Newbie Help - Atari Punk Console
Page 1 of 1 [14 Posts]
notrobb
PostPosted: Sun Apr 01, 2007 10:43 am    Post subject: Newbie Help - Atari Punk Console
Subject description: troubleshooting tips anyone?
I'm brand new to this and trying to assemble an APC as my first project.
I've got it breadboarded up, but it's not outputting any sound, except if i touch the 10uf capacitor that is, and then it acts as a radio.
wondering if anyone has some troubleshooting suggestions? wrong parts? blown chip? bad wiring? just not sure what would cause this......
choklitlove
Audio files: 17
PostPosted: Sun Apr 01, 2007 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
would it be possible to post a picture? we could find the problem right away, i bet. or we may be able to rule out human error.
PostPosted: Sun Apr 01, 2007 12:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Or learn about a new way to build a radio Laughing
MIKEFORD
PostPosted: Sun Apr 01, 2007 7:03 pm    Post subject: APC Reply with quote  Mark this post and the followings unread
Man, I tried to wire up the vero board version with a 556..Nothing!
I built one using a dual 555 chip configuration from robthefiddler.com
BINGO! worked fine the first time. I did a dual opto-resistor mod thats outta site!
here is the link below!
http://www.robthefiddler.com/electronics-audio-diy/circuit-experiments/atari-punk-console/
 Filesize:  55.01 KB
 Viewed:  6752 Time(s)
notrobb
PostPosted: Sun Apr 01, 2007 8:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sure, thanks a lot for taking a look at, wouldn't surprise me if it is human error.....
http://www.rawkandorroll.com/robb_apc2.jpg
shawn
PostPosted: Sun Apr 01, 2007 9:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
How many caps you got on that board? I only see 2, one elec and 1 non-elec.
Actually, better question is, which APC circuit you using?
choklitlove
Audio files: 17
PostPosted: Mon Apr 02, 2007 1:46 am    Post subject: Reply with quote  Mark this post and the followings unread
i found several errors in your arrangement. missing cap, a couple missing jumpers, and a couple others.
try this:
 Filesize:  29.02 KB
 Viewed:  6762 Time(s)
notrobb
PostPosted: Mon Apr 02, 2007 9:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
try this:
thanks! i did have the 3rd cap on, but it was sort of hidden
anyway, i think i've got it wired right now, according to your diagram there.. i think i did have a few connections wrong the first go. unfortunately, same results.
No sound, unless i touch the big cap, then radio...
 Filesize:  277.46 KB
 Viewed:  6749 Time(s)
Wild Zebra
PostPosted: Tue Apr 03, 2007 7:52 am    Post subject: Reply with quote  Mark this post and the followings unread
maybe you fried the chip? Try a new one.
"your stripes are killer bro"
notrobb
PostPosted: Tue Apr 03, 2007 11:20 am    Post subject: Reply with quote  Mark this post and the followings unread
good call. unfortunately i made the mistake of only buying one, but i'll pick some up this weekend and see how it goes. thanks!
choklitlove
Audio files: 17
PostPosted: Tue Apr 03, 2007 1:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
if you have another 10uF, try replacing that first. it's worth a shot, because those are really unreliable.
notrobb
PostPosted: Tue Apr 03, 2007 5:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks, i do have a bunch of those, so i'll try it out when i get home.
notrobb
PostPosted: Sat Apr 07, 2007 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
So I got some new 556s to try in there.... changed the pots too.
Not working great yet though. There is barely any volume, but i can barely hear this faint oscillating sound if i crank the amp i'm plugging it into. it's like the static is faintly oscillating?
one thing i realised is that your breadboard calls for 470k pots, but i've been using 500k linears, as called for in the circuit at
http://www.getlofi.com/wp-content/uploads/2006/10/atarilayout.gif
EDIT:
A connection wasn't being made somewhere. i reconnected it all and it works!
Thanks for all your help!
Wild Zebra
PostPosted: Tue Apr 10, 2007 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Word!! Good work stickin to it.
