Crackle Box DIY Synth Project
Page 3 of 4 [76 Posts]
bigtex
PostPosted: Mon Aug 07, 2006 10:27 am    Post subject: Reply with quote  Mark this post and the followings unread
bugbrand wrote:
Don't know about the danger aspect but you get bad-sound-ness-mess if you connect an audio out direct to the speaker in this case... Don't quite know why, but you do.!.
Well, if the speaker is still attached, it's because you'll be picking up other souds in the room. The speaker will act as a microphone! Shocked
Wild Zebra
PostPosted: Mon Aug 07, 2006 10:57 am    Post subject: Reply with quote  Mark this post and the followings unread
proceeded to squealy squak it and I told him no. Later on, while another act was playing I heard this guy blatantly messing around with this crackle box DURING their set. Talk about very rude and annoying. He's lucky he didn't get mauled.
Too bad that happened, but you can't blame it on the poor ole Cracklebox. Sad
"your stripes are killer bro"
shawn
PostPosted: Mon Aug 07, 2006 11:06 am    Post subject: Reply with quote  Mark this post and the followings unread
You're right, it's not the fault of the crackle box but the sounds those things can make certainly haven't impressed me enough. I suppose it has the "ciat-lonbarde" effect. basically really neat instruments but very bad samples showcasing the items. I'll just have to build one to see for myself.
Blacklight
PostPosted: Mon Aug 07, 2006 8:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
My usual method is to rig up a two way switch that breaks the circuit with the speaker and re-routs the speaker outs to a guitar or 14 inch jack so it makes using the speaker selectable. I ordered an actual box from Steim and I fully intend on building one once I totally get the schematic translated. A friend of mine had one and I loved it for what it was. It's fun to play with and I've used his with a mic in some of my music. I love the randomness of it and it sounds really cool with added FX. I have a circuit bent transister radio that I call "Mr Happynoise" (It looks like a round smiley face mounted in a black box) that sounds similar (It's playable with a photocell sewn onto a glove, a photocell mounted on top of a dome of a bendy lamp, and also touching a few brass knobs on it along with a plethora of sound altering buttons). I actually connected a bus wire from one of the knobs to the long metal railing in my house and connected another bus wire from the other knob to my ankle... therefore making the railing into a controller.. depending on where I touched the railing, Mr Happynoise would wail a different pitch. It was really cool. Mr Happynoise is like a theremin from hell and I'm still learning to carry a tune on it. It's so hard to play. 8D
dnny
PostPosted: Mon Aug 07, 2006 11:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
you should post some pictures and samples of Mr Happynoise -to our circuit bending -forum.
there is all ready schematics translated.
DIY Kraakdoos / Crackle Box
and welcome to electro-music.com forum
www.koelse.org
flickr: cable porn group
computer at sea
PostPosted: Thu Aug 16, 2007 8:03 am    Post subject: cracklebox voltage drop Reply with quote  Mark this post and the followings unread
I'm very much looking forward to building one of these.
Since the box performs differently as the battery ages, it seems like it would be a good move to install a pot on the +voltage like the traditional circuit bending 'voltage drop crash'. Then you can dial down the ammount of voltage comming into the circuit. Has anyone tried this?
I bet a 1k pot with a small resistor wired in parallel would do the trick nicely.
I'll let you know once I get all the parts.
Audio files: 235
PostPosted: Thu Aug 16, 2007 10:40 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome Computer at Sea
Yes, this is a great thing to do. I have seen this on several Crackle Boxes.
Blacklight
PostPosted: Thu Aug 16, 2007 11:32 am    Post subject: Reply with quote  Mark this post and the followings unread
My wife has threatened numerous times that she's going to throw my cracklebox in the lake near where we live. Damn she loves that thing ! Very Happy
loss1234
PostPosted: Thu Aug 30, 2007 12:33 pm    Post subject: nte 909 versus lm709 Reply with quote  Mark this post and the followings unread
does anybody know if this will work? its supposedly a direct replacement for the lm709, although you need to change the pin numbers on the schematic to fit. but as far as the tech specs, it seems to be identical. can anyone let me know if its worth trying?
thanks
etaoin
PostPosted: Fri Aug 31, 2007 12:37 am    Post subject: Reply with quote  Mark this post and the followings unread
By the way, I have some SN72709 spare if anyone's interested. They are NOS but can't guarantee they're OK, unless someone can point me to a small circuit I could use to test them.
TI's 709
 Filesize:  87.85 KB
 Viewed:  25428 Time(s)
http://www.casia.org/modular/
loss1234
PostPosted: Fri Aug 31, 2007 6:07 am    Post subject: oops sorry Reply with quote  Mark this post and the followings unread
i made the mistake of PMing you thinking these were the SNchips thomas henry talks about
sorry. i guess i am not interested. sn76477's are what i am looking for.
thanks
etaoin
PostPosted: Fri Aug 31, 2007 7:35 am    Post subject: Reply with quote  Mark this post and the followings unread
No, these are 709's from Texas Instruments. The 76477 is much larger anyway (28 pins).
rubendelacosta
PostPosted: Sun Sep 02, 2007 3:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi there!
just an idea:
could a crackle box be turned in to a nice cv controller?
just wondering...
loss1234
PostPosted: Sun Sep 02, 2007 3:28 pm    Post subject: how... Reply with quote  Mark this post and the followings unread
how would you do that
id be interested.
dan
rubendelacosta
PostPosted: Sun Sep 02, 2007 5:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
well, forget about the crackle box idea...i couldn't figure out a way to do that anyways...
