 Forum index » How-tos
Difference between Frequency Cross Modulation and
Page 1 of 1 [6 Posts]
oXo
PostPosted: Wed Nov 24, 2004 7:36 am    Post subject: Difference between Frequency Cross Modulation and Reply with quote  Mark this post and the followings unread
Hello all,
I need some help to have the right definition of this 2 terms :
- Frequency Cross Modulation (in my case it's the FXM function present in all the Roland XV sound engine, and it seems to be a fixed square waveform modulating an other wave)
- a Feedback generator or Feedback module.
In my opinion, the first one is a waveform modulating an other waveform and the second one is just the mixing of one waveform on itself
Can somebody help ? and give me the right definition ?
Thanks.
Audio files: 227
PostPosted: Wed Nov 24, 2004 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't have one of those synths, but I've found that sometimes Roland's terminology is unique. So, what I say is very probably wrong in this specific instance.
Feedback modulation is when you plug the output of an oscillator into its own frequency modulation input. With small modulation indexes, not much signal fed to the FM input, the effect is a nice richening of the sound. As you turn up the modulation, the sound becomes distorted and, IMHO, more interesting. Smile
Cross modulation usually involves two osciallators, lets call them A and B. You would have A modulate B and B modulate A. This creates wild and wonderfull effects that are very unpredictable. I love it. Some people have said it is so unpredictable that it is unplayable.
I probably should not have responded to this post because this may have absolutely nothing to do with what's going on in the Roland.
zynthetix
Audio files: 10
G2 patch files: 13
PostPosted: Wed Nov 24, 2004 5:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
too bad there is not an emoticon for 'scoff'!
oXo
PostPosted: Thu Nov 25, 2004 12:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Mosc.
'scoff'!
What is "scoff" ? I don't know this word !
and babelfish doesn't help Sad
PostPosted: Thu Nov 25, 2004 6:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
from http://dictionary.reference.com/:
scoff
v. scoffed, scoff·ing, scoffs
v. tr.
To mock at or treat with derision.
v. intr.
To show or express derision or scorn.
n.
An expression of derision or scorn.
oXo
PostPosted: Fri Nov 26, 2004 2:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jk Wink
