may help .. but i may be wrong .. but it .. it used to be that once could test it indefinitely .. i think you need to buy it nowadays .. and i'm not sure that it will do it. Heh .. I have bought it .. installed it on the mac .. but ended up using it once only.
Sorry tat i can not come any further than this.
boaone
PostPosted: Tue Jul 08, 2025 3:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Sure Jan. Thanks a lot for your help. Its not a problem.
I have option "what you here" at win 11 name changed to "stereo mix" and options are all over the place. With interface everything works for me so problem solved. Just regret selling nord modular couple of years ago.
Crashed only once for couple of years. Missing that stability.
Even was thinking about capybara but its another interface.
I have sonic-core scope with 10SHARC DSP on three cards connected with stripe and modular IV license but its PCI digidesign cards so 3 PCI SLOTS because XITE is somewhat too expensive for me.
Im using nowadays XP x86 with hardware for scsi transfer editors and ASPI etc. Just wanted to hear whats new here and was courious why there is no modules on start.