BUT! i had this random controller idea 30mins a go and it might work
(sorry, it's probably of topic...)
and i hope to get some help Wink
so, the whole idea it's based around the great ken stone's psyco lfo (here is the schematic http://www.cgs.synth.net/modules/psycho_lfo.html here is some samples too http://www.metalbox.com/samples/psychosine.mp3 http://www.metalbox.com/samples/psychopulsefilter.mp3 it sure is a great module!)
hope ken stone don't get mad at me...
and my idea would be something like this:
build something like a tabletop controller that you would use all you fingers on it.
i also did a simple patch that i think would work well (yeah...i got nothing to do) http://img98.imageshack.us/img98/8578/patchkv6.png (the word "points" it's misspelled...please don't laugh)
now, maybe some features should be add, and here is where i need some help.
-- a wave shaper would be cool, so you don't have only square waves.
-- and maybe a trigger circuit would be nice too to trigger adsr's or something like that (probably a foot trigger would be smartest...)
any idea?
hope you understood everything... my windows "Paint" skills are lame and sorry for my inglish Rolling Eyes
thank you for your time,
rubens.
clarke68
PostPosted: Sat Mar 27, 2010 11:56 am    Post subject: DIY Cracklebox Reply with quote  Mark this post and the followings unread
The first synth/noisemaker thing I've ever built! Shamelessly showing it off here like a proud papa (hard to decide if I should create a new thread or drag up this old one). Overall I'm very happy with the build...for some reason the finished product is a lot louder than it was on the breadboard.
Hardest parts were the transistor "array" (gorgeous & elegant on the schmatic, convoluted & weird on the protoboard) and stuffing the whole thing into this tiny box.
The box was some schwag I got from work for a project I worked on...nice box that has done nothing but hold a pen for the last 10 years. Now it has a new purpose and is getting a good deal more attention! I brought it to a friend's house last night, his 3-year-old son loved it...carried it around and played it all night. Now I think I need to build him one.
The opamp is an actual LM709 I got from bgmicro. The knob on the side is a 1k pot with an SPST switch, the pot used as a voltage starve. Adding a voltage starve is essential on these things (thanks for the suggestion Mosc and Computer at Sea)...it changes the behavior of the instrument quite a bit and adds another level of expression. I tried an LED in the circuit while it was on the breadboard, but it seemed to subtly soften the sound in ways I didn't like, so I left it out.
Short video of a "performance" in a parking garage: http://www.youtube.com/watch?v=4zbR4uBJOv8
mark_olson
PostPosted: Sun Mar 28, 2010 2:42 pm    Post subject: Re: DIY Cracklebox Reply with quote  Mark this post and the followings unread
clarke68 wrote:
Short video of a "performance" in a parking garage...
Very nice, clarke68.
I have breadboarded this circuit many times and it has never worked the same twice. It's a lot of fun.
I am also really impressed by the way you added reverb in the video. I live a block from a parking garage and never appreciated that it draws no current, isn't a bear to troubleshoot, accepts any kind of input, etc.
Thanks for sharing!
Mark
Audio files: 235
PostPosted: Tue Mar 30, 2010 12:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
clarke68, beautiful job. Great way to reuse that advertising gimmick box. Smile
I love the video too. Very Happy
Danno Gee Ray
PostPosted: Tue Mar 30, 2010 2:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think your increase in perceived volume is due to resonance with cool wood. Wink
The Peasant
PostPosted: Wed Mar 31, 2010 7:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've built probabloy half a dozen crackleboxes, no two ever sounded the same!
http://www.electronicpeasant.com/projects/krakcats/krakcats.html
Take care,
Doug
The Electronic Peasant
clarke68
PostPosted: Fri Apr 02, 2010 1:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
That is amazing...totally makes me want to build another one!
EpicFail
PostPosted: Mon Jul 09, 2012 8:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi there! Just found this post on the cracklebox. Definitely want to give this a go and think I've tracked down a supplier of the LM709 from Cricklewood Electronics: http://www.cricklewoodelectronics.com/Cricklewood/search.php?mode=search&page=1
Can anyone tell me whether I need the LM709CH or LM709CP? I'm guessing it's the latter as it looks like the one people have been using the these projects...
clarke68
PostPosted: Mon Jul 09, 2012 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
The only difference is the package, so either will work in the circuit. You can decide based on which format you're more comfortable working with, which one looks cooler, etc.
EpicFail
PostPosted: Mon Jul 09, 2012 10:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks clarke68. Good to know.
mrkva
PostPosted: Tue Jul 10, 2012 9:55 am    Post subject: Reply with quote  Mark this post and the followings unread
For those interested, I've developed a simple cracklebox alternative based around 40106 inverter http://electro-music.com/forum/viewtopic.php?highlight=hniezdo&t=52008
