Evan
Posted: Mon Sep 10, 2007 5:35 am Post subject:
Re: Schulte Compact A Phasing |
| jhaible wrote: | | I discovered his early works rather late in life: Apocalypse, Earth, 666. |
Has 666 been released on CD?
I no longer have a record player (actually I have one, but no needle), and would like to listen to this again. |
Posted: Mon Sep 10, 2007 5:38 am Post subject:
Hang on- I'm mixing "See you later" up with "The Dragon"  _________________ ACHTUNG!
moosapotamus
Joined: May 11, 2007 Posts: 113 Location: New Hampshire USA
Posted: Mon Sep 10, 2007 6:40 am Post subject:
Cool! I would love to build one of these!
The 'original' schemo always kind of baffeled me...
Compact Phasing A scheme
A while ago I spent some time redrawing it in a form that made more sense to me...
SCP'A' Audio Signal Path
SCP'A' LFO Section
SCP'A' Power Supply
But, I never figured out what connections that DIN jack in the LFO section was supposed to make, and how to get rid of it.
So, count me in!
~ Charlie _________________ moosapotamus.net
"I tend to like anything that I think sounds good" |
Posted: Mon Sep 10, 2007 7:54 am Post subject:
| moosapotamus wrote: |
I never figured out what connections that DIN jack in the LFO section was supposed to make, and how to get rid of it. |
Do you think that this connection was for foot controlled speed? Schaller's phaser used a similar configuration- that a foot control was used for the speed. _________________ ACHTUNG!
moosapotamus
Posted: Mon Sep 10, 2007 9:23 am Post subject:
I don't know for sure, but I think it might have been like a footswitch for 'high' and 'low' for the speed range... maybe?
jhaible
Posted: Mon Sep 10, 2007 9:43 am Post subject:
| v-un-v wrote: | An LDR...?
Like this one?; |
The NORPS-12 is quite expensive, but it's probably a candidate.
I'd prefer smaller LDRs without plastic package, though.
JH. _________________ "I tell you the truth, if anyone says to this mountain, 'Go, throw yourself into the sea,' and does not doubt in his heart but believes that what he says will happen, it will be done for him. Therefore I tell you, whatever you ask for in prayer, believe that you have received it, and it will be yours." (Mk 11,23f) |
jhaible
Posted: Mon Sep 10, 2007 9:46 am Post subject:
| moosapotamus wrote: | I don't know for sure, but I think it might have been like a footswitch for 'high' and 'low' for the speed range... maybe?
~ Charlie |
All kind of switching.
I've transformed some of tehse functions into something with a better interface on the Compact Clone - may need another redesign for new LDR types.
Manual Mode is very very nice on the CC, too.
jhaible
Posted: Mon Sep 10, 2007 9:48 am Post subject:
This runs from +/-16V and needs a lot of current.
Therefore it _should_ be a standalone box, not a module for a synthesizer.
(Plus, if you ever played one, you want this on the desktop, not in a rack. Honestly.)
Anybody has a problem if it needs a 2 * 18V transformer?
norman phay
Joined: Jun 29, 2007 Posts: 176 Location: North-East England
Posted: Mon Sep 10, 2007 9:49 am Post subject:
| As a dedicated Phaser Phanatic, count me in on this one, please! |
Posted: Mon Sep 10, 2007 11:20 am Post subject:
I'm with you there Norman Phasers? I can't get enough of them!
Jurgen, personally I would prefer this to be a standalone unit anyway. I really dig the original case design too  _________________ ACHTUNG!
germaniac
Posted: Mon Sep 10, 2007 11:32 am Post subject:
| Peake wrote: | | It makes the world just that much more acceptable to me. |
LOL! This sentiment has been on the tip of my tongue just about all my life. Thank you for actually putting it into words!
RE: Shulte Compact A, yes please!
Regards,
Joe |
germaniac
Posted: Mon Sep 10, 2007 12:05 pm Post subject:
That looks nice. That's an incandescent inside?
edit; any chance of reposting this? As the actual LDR section is out of focus. (the camera seems to have focussed on the socket instead _________________ ACHTUNG!
Posted: Mon Sep 10, 2007 12:08 pm Post subject:
PS Listening to Scott Walker right now. Fantastic production!! _________________ ACHTUNG!
germaniac
Posted: Mon Sep 10, 2007 12:33 pm Post subject:
Yes, sorry for my lousy photographic skills. These pix were done a long while ago, and by now the little module is all packaged in shrink tube and happily phasing away in a four-stage phaser. FWIW, here are a couple more pix from that build:
857.25 KB |
| Viewed: |
771 Time(s) |
648.83 KB |
| Viewed: |
777 Time(s) |
364.6 KB |
| Viewed: |
777 Time(s) |
Posted: Mon Sep 10, 2007 12:43 pm Post subject:
Nice
But that's with an LED. I'm trying to think how we can do this with a filament bulb- which can be replaced if necessary- although apparently the chances of the bulb 'blowing' are remote. _________________ ACHTUNG!
Posted: Mon Sep 10, 2007 12:55 pm Post subject:
Does the bulb thingie need cooling ? _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
germaniac
Posted: Mon Sep 10, 2007 12:59 pm Post subject:
Right, an LED. For my purpose at the time (a battery-powered stompbox) it was all about keeping current consumption low. But since that's no concern for something mains powered, I'd guess the smoother response of the incandescent bulb is preferable. Or in any case, it's more authentic to the original Schulte design, right?
Joe |
Peake
Joined: Jun 29, 2007 Posts: 1113 Location: Loss Angeles
Posted: Mon Sep 10, 2007 1:46 pm Post subject:
That's a clever setup.
Has anyone seen pics of the four lamps/detectors/joysticks Buchla used in the 204, IIRC? Although a wonderful idea, it was a bit messy on the board. |
vtl5c3
Peake
jhaible
Posted: Mon Sep 10, 2007 2:22 pm Post subject:
| v-un-v wrote: | Nice
But that's with an LED. I'm trying to think how we can do this with a filament bulb- which can be replaced if necessary- although apparently the chances of the bulb 'blowing' are remote. |
It's even easier with an incandescent lamp. Put the sensitive surface of 4 LDRs directly on the glass surface of the bulb (long wires ..). Wrap it with a sturdy black adhesive tape.
jhaible
Posted: Mon Sep 10, 2007 2:23 pm Post subject:
| elektro80 wrote: | | Does the bulb thingie need cooling ? |
No. You run it at undervoltage.
