today> Various Artists NYE concert
2009 Build Pictures
Page 1 of 16 [399 Posts]
Goto page: 1, 2, 3, ..., 14, 15, 16 Next
EdisonRex
Audio files: 172
PostPosted: Tue Jan 20, 2009 3:14 pm    Post subject: 2009 Build Pictures
Subject description: Show what you've built!
20 days into 2009 already and the builds continue. Post your stuff!
Here's last weekend's effort (mostly Saturday with some debugging on Sunday). I had a cold solder joint on of all things the power pin on U2. Silly me.
The connectors on that board are dense, so I ended up using 12-pin connectors, with some 3 pin ones on the end.
 Filesize:  411.04 KB
 Viewed:  418 Time(s)
 Filesize:  395.41 KB
 Viewed:  390 Time(s)
 Filesize:  384.22 KB
 Viewed:  423 Time(s)
Garret: It's so retro.
PostPosted: Tue Jan 20, 2009 3:36 pm    Post subject: Re: 2009 Build Pictures
dense, indeed. i know that (mea culpa). however, i use stackable connectors, i mean you could put them in rows. i have 3pol and 2pol, so i can create any width i need.
anyways, nice built.
here's what i have done so far (you might already have seen it, though): the PS3100 DoubleTrouble Resonators with x-panning. as you can see i placed the connector footprints with enough spacing to use any connector.
PS3100 DT wiring UR
PS3100 DT wiring UL
PS3100 DT wiring
PostPosted: Tue Jan 20, 2009 3:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
BTW edison. did you add the 100k resistor to GND right after the capacitor for AC coupling? i can't tell from the picture. it is necessary to install this resistor to make the AC coupling work (check out the lates documentation at my site: http://www.modular.fonik.de/pdf/f-mixer-rev2.pdf).
EdisonRex
Audio files: 172
PostPosted: Tue Jan 20, 2009 5:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
It is underneath the board, jumping from the underside of the terminal to R28's connection. Wink
It was easier for me to have it there.
Lovely PS3100 too, BTW. I hadn't seen those pics.
numbernone
PostPosted: Tue Jan 20, 2009 8:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Getting back in gear after a slow moving (building wise) year.
Aiming for one panel a weekend for the next several weeks. 2 done so far.
First one: 8 Thomas Henry VCAs for the 21st century, with each group of four also having a mix output. 2 CGS stomp box adapters. 4 generic attenuated banana to 1/4" outputs.
Second: Another Buchla 291 filter, all the same bugs as the first, which I aim to eradicate now that I am slightly smarter than a year and a half ago.Still awesome filter! MFOS mulitmode VCF, I love these. Another 4 VCAs, this time strait up IN/CV/OUT. Mankato w/ LEDs and 8 outs, glad to have a second one, super modulation workhorse.
And a snap of the guts of the filter panel before finishing up.
Next couple weeks will see a bunch of ADSRs (21st century again), and pairs of QFGs and PS3100 resonators, and a bunch more mixers. Then a pair of that killer PIC sequencer. Then a bunch of gigs. The year is off to a great start.
Oh yeah, I am anxiously awaiting a big bag of the Davies clone knobs.
 Filesize:  66.94 KB
 Viewed:  415 Time(s)
 Filesize:  76.11 KB
 Viewed:  395 Time(s)
 Filesize:  100.34 KB
 Viewed:  402 Time(s)
RF
Audio files: 28
PostPosted: Tue Jan 20, 2009 9:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Beautiful stuff - all of you!
bruce
www.sdiy.org/rfeng
Tim Servo
PostPosted: Thu Jan 22, 2009 10:53 pm    Post subject: 2009 Build Pics Reply with quote  Mark this post and the followings unread
Well, this has taken me some of 2008 and all of 2009 so far... It's my new secret gizmo, but that's about it for 2009. I'm really going to have to get some other stuff built Wink
Tim (working at Gizmonic Labs) Servo
Pardon the "Batman" camera angles...
