Jari Jokinen
Posted: Fri May 04, 2007 7:36 am Post subject:
Rectifier for Eurorack? |
I am sure I need one. Full and half wave rectifiying maybe with offset control.
There is Bananalogue WVX, which according to the manufacturer is "pretty non- linear". If carefully adjusted, Doepfer A-136 is capable of rectifying too, but propably not very well in practice.
As I am not a DIY man, I wonder if I am out of luck? Is anyone interested in building me one?
Best regards
Jari Jokinen |
Posted: Fri May 04, 2007 4:25 pm Post subject:
I don't understand what you're asking, sorry.  _________________ What makes a space ours, is what we put there, and what we do there. |
bugbrand
Posted: Fri May 04, 2007 6:58 pm Post subject:
Just diodes, surely?!
Half-wave --> one diode
Full-wave--> four diodes (or a bridge recitifier)
Maybe some buffers too and may as well add in some nice bells&whistles to fill up a panel. _________________ http://www.bugbrand.co.uk
Jari Jokinen
Posted: Sat May 05, 2007 9:15 am Post subject:
| Uncle Krunkus wrote: | I don't understand what you're asking, sorry.  |
Nord Modular rectifier module:
"The Rectifier (diode processing) module can be set to discard of any positive or negative input levels (half wave rectification), or to convert the input signal to only positive or only negative levels (full wave rectification)."
Analog implementation is with diodes, as bugbrand says.
Best regards
Jari Jokinen |
Posted: Sat May 05, 2007 4:16 pm Post subject:
Cool,
Initially I thought you were talking about PSUs.  _________________ What makes a space ours, is what we put there, and what we do there. |
Adam-V
Posted: Sun May 06, 2007 4:09 pm Post subject:
I think what you are looking for is a precision rectifier circuit.
This page gives some good information on using super diode circuits to achieve half and full wave rectification. I've been experimenting with the circuits shown and they do work very nicely: http://sound.westhost.com/appnotes/an001.htm
I'm still experimenting with addition of an offset to allow rectification around something other than 0 volts but haven't managed a satisfactory solution to this yet.
Adam-V |
Joined: Apr 03, 2004 Posts: 24670 Location: The Netherlands, Enschede
Posted: Sun May 06, 2007 4:48 pm Post subject:
| Adam-V wrote: | | I think what you are looking for is a precision rectifier circuit. |
When it should reproduce the NM rectifier module it would need to be something like that indeed. _________________ Jan
Jari Jokinen
Posted: Tue May 08, 2007 2:10 am Post subject:
| Precision would be needed. I am not sure about the usefulness of the offset setting. |
