flip flop toggle confusion
Page 1 of 1 [3 Posts]
zynthetix
Audio files: 10
G2 patch files: 13
PostPosted: Wed Jan 05, 2005 6:38 pm    Post subject: flip flop toggle confusion Reply with quote  Mark this post and the followings unread
the two toggle methods I know of seemed to have stopped working in a patch I was constructing. The second attatchment is an example of how they are supposed to work. The first is the malfunctioning version. Any thoughts or solutions would be appreciated.
fftg.pch2
 Filename:  fftg.pch2
 Filesize:  809 Bytes
 Downloaded:  1832 Time(s)
cross switch.pch2
Load in slot A. The first flip flop is supposed to toggle with every gate, the second is supposed to toggle with every other.
 Filename:  cross switch.pch2
 Filesize:  1.8 KB
 Downloaded:  1804 Time(s)
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed Jan 05, 2005 7:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
I tend to just use the clk input for a toggling FlipFlop (the output changes state on the clk positive edge). The second flipflop mode seems to double duty as a SR or JK, depending on what inputs you use.
It becomes difficult to diagnose logic in a poly VA as the LED(s) only reflect the state of the last voice.
cross switch-b.pch2
 Filename:  cross switch-b.pch2
 Filesize:  1.71 KB
 Downloaded:  1837 Time(s)
zynthetix
Audio files: 10
G2 patch files: 13
PostPosted: Wed Jan 05, 2005 10:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
I had tried this before (clk only) but still had problems...the one you uploaded led me to realize that the toggling problem was generated by having a high polyphony (10 voices). I don't understand why the polyphony would make a difference though. thank you for the help too.