 Filesize:  141.44 KB
 Viewed:  499 Time(s)
ErichBreakfast
PostPosted: Fri Jan 23, 2009 8:53 am    Post subject: Reply with quote  Mark this post and the followings unread
This is my first DIY synth after the Paia Fatman I built in 2008.
The top unit is a Paia 9700 VCO with a busted oscillator A. I think the Lm13700 might be bad, but I tried 4 different ones with no change yet. The second panel is an MFOS 24db/oct VCF and the MFOS Log/Lin VCA and the bottom panel is 3 MFOS super simple ramp/saw LFO's. I don't have a picture yet of the sample and hold, white/pink noise generator panel yet, but it looks like more of the same, but with holes drilled for some CV distributor's when I get more jacks and TL084's. My semester break is over though so I think my building may have to die down a little. Happy synthesizing!
Erich
 Filesize:  121.97 KB
 Viewed:  379 Time(s)
 Filesize:  120.36 KB
 Viewed:  389 Time(s)
Action shot.
 Filesize:  119.71 KB
 Viewed:  369 Time(s)
Rykhaard
PostPosted: Fri Jan 23, 2009 10:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Very cool to see someone else's work early in their building history. It reminds me of mine back in '92 / '93. 5U rack panels filled with stuff. Black paint and white lettering for everything. I've photos of them around somewhere. Will have to search.
ErichBreakfast
PostPosted: Fri Jan 23, 2009 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
I really wanted to make my panels very colorful but since I did all this in January and it's been snowing and/or below freezing here in MA I figured the Krylon probably wouldn't be too happy.
slacker
PostPosted: Fri Jan 23, 2009 3:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can't compete with the great looking stuff from everyone else but here's a couple of recently completed lunetta "modules".
CD40106 based oscillator on the right and a CD4047 based oscillator/pulse generator/audio mangler thing on the left.
 Filesize:  130.23 KB
 Viewed:  362 Time(s)
guitarfool
PostPosted: Fri Jan 23, 2009 7:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
The colored ones from Smallbear? Cool
Where'd you get the colored banana cables? The only place I've found so far is E-Z-Hook.
I'm thinking of changing formats from Moog to something smaller with bananas Very Happy
BananaPlug
PostPosted: Fri Jan 23, 2009 9:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Pomona cables. Get 'em at a place called TestPath. Search this forum you'll find the link.
neandrewthal
PostPosted: Sat Jan 24, 2009 9:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Are you gonna convert your whole system, or start a new one?
guitarfool
PostPosted: Sat Jan 24, 2009 10:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, start a new one I think. I'm not going to scrap my old stuff - I put way too much work into the panels. I just want something a little more portable than my current portable system (see below) Very Happy
Picture taken at the last Baltimore SDIY meeting by Logan Mitchell. Left to right are Art Harrison, David Rickert, and me.
 Filesize:  60.48 KB
 Viewed:  385 Time(s)
philpeery
PostPosted: Sat Jan 24, 2009 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Really nice work everyone! Numberone, you are beating me to the punch with the ASF21C vca's and adsr's! I just finished a single sided PCB layout for the envelope generator, based loosely on TH's design from the old MAP web site the fits my modular a bit better - I put in an MTA156 power connector, ferrite beads, pot and jack pads for all connects (I hate flying wires!), and added a inverted output as an option. I'm making up PCB's this weekend. Then I will work on the vca layout. I'll be sure to post some pic's as I make progress.
There's always catch up work to do....!
Regards,
Phil
iceowl
PostPosted: Sun Jan 25, 2009 1:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
The synthesizer birthing process is underway. Gestation will take some time. My first modules finished. Don't have cabinet built yet.
Complete (save for knobs):
2 - SN Voice
o Panel + bracket + most Components: Bridechamber
o Boards : sMs
o Everything else (mouser/digikey, etc.)
