Hyde
Posted: Sat Jan 20, 2007 1:20 am Post subject:
cappy2112 wrote: | Hyde wrote: | ok - i am using MacPython 2.5.
i did what you said and did the 'Get Info' and assigned the nm2g2.py file to be opened with Python Launcher instead of IDLE.
but now when i double click the 'nm2g2.py' file it opens up two Terminal windows - one of which says this (and i can't type anything into it:
Last login: Sat Jan 20 01:40:06 on ttyp1
Welcome to Darwin!
Hyde:~ Hyde$ cd '/Users/Hyde/Desktop/g2ools-1.0/' && '/usr/local/bin/pythonw' '/Users/Hyde/Desktop/g2ools-1.0/nm2g2.py' && echo Exit status: $? && exit 1
Exit status: 0
logout
[Process completed]
and the other one is just an empty Terminal window. |
Instead of double clicking- why not just open a command window in the directory where g2ools are, and just run it from there? |
cuz OSX doesn't work that way. something isn't right. it runs through and then says [Process completed] and you can't type anything else in that Terminal window. (sigh). i know this will all get ironed out sooner or later. just letting those who can code and know Unix what i am seeing when i try.
i am not a programmer. i'm a musician lol. |
3phase
G2 patch files: 141
Posted: Sat Jan 20, 2007 1:21 am Post subject:
Hyde wrote: |
How emty? can you type anything in there? |
Hyde
Posted: Sat Jan 20, 2007 2:10 am Post subject:
ugh - now its just opening the one Terminal window when i double click the 'nm2g2.py' file:
my machine is running tip-top. i know that's not the problem. anyone else have any ideas? |
modular
Joined: Jul 26, 2004 Posts: 185 Location: Rome, Italy
G2 patch files: 72
Posted: Sat Jan 20, 2007 4:36 am Post subject:
Hyde wrote: | ugh - now its just opening the one Terminal window when i double click the 'nm2g2.py' file:
Just the same to me
Something doesn't work on OSX  |
Joined: Apr 03, 2004 Posts: 24451 Location: The Netherlands, Enschede
Audio files: 297
Posted: Sat Jan 20, 2007 5:49 am Post subject:
Ok, so it did run the conversion program using pythonw but it didn't get any instructions as to what patch should be converted, so it was done pretty quickly
Is there no way to open a command prompt in OSX (as suggested by Tony) ? There must be, how about using an X windows terminal session, that one should do the trick I'd think. _________________ Jan
3phase
G2 patch files: 141
Posted: Sat Jan 20, 2007 6:55 am Post subject:
Here's how I did on OSX 10.4.8, using a command line:
I tried it first without installing anything, and got a weird exception, so I figured I'd install Python 2.5 (was 2.3 something).
* Install Python/Update to 2.5 by downloading from here: http://www.python.org/download/ (choose "Python 2.5 for Macintosh OS X")
* Open a terminal window (Program/Tools/Terminal - might be different since I only see my swedish locale version which is Program/Verktygsprogram/Terminal).
* Write "cd " followed by the path to your g2tools folder, e.g. "cd Desktop/g2ools-1.0/"
* Write "nm2g2.py " followed by the full path to your NM patch (or just the patchname if you put it in the same folder as g2ools), e.g. "nm2g2.py ~/Documents/Audio/nm_misc/sgm_git6.pch".
* Lots of text will be outputted, and a new file will be created at the same place as the original NM file.
I would also like to take a deep bow towards qfingers for realizing this project. Impressive.
