 Forum index » Clavia Nord Modular » G2 Patches - Completed » Sequencer - interactive
polyphonic live sequencer
Page 1 of 1 [10 Posts]
Rivelen
G2 patch files: 12
PostPosted: Thu Mar 08, 2007 5:12 am    Post subject: polyphonic live sequencer Reply with quote  Mark this post and the followings unread
Here is a little, volatile sequencer, I use it as a sketch pad or for jamming with friends. It takes one slot, so it's not a perfect solution, but i like it anyway, it's so fast to record something...
how to use ?
It contains two seq that can send notes to two slots or midi channels.
set the number of voices you want to record via the slot properties.
choose the record destination (1 or 2)
set record on...
after listening your recording for a while, it may be a bit boring, so you can use the transpose button : while you press it, press a key to transpose...
Rivelen
poly seq1.44.pch2
 Filename:  poly seq1.44.pch2
 Filesize:  2.6 KB
 Downloaded:  2390 Time(s)
iPassenger
G2 patch files: 78
PostPosted: Thu Mar 08, 2007 5:31 am    Post subject: Reply with quote  Mark this post and the followings unread
sounds interesting, look forward to checking it out when i am at home. Very Happy
iP (Ross)
Rivelen
G2 patch files: 12
PostPosted: Sat Mar 10, 2007 6:12 am    Post subject: Reply with quote  Mark this post and the followings unread
here is an update, the last one has a bug on the transpose function Embarassed
I join a little demo of music made with it, the clocked-fm patch previously posted, and two patch taken from the electro-music.com collection..
Rivelen
poly seq1.46.pch2
 Filename:  poly seq1.46.pch2
 Filesize:  2.96 KB
 Downloaded:  2236 Time(s)
pseq demo.mp3
 Filename:  pseq demo.mp3
 Filesize:  1.6 MB
 Downloaded:  1595 Time(s)
eposk
PostPosted: Sun Mar 11, 2007 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
nice track Very Happy
Rivelen
G2 patch files: 12
PostPosted: Mon Mar 12, 2007 5:04 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks Eposk.
i'm not very proud of this sample track, I'll post a better one next time...
I have a question: does anybody have a trick to encode the pitch and velocity in one blue cable ?
it means that it should be able to mix in two signals 0-127 in one 0-127 and
mix out one in two without loss of information Confused
I want to add velocity handle in this sequencer.
I know it seems impossible...
Maybe I should buy an mpc or plug the midi cables from my computer... but... i want the G2 to be completely autonomous...
any idea ?
Rivelen
G2 patch files: 12
PostPosted: Tue Mar 13, 2007 5:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, sorry for the silly question... I think i will use a delay clock to handle the velocity in this patch.
I asked this question because i'm currently working on a non volatile version of this patch, with notes sequencers , so, a velocity trick would have been nice...
I'm going to post a wish for a better note sequencer....
PostPosted: Tue Mar 13, 2007 5:42 am    Post subject: Reply with quote  Mark this post and the followings unread
It's more like I don't really understand why you want velocity and pitch to flow through one blue wire. This may be possible but it will be pretty complicated. Would it not be possible to duplicate the pitch processing and use the copy for velocity processing ?
Rivelen
G2 patch files: 12
PostPosted: Tue Mar 13, 2007 9:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh yes, you're right, thanks for your answer ; in the present case, that's a good solution to duplicate the pitch processing.
I were asking that question for another project:
I want to find a nice way to record velocity and pitch into a note sequencer :
It would be nice to record and save a long sequence of notes with velocity in a patch.
I think that it may be dsp cheaper to have a circuit that do a pitch-velocity merge, in the case of a noteSeq chain (4 or 8 sequencers for example), instead of duplicate the whole chain to handle velocity ( well, hmm, maybe...)
I've considered the DA/AD converters, but I think it wouldn't suit, as 4 bits are not enough to code pitch or velocity..
I can't send a patch right now as i'm a bit far from my G2..
PostPosted: Tue Mar 13, 2007 10:05 am    Post subject: Reply with quote  Mark this post and the followings unread
The "maybe" may be appropriate Very Happy
Sequencers are not really expensive modules and some smart logic somehow always tends to eat a lot of resources. In general that is ...
Indeed, as you said, four bits is not many, both for velocity and for pitch. Otoh 16 notes could be usefull still but it would need a decoder then (another sequencer probably).
Rivelen
G2 patch files: 12
PostPosted: Wed Mar 14, 2007 4:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you Jan for your advices, you're certainly right, I will just try something with 3 bits for velocity , 5 for pitch, it may be enough....
After that, I'll focus on possible things, i promise Wink
Rivelen
