Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Tue Apr 24, 2007 11:50 am Post subject:
I thought it was just a lay out case. When you are quoting yourself, 'Edit' is the first button on the right, where normal (other messages) 'Quote' is positioned.
Wout |
ian-s
Audio files: 42
G2 patch files: 626
Posted: Tue Apr 24, 2007 2:23 pm Post subject:
not sure what happened to that last post,
Here is a mono unison version, the manual says 2 and 4 voices are used for poly and mono unison respectively. I agree that the poly unison could be handled with just a two slot prf, nl2g2 could take care of the pan and detune automatically.
Although if the LFO's are in mono mode, then there would be no need to duplicate them or the envelopes and mixers, save some dsp overall. I'll try to do a poly-unison version as well.
Edit: Here is the poly-unison, it wont get more voices but the small saving in dsp will allow for more stuff to be loaded into other slots.
 Download (listen) |
| Filename: |
lead2g2-Uni.pch2 |
3.25 KB |
| Downloaded: |
2008 Time(s) |
 Download (listen) |
| Filename: |
lead2g2-PUni.pch2 |
4.22 KB |
| Downloaded: |
1969 Time(s) |
Wout Blommers
Audio files: 123
G2 patch files: 12
dorremifasol
Joined: Sep 28, 2006 Posts: 823 Location: Barcelona, Spain
G2 patch files: 49
Posted: Wed Apr 25, 2007 5:27 pm Post subject:
That was a real Nord Lead 2, right? _________________ Cheers,
Albert |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Apr 26, 2007 12:16 am Post subject:
| dorremifasol wrote: | | That was a real Nord Lead 2, right? |
Yes.
It is that kind of sound one seldom programs on a NordLead, but it is possible.
Wout |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Apr 26, 2007 1:49 am Post subject:
This is also a single NordLead2
Using the Arpeggiator and LFO1 (bass drum), Filter on HighResonance and Morphing using the Wheel this little sequence shows what the NL2 can do, sometimes. At the end the Distortion is shut off.
Wout
 Download (listen) |
| Filename: |
NL2-Sequence04.mp3 |
755.23 KB |
| Downloaded: |
1212 Time(s) |
 Download (listen) |
| Filename: |
NL2-Sequence04.syx |
139 Bytes |
| Downloaded: |
561 Time(s) |
Last edited by Wout Blommers on Sun Feb 24, 2008 3:50 am; edited 2 times in total |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sun Apr 29, 2007 11:45 pm Post subject:
I'm still busy to make the measurements
Just one module to go.
Had a special lecture by Rob Hordijk 'why' those values are so different in each synth and by different manufactories...
And why computers aren't that stable as we think (1/8 note at 120 BPM isn't always 125 ms) and what the sample rate has to do with it.
AFAI(K) and Rob knows the sample rate of the NL2 at once side and the NM Classic and the NM G2 at the other are different (44.1 - 96)
Wout |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Fri May 04, 2007 2:22 pm Post subject:
Re: Nord Modular G2X vs. Nord Lead 2X |
| bbw wrote: | | if someone has already created an Nord Lead 2X emulation patch for the G2X i'd love to hear from them. if not, i plan on attempting one, & then plan to re-create the factory patch set for the 2X on the G2X. |
I just realized there are already a lot of NordLead emulations in the Archive. Just search for:
NordLead_Emulation_by_Martinez_Ken
and
Nord_Lead_Emulation_by_Clavia
The first one is the 'leave none used modules out' and the second one is rather poor.
What I'm searching for is a structure like the NordLead2(X), so all the possibilities are there in the emulation on the G2 platform, not just sounds...
Wout
(who is almost ready measuring  |
Wout Blommers
Audio files: 123
G2 patch files: 12
dorremifasol
G2 patch files: 49
Posted: Sun May 06, 2007 9:13 am Post subject:
| Quote: | | (What shall I do with the rest of my life...) |
Please, keep posting great patches  _________________ Cheers,
Albert |
Joined: Apr 03, 2004 Posts: 24673 Location: The Netherlands, Enschede
Posted: Sun May 06, 2007 11:08 am Post subject:
Here is the pdf.
(edit: pdf got lost) _________________ Jan
9 3 4 .. erm .. not 13 then? .. hmm, ah eight! .. yeah yeah as in 8647 .. 47 is an 88 .. pwew .. numbles! Last edited by blue hell on Thu Aug 23, 2007 1:24 pm; edited 1 time in total |
bbw
Posted: Wed May 16, 2007 1:14 pm Post subject:
so... |
where do y'all stand w/ the conversion? i agree w/ Wout: the point is to mimic the functionality of the Nord Lead 2X & the sounds.
on that point: i don't remember who posted above saying they played w/ a Nord Lead 2X & found it similar in character to a Nord Modular G2X - do you mean that they are both analog synthesizer emulations? because that's about where the similarity ends.
i've now had my G2X for about 2 months & it does not even BEGIN to compare to the Nord Lead 2X in terms of bad ass-ness, girth & edge. & (drum roll) THE PRESETS IN THE 2X ARE FREAKING AWESOME! almost every sound in that instrument is instantly inspirational.
the same can not at ALL be said of the the presets in the G2X, which are kind of like a limp noodle by comparison - which is the whole point of this excersize.
screw it - i am getting a 2X. i'll just live w/ the crap keyboard, or get the rack.
anyone want to buy a barely used G2X? |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Wed May 16, 2007 2:08 pm Post subject:
Re: so... |
| bbw wrote: | | ... screw it - i am getting a 2X. i'll just live w/ the crap keyboard, or get the rack. ... |
What ever you do, I'm sure you will make the right decision.
Wout |