@soundcloud @Flattr home - you can't explain music Last edited by Antimon on Sat Jan 20, 2007 7:00 am; edited 1 time in total |
Hyde
Posted: Sat Jan 20, 2007 6:57 am Post subject:
[edit] instructions to follow... Last edited by Hyde on Sat Jan 20, 2007 7:38 am; edited 1 time in total |
Hyde
Posted: Sat Jan 20, 2007 7:09 am Post subject:
Antimon wrote: | Here's how I did on OSX 10.4.8, using a command line:
/Stefan |
well - i tried. i opened Terminal and typed this:
cd Desktop/g2ools nm2g2.py ~/Desktop/g2ools/testenv.pch
and then it said:
-bash: nm2g2.py: command not found |
3phase
G2 patch files: 141
Posted: Sat Jan 20, 2007 7:13 am Post subject:
the program dont costs any money... just costs some nervs to get tzhe phyton executed
but as i said..once it started running..and dont ask me whay it works better for me than for you..
just..
a permission repair dont hurts and sometimes solves os x problems |
Posted: Sat Jan 20, 2007 7:21 am Post subject:
Hyde wrote: | Antimon wrote: | Here's how I did on OSX 10.4.8, using a command line:
/Stefan |
Ah... try ./nm2g2.py instead. If that doesn't work, try writing this strange line and then try with ./nm2g2.py again:
Hyde
Posted: Sat Jan 20, 2007 7:22 am Post subject:
my perms are fine. my Quad G5 is always 'clean'. the problem is this and this only:
i dont know command line codes, Unix, and hardly software modular synthesis. i am a hardware guy. i find cool patches and change little things in them but i am by no means a 'patcher'. so. the reason it's not working is me. and i am doing my best to try to get it to. thanks for everyone's patience. |
Hyde
Posted: Sat Jan 20, 2007 7:27 am Post subject:
Quote: | Ah... try ./nm2g2.py instead. If that doesn't work, try writing this strange line and then try with ./nm2g2.py again:
/Stefan |
ok - it didn't work by just typing ./nm2g2.py
i had to write the chmod u+x nm2g2.py and then do it.
then it worked. why is that? |
Posted: Sat Jan 20, 2007 7:37 am Post subject:
Hyde wrote: | Quote: | Ah... try ./nm2g2.py instead. If that doesn't work, try writing this strange line and then try with ./nm2g2.py again:
/Stefan |
It's a way to tell the operating system that it is an executable file. chmod stands for change permission mode, u stands for user and x stands for executable. Some archiving software don't manage to set these properly when you unpack an archive (like zip).
Anyway, now you should at least be able to keep the terminal open and run nm2g2.py for patch after patch without having to start all over again.
3phase
G2 patch files: 141
ask a unix guy...
maybe your G5 is too clean  |
Hyde
Posted: Sat Jan 20, 2007 7:47 am Post subject:
Antimon wrote: | Anyway, now you should at least be able to keep the terminal open and run nm2g2.py for patch after patch without having to start all over again.
/Stefan |
THANK YOU STEFAN!!! actually i have to run:
./nm2g2.py (patch name)
here are the OSX step-by-step instructions:
* install MacPython 2.5
* open Terminal and type: which python
--- mine said this:
Last login: Sat Jan 20 07:41:44 on ttyp3
Welcome to Darwin!
Hyde:~ Hyde$ which python
/Library/Frameworks/Python.framework/Versions/Current/bin/python
Hyde:~ Hyde$
* copy the whole path: /Library/Frameworks/Python.framework/Versions/Current/bin/python
* go to your g2ools-1.0 folder and open the 'nm2g2.py' file WITH IDLE
* change the first line (red text above the '# Copyright (c) 2006,2007 Matt Gerassimoff') to:
#!(your path)
mine looked like:
#!/Library/Frameworks/Python.framework/Versions/Current/bin/python
* hit 'Apple-S' to Save
* close IDLE
* open Terminal and type: cd Desktop/g2ools (if that's where it is) and then: chmod u+x nm2g2.py
mine looked like: cd Desktop/g2ools chmod u+x nm2g2.py
(hit Enter)
* then type ./nm2g2.py (patch name) for each patch you want converted like this:
./nm2g2.py Chaos001.pch
(hit Enter)
you're all done - the NM1 patch will be converted thanks to qfingers, Stefan, 3phase, and everyone else who helped make this possible on OSX! |
Posted: Sat Jan 20, 2007 8:09 am Post subject:
Hyde wrote: |
THANK YOU STEFAN!!!
Great! Glad I could help.
