del
Page 1 of 1 [18 Posts]
Nosferatu
PostPosted: Thu Sep 20, 2007 5:25 pm    Post subject: del Reply with quote  Mark this post and the followings unread
del
andrewF
PostPosted: Fri Sep 21, 2007 8:18 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm curious about the BC547, P7 pot (trimmer?) and the freq mod input.
Are you affecting freq by control the VDD of the chips, or is it more like a 'pause' function?
Nosferatu
PostPosted: Fri Sep 21, 2007 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
del
creekree
PostPosted: Fri Sep 21, 2007 2:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
sound samples, dude, sound samples!!
EdisonRex
Audio files: 172
PostPosted: Fri Sep 21, 2007 3:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
and a picture of your module... Wink
I actually like this circuit, looking at it. It fits my imagination test, such as it is. It uses novel ideas to solve a novel problem. It is unusual. It reminds me if Ian Fritz's ideas, no offense intended. (you should actually think of that as a fine compliment from me as I am quite in awe of Mr. Fritz's imagination in his designs).
Garret: It's so retro.
fluxmonkey
PostPosted: Fri Sep 21, 2007 4:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
reminds me quite a bit of scott stites take on thomas henry's pitched noise generator:
http://mypeoplepc.com/members/scottnoanh/slsdiy/id18.html (scroll down to april 2004)
http://mypeoplepc.com/members/scottnoanh/sitebuildercontent/sitebuilderfiles/bank1.jpg
http://mypeoplepc.com/members/scottnoanh/sitebuildercontent/sitebuilderfiles/bank2.jpg
his design preset the 6 oscillators at 6 separate freqs, and then varied all 6 w/ vactrols, all chained to a single modulator. i built one, good for what it did but not very versital.
in the same family as ken stones superpsyco, as well: http://www.cgs.synth.net/modules/cgs21_super_psycho.html
still lots of variations to be made on this theme, m'thinks... thanks for sharing.
bbob
EdisonRex
Audio files: 172
PostPosted: Fri Sep 21, 2007 4:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
yup, and Scott cites good old TH for the idea. I should do some more homework. Interesting set of links. I should have looked at Scott's site in more detail, but the organization leaves a bit to be desired as it is temporally based and not thematically indexed. Maybe Scott will read this and comment...
Learn a new thing every day. I learned to rescue an important job from an Oracle database crash today, and I thought that was the important lesson. Maybe it wasn't.
Idea
Nosferatu
PostPosted: Fri Sep 21, 2007 5:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
del
Nosferatu
PostPosted: Sun Sep 23, 2007 10:09 am    Post subject: Reply with quote  Mark this post and the followings unread
del
PostPosted: Sun Sep 23, 2007 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Nosferatu wrote:
Sounds!
Nice !
Edit: hey there are more now Very Happy
Nosferatu
PostPosted: Sun Sep 23, 2007 10:35 am    Post subject: Reply with quote  Mark this post and the followings unread
del
loss1234
PostPosted: Mon Oct 08, 2007 3:21 pm    Post subject: AG??? Reply with quote  Mark this post and the followings unread
what is AG on schematic???
Adam-V
PostPosted: Mon Oct 08, 2007 3:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
AG = Analogue Ground (For those folks who like to keep the dirty digital ground path away from the analogue signal ground).
Adam-V
loss1234
PostPosted: Mon Oct 08, 2007 3:52 pm    Post subject: 2 psu? Reply with quote  Mark this post and the followings unread
so how do you create a second ground? i have had problems with dirty grounds..... do you have 2 use two psu's?
thanks
PostPosted: Mon Oct 08, 2007 4:00 pm    Post subject: Re: 2 psu? Reply with quote  Mark this post and the followings unread
No you keep analog and digital grounds separate throughout the circuit and then connect them to each other at the PSU ground terminal.
The circuit above uses AG only, so it's just ground here.
Adam-V
PostPosted: Mon Oct 08, 2007 4:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nothing so complex as two power supplies. You simply have two ground lines running out from a common ground point within your module that serve the analogue and digital circuitry separately. Ultimately ground is ground but by using the separate analogue/digital lines and having them converge at a point closer to the supply rather than being mixed, the analogue circuits can be kept relatively free of digital noise.
Some people go so far as to extend this right back to the power supply but I don't think that is absolutely necessary.
In this case, since the circuit, although digital, is a sound generator, there is only an analogue ground represented so you shouldn't need to worry too much about it.
Adam-V
Nosferatu
PostPosted: Mon Oct 08, 2007 6:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hohum!
The circuit are all analog.
PostPosted: Wed Oct 10, 2007 4:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
I split off a couple of posts that started out as a circuit similar to the original one posted by Nosferatu, which went on though to be more like a project in itself.
See : http://electro-music.com/forum/post-143488.html
