Nosferatu
Joined: Jul 27, 2007 Posts: 234 Location: Planet Rock.
Posted: Thu Sep 20, 2007 5:25 pm Post subject:
del |
del Last edited by Nosferatu on Mon Nov 26, 2007 2:34 pm; edited 1 time in total |
andrewF
Posted: Fri Sep 21, 2007 8:18 am Post subject:
I'm curious about the BC547, P7 pot (trimmer?) and the freq mod input.
Are you affecting freq by control the VDD of the chips, or is it more like a 'pause' function? |
Nosferatu
Posted: Fri Sep 21, 2007 11:07 am Post subject:
del Last edited by Nosferatu on Mon Nov 26, 2007 2:35 pm; edited 1 time in total |
creekree
Joined: Mar 30, 2006 Posts: 192 Location: Morgenland Neukölln
Posted: Fri Sep 21, 2007 2:52 pm Post subject:
sound samples, dude, sound samples!!
EdisonRex
Audio files: 172
Posted: Fri Sep 21, 2007 3:29 pm Post subject:
creekree wrote: | sound samples, dude, sound samples!!
and a picture of your module...
I actually like this circuit, looking at it. It fits my imagination test, such as it is. It uses novel ideas to solve a novel problem. It is unusual. It reminds me if Ian Fritz's ideas, no offense intended. (you should actually think of that as a fine compliment from me as I am quite in awe of Mr. Fritz's imagination in his designs). _________________ Garret: It's so retro.
fluxmonkey
EdisonRex
Audio files: 172
Posted: Fri Sep 21, 2007 4:32 pm Post subject:
yup, and Scott cites good old TH for the idea. I should do some more homework. Interesting set of links. I should have looked at Scott's site in more detail, but the organization leaves a bit to be desired as it is temporally based and not thematically indexed. Maybe Scott will read this and comment...
Learn a new thing every day. I learned to rescue an important job from an Oracle database crash today, and I thought that was the important lesson. Maybe it wasn't.
Nosferatu
Posted: Fri Sep 21, 2007 5:19 pm Post subject:
del Last edited by Nosferatu on Mon Nov 26, 2007 2:35 pm; edited 2 times in total |
Nosferatu
Posted: Sun Sep 23, 2007 10:09 am Post subject:
del Last edited by Nosferatu on Mon Nov 26, 2007 2:36 pm; edited 7 times in total |
Joined: Apr 03, 2004 Posts: 24392 Location: The Netherlands, Enschede
Audio files: 296
Posted: Sun Sep 23, 2007 10:18 am Post subject:
Nice !
Edit: hey there are more now  _________________ Jan
Nosferatu
Posted: Sun Sep 23, 2007 10:35 am Post subject:
del Last edited by Nosferatu on Mon Nov 26, 2007 2:38 pm; edited 2 times in total |
loss1234
Adam-V
Posted: Mon Oct 08, 2007 3:49 pm Post subject:
AG = Analogue Ground (For those folks who like to keep the dirty digital ground path away from the analogue signal ground).
Adam-V _________________ Digitalis Effect | Fractured Symmetry (www.spiralsect.com) |
loss1234
Audio files: 296
Posted: Mon Oct 08, 2007 4:00 pm Post subject:
Re: 2 psu? |
loss1234 wrote: | do you have 2 use two psu's? |
No you keep analog and digital grounds separate throughout the circuit and then connect them to each other at the PSU ground terminal.
The circuit above uses AG only, so it's just ground here. _________________ Jan
Adam-V
Posted: Mon Oct 08, 2007 4:04 pm Post subject:
Nothing so complex as two power supplies. You simply have two ground lines running out from a common ground point within your module that serve the analogue and digital circuitry separately. Ultimately ground is ground but by using the separate analogue/digital lines and having them converge at a point closer to the supply rather than being mixed, the analogue circuits can be kept relatively free of digital noise.
Some people go so far as to extend this right back to the power supply but I don't think that is absolutely necessary.
In this case, since the circuit, although digital, is a sound generator, there is only an analogue ground represented so you shouldn't need to worry too much about it.
Nosferatu
Posted: Mon Oct 08, 2007 6:23 pm Post subject:
Quote: |
In this case, since the circuit, although digital, is a sound generator, there is only an analogue ground represented so you shouldn't need to worry too much about it. |
Hohum!
The circuit are all analog.  |
Audio files: 296
Posted: Wed Oct 10, 2007 4:31 pm Post subject:
I split off a couple of posts that started out as a circuit similar to the original one posted by Nosferatu, which went on though to be more like a project in itself.
See : http://electro-music.com/forum/post-143488.html _________________ Jan
