iPassenger
Joined: Jan 27, 2007 Posts: 1070 Location: Sheffield, UK
G2 patch files: 78
Posted: Sun May 06, 2007 10:21 am Post subject:
Lazy Glitch Music Production |
If anyone out there makes that glitchy style music, there is a really easy way of getting those kind of sounds with next to zero effort. Feed a drum machine (worked well with my electribe) into yr G2, Then using the zero cross counter feed a basic ring-mod style synth, the only other thing is to perhaps use a noisegate and an envelope or 2 to give u some extra control over the noise bursty moments, as it can be a bit much.
I would post an example but it is just soo easy. _________________ iP (Ross)
mother misty
Joined: May 13, 2004 Posts: 681 Location: Ghent / Belgium
G2 patch files: 130
Posted: Sun May 06, 2007 11:54 pm Post subject:
Re: Lazy Glitch Music Production |
| iPassenger wrote: | If anyone out there makes that glitchy style music, there is a really easy way of getting those kind of sounds with next to zero effort. Feed a drum machine (worked well with my electribe) into yr G2, Then using the zero cross counter feed a basic ring-mod style synth, the only other thing is to perhaps use a noisegate and an envelope or 2 to give u some extra control over the noise bursty moments, as it can be a bit much.
I would post an example but it is just soo easy. |
Never tried that... thanks for the tip!
(ohh... do you use the zero cross counter output
to modulate the pitch of the osc?) |
iPassenger
G2 patch files: 78
and70it
Posted: Mon May 07, 2007 3:20 am Post subject:
for beginners |
can you post this patch?
Thanks |
iPassenger
G2 patch files: 78
Posted: Mon May 07, 2007 3:56 am Post subject:
Just knocked this one up for ya. Maybe stay away from too many hi freq sounds (like hats cos they really confuse it, but bass n mid tone drum sounds work well)
| Description: |
 Download (listen) |
| Filename: |
Weird Proc.pch2 |
| Filesize: |
1.27 KB |
| Downloaded: |
2075 Time(s) |
| Description: |
 Download (listen) |
| Filename: |
Messing with Weird Proc.mp3 |
| Filesize: |
1.62 MB |
| Downloaded: |
1618 Time(s) |
- http://soundcloud.com/ipassenger Last edited by iPassenger on Tue Aug 21, 2007 1:39 pm; edited 1 time in total |
Joined: Apr 03, 2004 Posts: 24660 Location: The Netherlands, Enschede
Audio files: 327
Posted: Mon May 07, 2007 2:38 pm Post subject:
| iPassenger wrote: | | that occasionally does something unexpected |
Yes, thats the fun part When the signals get a bot complex the tracking gets glitchy. You can tune that a bit by applying filtering before.
I particulary liked your first demo mp3. I seem to be in a quiet mood ... _________________ Jan
dasz
Audio files: 29
G2 patch files: 56
Posted: Mon May 07, 2007 10:27 pm Post subject:
I like this, it uses different modules than I normally use.
/Dasz |
mother misty
G2 patch files: 130
Posted: Mon May 07, 2007 11:56 pm Post subject:
| iPassenger wrote: | | Feed a drum machine (worked well with my electribe) into yr G2 |
Hmmm... time to get my electribe back from the attick
Nice examples ipassenger! |
iPassenger
G2 patch files: 78
Posted: Tue May 08, 2007 2:41 am Post subject:
I hadn't used mine (electribe) in ages either, only got it out cos I wanted to wire something tweakable thru the G2 (n gald i did, it wont be returning to it's box any time soon). Recently put the soft synth Drumazon and Stylus thru it with some lovely results too. Can't wait to feed my MDrum thru it when it returns from its European holiday.
Thanks for your comments guys.
R. _________________ iP (Ross)