1 - MOTM 101 Noise/SH
o Panel / bracket / key components: MOTM
o Everything else (Mouser/Digikey/Ccomm for Rg174)
Still under construction:
1 - TH percussion synth
o Board : EM
o Parts (Mouser/Digikey/etc)
o Panel / bracket- still need
1 - MFOS Soundlab Plus + Sample & Hold
o Boards + components : MFOS + Mouser/digikey/etc.
o Panel / bracket : still need
1 - MOTM VCO 300 (unable to make it squeak despite great help from Paul) Awaiting replacement parts
Parts sitting in box:
1 - TH Mankato VCF
o Board : Magic Smoke
o Components : Mouser/Digikey
o Panel / bracket : Bridechamber
Stuff ordered and not yet here
VCA (MOTM) / AD (Fritz) / PS (MOTM) / other things...
Stuff Scrounged cheaply from Surplus Store
1 - Power One HDCC-150W-A +/1 15V and +5v -
Stranded hookup wire: All sorts
Numerous ICs / Caps / Etc.
I am still not sure where I will locate this synth when I have enough modules to actually make my first serious sounds. May have to buy a new home to accommodate it, but in this market, that will be tough. Also, the spouse may complain.
Once I figure out how to do pix, I will post here.
Joe
mono-poly
PostPosted: Wed Jan 28, 2009 8:44 am    Post subject: Reply with quote  Mark this post and the followings unread
This is the first DIY stuff for 2009
 Filesize:  27.41 KB
 Viewed:  21798 Time(s)
yusynth
PostPosted: Thu Jan 29, 2009 5:09 am    Post subject: Reply with quote  Mark this post and the followings unread
My first designs of the year : two keyboard matrix scanners using PIC16F88 and which provide V/Oct CV (over five octaves) and GATE. The analogue modulation boards (pitch wheel, modulation wheel, delayed vibrato...) are currently under design. The left board is for FATAR (8x8 matrix) keybeds, the right board is for CASIO, EVOLUTION (11x9 matrix) keybeds.
These are intended to be used in the yusynth CV/GATE keyboard controller.
Yves
sduck
PostPosted: Fri Jan 30, 2009 9:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's the first thing I've finished this year. Took a bit longer than it might have because I worked up 3 of these pcb's at the same time and also 2 other ones (bananalogue VCS's) all at the same time.
DRLGfront
DRLGside
PostPosted: Sat Jan 31, 2009 7:58 am    Post subject: Reply with quote  Mark this post and the followings unread
very nice and neat build. i like your color coding. it makes your modules so very special and unique. great.
Sebo
PostPosted: Sun Feb 01, 2009 2:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi:
Here are some modules I finished this month. I started them in 2008.
Some knobs are missing, and I have to finish the wiring in the MIDIbox CV.
All others are working, including the PSU (a Formant PSU built from
the Bergfotron PCB layout).
The modules are:
1 x MIDIbox CV
3 x Yusynth VCO
4 x Yusynth VCA
1 x Yusynth MiniMoog VCF
I will post more pics in the Yusynth subforum.
My forthcomming Modular.
 Filesize:  344.61 KB
 Viewed:  453 Time(s)
Sebo
My Music:
philpeery
PostPosted: Sun Feb 01, 2009 3:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Sebo,
AWESOME job! You gotta tell us how you do your front panels!
Phil
PostPosted: Sun Feb 01, 2009 3:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yup those panels look good!
Sebo
PostPosted: Sun Feb 01, 2009 5:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks!!!
The panels are 1.5mm aluminium covered with autoadhesive vinyl.
I had the vinyl printed at a graphic shop, and is covered with a satin
(kind of textured) transparent vinyl layer to protect the printing.
I just drilled the aluminium and then pasted the vinyl.
Is really cheap.
Here where I live (Buenos Aires, Argentina) laser engraving will cost me
about 35 dollars per panel, silk screening will cost me about 15 dollars per
panel, this method cost me about less than 1 dollar per panel.
PD: BlueHell you have really nice music at your Myspace!!!
Sebo
My Music:
