Lazy Glitch Music Production
Page 1 of 1 [9 Posts]
iPassenger
G2 patch files: 78
PostPosted: Sun May 06, 2007 10:21 am    Post subject: Lazy Glitch Music Production Reply with quote  Mark this post and the followings unread
If anyone out there makes that glitchy style music, there is a really easy way of getting those kind of sounds with next to zero effort. Feed a drum machine (worked well with my electribe) into yr G2, Then using the zero cross counter feed a basic ring-mod style synth, the only other thing is to perhaps use a noisegate and an envelope or 2 to give u some extra control over the noise bursty moments, as it can be a bit much.
I would post an example but it is just soo easy.
iP (Ross)
mother misty
G2 patch files: 130
PostPosted: Sun May 06, 2007 11:54 pm    Post subject: Re: Lazy Glitch Music Production Reply with quote  Mark this post and the followings unread
Never tried that... thanks for the tip! Smile
(ohh... do you use the zero cross counter output
to modulate the pitch of the osc?)
iPassenger
G2 patch files: 78
PostPosted: Mon May 07, 2007 1:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I fed the cross counter to both osc pitch inputs (both sides of ringmod). Use the noisegate's, that's gating the input, gate output to trigger an envelope placed after the ringmod synth, I suppose FM-ing the synths either with each other or the input would work too.
On the one i set-up i fed it the most boring of drum loops with ridiculously simple n dull sonds and out came this musical and trippy glitch loop, that occasionally does something unexpected, presumably due to the accuracy of the counter.
Electribe Weirdo Process.mp3
 Filename:  Electribe Weirdo Process.mp3
 Filesize:  3.4 MB
 Downloaded:  1608 Time(s)
iP (Ross)
and70it
PostPosted: Mon May 07, 2007 3:20 am    Post subject: for beginners Reply with quote  Mark this post and the followings unread
can you post this patch?
Thanks
iPassenger
G2 patch files: 78
PostPosted: Mon May 07, 2007 3:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Just knocked this one up for ya. Maybe stay away from too many hi freq sounds (like hats cos they really confuse it, but bass n mid tone drum sounds work well)
Weird Proc.pch2
 Filename:  Weird Proc.pch2
 Filesize:  1.27 KB
 Downloaded:  2075 Time(s)
Messing with Weird Proc.mp3
 Filename:  Messing with Weird Proc.mp3
 Filesize:  1.62 MB
 Downloaded:  1618 Time(s)
iP (Ross)
Audio files: 329
PostPosted: Mon May 07, 2007 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, thats the fun part Very Happy When the signals get a bot complex the tracking gets glitchy. You can tune that a bit by applying filtering before.
I particulary liked your first demo mp3. I seem to be in a quiet mood ...
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Mon May 07, 2007 10:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
I like this, it uses different modules than I normally use.
/Dasz
mother misty
G2 patch files: 130
PostPosted: Mon May 07, 2007 11:56 pm    Post subject: Re: Lazy Glitch Music Production Reply with quote  Mark this post and the followings unread
Hmmm... time to get my electribe back from the attick Smile
Nice examples ipassenger!
iPassenger
G2 patch files: 78
PostPosted: Tue May 08, 2007 2:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I hadn't used mine (electribe) in ages either, only got it out cos I wanted to wire something tweakable thru the G2 (n gald i did, it wont be returning to it's box any time soon). Recently put the soft synth Drumazon and Stylus thru it with some lovely results too. Can't wait to feed my MDrum thru it when it returns from its European holiday.
Thanks for your comments guys.
R.
iP (Ross)
