 Forum index » electro-music.com
problem accessing site last couple of days 02/08/2007
Page 1 of 1 [17 Posts]
Stanley Pain
Audio files: 10
G2 patch files: 35
PostPosted: Thu Aug 02, 2007 2:07 am    Post subject: problem accessing site last couple of days 02/08/2007
Subject description: anyone else?
i keep getting "connection reset" messages whilst navigating around electro-music.com
this has only happened in the last couple of days. is this a known/shared problem?
there's no I in TEAM, so let's all act as individuals instead
PostPosted: Thu Aug 02, 2007 2:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes it's happening to me here too.
I've told da bosses about it Very Happy
ACHTUNG!
PostPosted: Thu Aug 02, 2007 2:56 am    Post subject: Reply with quote  Mark this post and the followings unread
I have no idea just yet what ths is about. I don´t think I´ve seen this today myself, but then I´m mostly busy at work. I´ll look into it tonight. The site seems stable now, doesn´t it? Shocked
Flickr
PostPosted: Thu Aug 02, 2007 2:58 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah seems to be okay now Confused
ACHTUNG!
cebec
G2 patch files: 31
PostPosted: Thu Aug 02, 2007 5:39 am    Post subject: Reply with quote  Mark this post and the followings unread
It's intermittent for me. If I use any of my bookmarks I get the error message occasionally. If I go to the front page first then to the forum, it works fine. Question
Low Note
PostPosted: Thu Aug 02, 2007 7:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Just happened to me.
PostPosted: Thu Aug 02, 2007 8:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Try to kill the cookies and see if things change?
Flickr
PostPosted: Thu Aug 02, 2007 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Safari gives me a weird internal error "report to Apple...". If I retry immediately I get the error again. If I close my eyes, recite some poetry, and then try again it works.
I'll look out for the next time it happens and copy/paste the error message here.
/Stefan
PostPosted: Thu Aug 02, 2007 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Try to kill the cookies first. Then pray or spray or whatever feels natural.
Flickr
PostPosted: Thu Aug 02, 2007 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, got it once again when just accessing electro-music.com (main page):
Safari kan inte öppna sidan ”http://www.electro-music.com/”. Felet var: ”förlorade nätverksanslutning” (NSURLErrorDomain:-1005) Välj Rapportera bugg till Apple från Safari-menyn, anteckna felnumret och beskriv vad du gjorde innan du såg det här meddelandet.
Sorry about the locale - it basically says "lost connection" and then "report bug to Apple". NSURLErrorDomain:-1005 is key I suppose. I got it a couple of times on the main page and then magically it worked. Then I got the same issue when clicking "forum" (I usually go here this way).
I'll try to remove all cookies next time before I try again, see if it works better. I have definitely not had this problem anywhere else before. I can access other sites ok (just tried a couple), althoug apple.com took a while to respond (could be that I'm visiting my parent's and using their slightly inferiour ADSL line).
/Stefan
PostPosted: Thu Aug 02, 2007 3:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've got the reset problem bad!
Accessing the site has become a real pain in the **** both today and yesterday
I'll try the cookies
ACHTUNG!
dewdrop_world
PostPosted: Thu Aug 02, 2007 3:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
The error I'm getting looks like:
WSAECONNRESET (10054)
Connection reset by peer.
An existing connection was forcibly closed by the remote host. This normally results if the peer application on the remote host is suddenly stopped, the host is rebooted, or the remote host used a "hard close" (see setsockopt for more information on the SO_LINGER option on the remote socket.)
(I mean, it doesn't look like that in Firefox, but Firefox reports "connection reset" which I believe corresponds to this standard networking error.)
hjh
PostPosted: Thu Aug 02, 2007 4:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
fwiw, i've just trashed the cookies- and everything seems okay at the moment (touch wood)
ACHTUNG!
PostPosted: Fri Aug 03, 2007 9:00 am    Post subject: Reply with quote  Mark this post and the followings unread
I've had a few "Page is unavailable" errors. If I click refresh, it's fine.
PostPosted: Fri Aug 03, 2007 10:13 am    Post subject: Reply with quote  Mark this post and the followings unread
The refresh did nothing at all here. However since I threw away ALL the EM related cookies, it's back to normal.
ACHTUNG!
Evan
PostPosted: Wed Aug 08, 2007 3:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
It must be Uncle Krunkus' new avatar...
Audio files: 299
PostPosted: Wed Aug 08, 2007 3:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Rather the old one showing it's unhappiness maybe Shocked Laughing
