zynthetix
Audio files: 10
G2 patch files: 13
Posted: Thu Nov 18, 2004 7:47 pm Post subject:
Unexpanded G2 opening Expanded G2 patch |
Just curious, what is the protocol for an unexpanded G2 when it opens a patch made by (and utilizing the extra cycles/memory for) an expanded G2? Does the patch fail to open? Does the unexpanded G2 "truncate" and cut out the right most columns of modules or something until the patch works?
If anyone has an expanded engine or keyboard around and doesn't mind removing the card to check, I'd appreciate it. |
Afro88
Audio files: 12
G2 patch files: 79
Posted: Thu Nov 18, 2004 9:59 pm Post subject:
With an expanded G2, you still have 4 slots, but you can use 100% dsp and memory on both the cva and the fx areas for each slot. So essentially you have 2 dsp chips for each slot, one for cva and one for fx area as opposed to 1 dsp sharing both cva and fx area for each slot with an unexpanded G2 (if all 4 slots are being used). When only 2 slots are activated, you can use 1 dsp for each area in each slot. Similarly, with 3 slots activated, you can use 2 dsps for 1 slot and 1 for the other.
There have been a few G2 performances posted here that require an expanded G2 to work. When I open them on my unexpanded, slots C and D get turned off (voice allocation is on 0 and in the red), but slots A and B still play.
edit: wooo, 128th post! Heh, I know, I'm a geek...  |
Posted: Thu Nov 18, 2004 10:53 pm Post subject:
Yeah, just to boil it down, the "expansion" doesn't give more DSP power to a given patch (patches at 100% are not 50% on an expanded G2), just more voices. So it *should* be just like turning your voice request number up to 10, but only getting 4 voices allocated. In Afrokids example, his lack of polyphony cut out the voices for the performance's C and D slot patches.
Other than that, it's like having twice as many voices. |
zynthetix
Audio files: 10
G2 patch files: 13
Posted: Fri Nov 19, 2004 5:38 pm Post subject:
ok, thanks for the feedback. This helped me to understand the expansion card a lot more as well. As for 128 posts congrats, but I also noticed I just passed 256 a few minutes ago...our posting is in some kind of binary sync  |
Joined: Jan 31, 2003 Posts: 18269 Location: Durham, NC
Audio files: 231
Posted: Fri Nov 19, 2004 5:57 pm Post subject:
As for the binary posting milestones, congrats to both our you. JK also has passed the 128 mark.
Thanks very much. All of you are major contriutors to our community. You each enrich the community in unique and wonderfull ways. _________________ --Howard
my music and other stuff |
