source for non polarized electrolytic caps
Page 1 of 1 [4 Posts]
a.b.o.z.
G2 patch files: 4
PostPosted: Sun Sep 09, 2007 8:58 am    Post subject: source for non polarized electrolytic caps Reply with quote  Mark this post and the followings unread
I'm recaping boss rps-10 and came across 1uF cap. It's electrolytic but there is no mark of positive or negative side. Neither on cap or silkscreen. I'm confused. Where to find those caps? Can I use some other kind?
 Filesize:  80.01 KB
 Viewed:  299 Time(s)
 Filesize:  72.65 KB
 Viewed:  275 Time(s)
Clack
PostPosted: Mon Sep 10, 2007 5:08 am    Post subject: Reply with quote  Mark this post and the followings unread
its a non polarized electrolytic cap
http://www.rapidonline.com/productinfo.aspx?tier1=Electronic+Components&tier2=Capacitors&tier3=Electrolytic&tier4=Non-polarised+85%26deg%3bC+radial+capacitors&moduleno=78276
can get you some if you need it next time I order. I'd check if you can get them from your local supplier first. You can replace it with a ceramic or polyester, I think they are used because its quite hard to get ceramic , polyester, polystyrene in high f
Clacktronics.co.uk
a.b.o.z.
G2 patch files: 4
PostPosted: Mon Sep 10, 2007 7:19 am    Post subject: Reply with quote  Mark this post and the followings unread
i checked whit my locals..no luck. friend told me to use two polarized to get a non one.
thnx.
jfromel
PostPosted: Sat Aug 23, 2008 12:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Use a 1uF film cap. AVX has a box one that takes up a pretty small footprint for a film cap of this value.
