 Forum index » Instruments and Equipment » Cwejman Sound
Sequencer question
Page 1 of 1 [8 Posts]
white noise
PostPosted: Sun Nov 19, 2006 9:04 am    Post subject: Sequencer question
Subject description: Good sequencer for the S1?
First of all, you have a nice forum here! I am new and I was wondering what sequencer you use in combination with your Cwejman S1? I own a Cwejman S1 and I am looking for a sequencer with that typical analogue feel and control. Of course you can go for a full analogue type sequencer, like the Analogue Systems RS-200 Sequencer system, which you can also use for wave shaping, or a midi sequencer like the Doepfer MAQ, Sequentix P3 or Manikin Schrittmacher (the last two come highly recommended so I read, because of their analogue feel and extensive options). Both types have of course their own strengths and weaknesses, but maybe you could offer me some advice?
By the way, I don't use a sequencer for pure rhythm creation, more for slowly evolving ambient patterns, so I don't know for sure if elaborate sequencers like the Sequentix P3 and Manikin Schrittmacher might be a little overkill, or on the other hand maybe really suited for the job. Thanks in advance!
Best wishes, David.
mono-poly
PostPosted: Mon Nov 20, 2006 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I got rs-200 system for sale.
It's also cool because you can use it as an oscilator.
monads
PostPosted: Tue Nov 21, 2006 3:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Keep in mind too that the P3 has been discontinued.
hogberto
PostPosted: Sun Dec 10, 2006 4:49 am    Post subject: Reply with quote  Mark this post and the followings unread
i use an rs200 with mine. it works well.
so well, in fact, that the next addition to my system is going to be another rs200. Cool
Per
PostPosted: Thu Dec 21, 2006 9:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Analogue Solution Oberkorn mkii is very nice to work with. It is fast, intuitive and simple, offering 3 x 16 CV and 5 x 16 gate channels, as well as CV skip step/jump to another step functions.
The Doepfer MAQ use menue programming and I never has became a real friend to it, even though I have owned it for quite a while.
If you want a stand alone gear, I´m sure you should try it.
Per
softfin
PostPosted: Fri Dec 22, 2006 1:55 am    Post subject: Reply with quote  Mark this post and the followings unread
There's a slider version of the oberkorn too which seems pretty nice. I haven't had a chance to try one so i can't say much about it. It has only 1cv and 2 gate channel. http://www.users.globalnet.co.uk/~concuss/concussor/aspics/sl16.jpg
And there may also be a possibility that Sequentix would release a new sequencer next year, but i can only speculate that for now ...
Sound
PostPosted: Sat Dec 23, 2006 5:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.ear-group.net/model_21.html
 Filesize:  184.93 KB
 Viewed:  13902 Time(s)
white noise
PostPosted: Tue Dec 26, 2006 6:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for the advice!