I would just like to point out to other people that before you edit nm2g2.py as in Hyde's instructions, try skipping ahead to the part where you open a terminal and write cd and stuff, because I didn't have do this (you still need to update to Python 2.5). If you don't get it to work, try again from the start.
Audio files: 297
Wapskallion
Posted: Sat Jan 20, 2007 9:50 am Post subject:
IT WORKS!!!
Although I had to do the following -
In terminal, type ./nm2g2.py patchname (leave .pch off the end)
then manually put .pch2 on the end of the new file
Thanks to everyone involved for this great free software and advice (particualy qfingers, 3phase and cappy) - sterling effort!
True to my word, i will make a donation to the forum (although I will have to wait for pay day).
Thanks a million! |
cappy2112
Joined: Dec 24, 2004 Posts: 2495 Location: San Jose, California
Posted: Sat Jan 20, 2007 11:40 am Post subject:
Hyde wrote: | Antimon wrote: | Anyway, now you should at least be able to keep the terminal open and run nm2g2.py for patch after patch without having to start all over again.
/Stefan |
if you want to convert multiple patches at the same time type
./nm2g2 *.pch |
modular
G2 patch files: 72
Posted: Sat Jan 20, 2007 11:43 am Post subject:
/Stefan |
Great!!!
Finally it works!
Thank you Hyde for step by step instructions (i'm a rookie with unix too )and from me too thanks to qfingers, Stefan, 3phase, and everyone else who helped make this possible on OSX!
Audio files: 297
Posted: Sat Jan 20, 2007 3:37 pm Post subject:
Bought me a new MIDI interface today so I can patch again for the Classic. Tried to convert one of my old noodles and discovered some problems.
For one thing, the Classic sequencers can be set to to have a loop length longer than 16, this is not dealt with in the translation.
Some sound details are lost as well. But as I understood a lot of changes are about to be made public in a while, I guess I better wait before going deeper into this - unless someone is curious about the patch in question.
Must say though that some of the sound is translated amazingly well ! _________________ Jan
Hyde
Posted: Sat Jan 20, 2007 4:15 pm Post subject:
sweet! doing a whole folder of stuff is easy! here are some of the errors i am seeing though on patches that can't be converted:
"/Users/Hyde/Desktop/Keepers/bLoFip.pch"
added missing [Header]
IndexError('list index out of range',)
"/Users/Hyde/Desktop/Keepers/MidiPitchTransposeGate.pch"
AttributeError("Patch instance has no attribute 'header'",)
is this because they were older patches? i don't know if they were before OS v3.03 or not but is that why they are failing? |
3phase
G2 patch files: 141
Posted: Sat Jan 20, 2007 4:39 pm Post subject:
Blue Hell wrote: | Bought me a new MIDI interface today so I can patch again for the Classic. Tried to convert one of my old noodles and discovered some problems.
Must say though that some of the sound is translated amazingly well ! |
the loop lenght longer than 16 is dealt with in the next version on looped sequences..
a still unclear situation is the longer one shots because theire link out put can be an impottant trigger source for later events...
a cheap solution is not found yet...
to do it with a clockdivider has the problem that the first clock gets thru...
while the link out trioggers the first after the pass thru...
there was other things to do so this is left out yet..
But..
If you have any ideas to solve that issue..let us know |
Audio files: 297
Posted: Sat Jan 20, 2007 5:11 pm Post subject:
3phase wrote: | If you have any ideas to solve that issue..let us know |
If you have an example patch illustrating the problem I'll have a look at it. (I'm not exactly sure what you mean by the "one shot", well I know you mean "non repeating", but in what context exactly).
Meanwhile I'm listenig through some of my old NM Classic stuff ... for some of those sounds I wouldn't have a clue as to how to patch it on the G2
Feedback delay lines for instance really sound much beter on the NM Classic, warm and wild and screaming.
Did I mention the perc osc already ? Same thing ... almost horny on the Classic, brain dead on the G2.
Guess I'm in a sort of a romantic mood or something  _________________ Jan
