Rectifier for Eurorack?
Page 1 of 1 [8 Posts]
Jari Jokinen
PostPosted: Fri May 04, 2007 7:36 am    Post subject: Rectifier for Eurorack? Reply with quote  Mark this post and the followings unread
I am sure I need one. Full and half wave rectifiying maybe with offset control.
There is Bananalogue WVX, which according to the manufacturer is "pretty non- linear". If carefully adjusted, Doepfer A-136 is capable of rectifying too, but propably not very well in practice.
As I am not a DIY man, I wonder if I am out of luck? Is anyone interested in building me one?
Best regards
Jari Jokinen
PostPosted: Fri May 04, 2007 4:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't understand what you're asking, sorry. Confused
bugbrand
PostPosted: Fri May 04, 2007 6:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just diodes, surely?!
Half-wave --> one diode
Full-wave--> four diodes (or a bridge recitifier)
Maybe some buffers too and may as well add in some nice bells&whistles to fill up a panel.
http://www.bugbrand.co.uk
Jari Jokinen
PostPosted: Sat May 05, 2007 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Nord Modular rectifier module:
"The Rectifier (diode processing) module can be set to discard of any positive or negative input levels (half wave rectification), or to convert the input signal to only positive or only negative levels (full wave rectification)."
Analog implementation is with diodes, as bugbrand says.
Best regards
Jari Jokinen
PostPosted: Sat May 05, 2007 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool,
Initially I thought you were talking about PSUs. Rolling Eyes
Adam-V
PostPosted: Sun May 06, 2007 4:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think what you are looking for is a precision rectifier circuit.
This page gives some good information on using super diode circuits to achieve half and full wave rectification. I've been experimenting with the circuits shown and they do work very nicely: http://sound.westhost.com/appnotes/an001.htm
I'm still experimenting with addition of an offset to allow rectification around something other than 0 volts but haven't managed a satisfactory solution to this yet.
Adam-V
PostPosted: Sun May 06, 2007 4:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
When it should reproduce the NM rectifier module it would need to be something like that indeed.
Jari Jokinen
PostPosted: Tue May 08, 2007 2:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Precision would be needed. I am not sure about the usefulness of the offset setting.
