Tim Kleinert
G2 patch files: 236
Posted: Thu May 13, 2004 8:02 am Post subject:
Electric piano model |
My first attempt at electric piano modeling. Here we go:
The pure fundamental is the only mode that can reside within a vibrating tine -like a tuning fork. Therefore, it's easily modelled with a single resonant filter, excitated by a "hammer" impulse. The resonance itself is controlled by a keyboard-gated AR envelope, and with each key release, a shapabale "damper noise" is triggered into the system as the resonance dies down. This models the damper touching the tine.
The characteristic overtones of a electric piano are caused by the interaction between the vibrating tine and the electromagnetic pickup. I attempted to model this by modulating the phase of a PhaseOsc at 0 Hz with the tine signal and adding asymmetric distortion. Since lower tines generate a higher vibration amplitude, I added keyboard-morph to the mod amount. It might have been more correct to morph the tine amplitude, but it works both ways.
IMPORTANT: The outputs of the voices are NOT gated by a master VCA. They all run straight together, just like in a "real" e-piano. That's the reason for the "thump" when you load this patch: That's the PhaseOsc of all voices being synced to zero (otherwise you get DC). Also there is a clicking sound when playing the first 19 notes -that's the voices that are being used for the first time. Afterwards they are OK.
It doesn't sound like a Fender Rhodes replica, but it has the right kind of "playing response" and "feeling". I added some characteristic processing, too. It's a very simple model. I kept it as simple as possible, in order to get many voices. It gets 19 voices from an unexpanded G2 -not bad at all.
tim
Description: |
electric piano model using basic modal synthesis |
 Download (listen) |
Filename: |
ElectricPiano2TK.pch2 |
Filesize: |
2.17 KB |
Downloaded: |
2926 Time(s) |
Joined: Jan 31, 2003 Posts: 18252 Location: Durham, NC
Audio files: 227
Posted: Thu May 13, 2004 9:10 am Post subject:
This is very interesting to me. Many techniques here I need to learn. It's such a simple patch, but so expressive if you get in and fool with the parameters.
It sounds more organlike than piano like. How can you adjust the decay time (key held down). |
bj2001
Posted: Thu May 13, 2004 7:11 pm Post subject:
great
u did a good job.
really sounds good.  _________________ Fuck the friendship,I ride alone |
Tim Kleinert
G2 patch files: 236
Posted: Fri May 14, 2004 3:01 am Post subject:
Quote: | How can you adjust the decay time (key held down). |
Well, since -at the core- it is a excitated resonating filter rather than oscillator, decay time is not arbitrarily controlled by an envelope time. Instead it's the amount of resonance (feedback of energy) which determines the decay time -just like in the real world.
The resonance however is controlled by a ramp envelope which keeps the resonance constant as long as the key is depressed and fades out quite quickly after release, which models the damping procedure. So, if you crank up the release time somewhat ("TineDamp Release"), it sound like the dampers don't work properly anymore when releasing a key. ("Ah -time for servicing!" ) I will try to randomize these things in a patch update, so each key behaves a bit differently in this respect, as well as concerning hammer and (de-)tuning-just like in a "real" electric piano.
So: it's the "Res M" knob on the UI which controls the decay, as this determines how long the oscillation can reside within the "tine filter". By default this is at maximum, If you play notes and decrease this value at the same time, you can hear the way the tines get more and more 'damped'. They get struck allright, but they deteriorate more quickly into a "thuck" -like if you damp the tines with your hand. With "Res M" at half, you only have "thucks" left.
Quote: | sounds more organlike than piano like. |
...as I say: it's my first try. I'm a "beginner" at this too -was just trying to get the basic concept right. Now's the time for embellishments, as mentioned above. They will cost polyphony, but oh well -I'll try to keep it at 16 voices -hopefully. Also I'll try some other approaches to the pickup, and the "hammer" and "damper" too. I really want to get that "bark" nailed. It's a fun project.
tim |
stiiiiiiive
Joined: Sep 21, 2006 Posts: 24 Location: Paris - Versailles, France
G2 patch files: 4
GovernorSilver
Joined: Apr 26, 2004 Posts: 1349 Location: Washington DC Metro
